Wheel Weight Missing, Handlebars judder when turning left
Ol
PostPosted: 11:54 - 06 Nov 2010    Post subject: Wheel Weight Missing, Handlebars judder when turning left Reply with quote
As per the title really, when turning left the handlebars judder, but not when going in a straight line or turning right.
At first i thought it would be the head bearings starting to go, or the rear wheel isn't aligned properly, but whilst giving the bike a clean this morning (well, my daughter was cleaning it, i just noticed a mark on the wheel) it looks like there could be a wheel weight has fallen off (see pics below)
does this sound like it could be the cause of the left hand bend juddering??
Many Thanks, Ol.
https://i1016.photobucket.com/albums/af282/Oliver7978/061120101093.jpg
https://i1016.photobucket.com/albums/af282/Oliver7978/061120101094.jpg
PostPosted: 15:50 - 06 Nov 2010    Post subject: Re: Wheel Weight Missing, Handlebars judder when turning lef Reply with quote
I'd suspect bearings more - unbalanced wheel judder tends to be dependant on speed not turning in my experience.
Check wheel and head bearings if you haven't.
Damon
PostPosted: 17:46 - 06 Nov 2010    Post subject: Reply with quote
Na, you wont feel the difference of having one less wheel weight at all.
As G said it could be wheel bearings or head bearings.
nightshaddow
PostPosted: 08:59 - 09 Nov 2010    Post subject: Reply with quote
it could even be uneven tyre ware on one side
Ol
PostPosted: 09:15 - 09 Nov 2010    Post subject: Reply with quote
Thanks All – I’ll have a look at the head bearing when I’ve got a minute…
Tyre wear isn’t too bad, quite even I think – tho the rear is slightly squared off, not too bad though.
Karma
MaybeGuy
PostPosted: 09:21 - 09 Nov 2010    Post subject: Reply with quote
you're not even missing a wheel weight. they're all in the same place, and the strip is still attached.
Ol
PostPosted: 09:44 - 09 Nov 2010    Post subject: Reply with quote
To be honest, it did cross my mind that the left over strip thats been taken off could have been from last time the tyre was changed, but i'd have expected i'd have noticed when cleaning the bike before!
PostPosted: 10:11 - 09 Nov 2010    Post subject: Reply with quote
Wheel weights are not always fitted together, though really they ideally should be.
Ie, fitter puts a few on, spins wheel (or uses machine) again and finds it's still not in balance, but overall position of the balance has moved a bit with the first lot of weights.
Similarly, especially if doing it manually, it's not uncommon to see several weights stuck down next to each other not in a strip, as more are added.
However, yes, it does seem more likely they were there from a previous occasion.
The last post was made 15 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 57.57 Kb
