| Syris the Indomitable |
 Syris the Indomitable Crazy Courier
| Flip |
 Flip Super Spammer
 Posted: 22:11 - 06 Nov 2010 Post subject: |
| willi |
 willi Spanner Monkey
| Glenben92 |
 Glenben92 Nearly there...
 Posted: 04:51 - 07 Nov 2010 Post subject: |
https://download.cnet.com/Smart-Defrag/3000-2094_4-10759533.html?tag=mncol;1
best i've came across. actually downloaded this when i had vista BECAUSE of the utter shit defrag that it comes with. This not only will defrag quickly showing detailed analysis of the HDD, but it'll order files based on usage frequency, for more effective operation can't complain ____________________ 57 Huoniao HN125-8 - , 97 Kawasaki GPZ500S -
99 Yamaha FZS 600 -
Mod 2 Passed - 01/10/2010 |
| pinkyfloyd |
 pinkyfloyd Super Spammer
| Inkognito |
 Inkognito Brolly Dolly
| t121anf |
 t121anf World Chat Champion
| Frost |
 Frost World Chat Champion
| t121anf |
| ajag |
 ajag Brolly Dolly
| Astridax |
 Astridax Nitrous Nuisance
 Posted: 21:18 - 08 Nov 2010 Post subject: |
Good god, please don't defrag an SSD, they only have a limited number or writes and rewrites, defragging is moving sectors of data around, therefore = lots of rw/r.
Also, I would pay for 2hrs defragging. I haven't tried to defrag a hard drive since the 2gb days, with 2x 1TB hard drives it would never finish, even with my i7 . |
| Inkognito |
| Rob W |
 Rob W World Chat Champion
| Rob W |
 Posted: 21:41 - 08 Nov 2010 Post subject: |
Not to be confused with an 'STD'.
 ____________________ '90 TS50 > '04 Senda 125 > '91 ZXR400 > '90 CB-1 > '04 GSX-R1000 > '96 Bandit 600 > '89 ZXR750 H1 > '96 GSX-R750 SRAD > '98 RR-W Fireblade > '98 T595 Daytona > '03 Hornet 900 > '04 Fireblade > '16 GSX-S1000F (x2) > '23 XSR900 |
| Inkognito |
 Posted: 21:52 - 08 Nov 2010 Post subject: |
Hmm.
I wouldn't fancy using a drive that "wears out" quickly
Can't see any use for them other than to load backups onto and never use again untill backup is needed.
Is that the point of these drives? |
| Frost |
 Posted: 22:10 - 08 Nov 2010 Post subject: |
No moving parts, so no discs to fuck up by dropping your laptop or something, lower power usage, silent, 0 seek time as there is no disk to spin round and head to move to a required position, potentially much faster read write speeds. They are basically like RAM but they keep their contents when turned off. Hard disks get fragmented when a file gets split up into lots of locations. The reason this is done is because the outer part of the disk can contain more data and be accessed quicker. As the disk fills up it gets slower as the slower bits get used. A brand new hard disk can go at about 75mb/s. As the disk gets older and bits get damaged, and as the disk fills up with data it gets slower, usually dropping to about 40mb/s. Write speed can be less.
Typical SSD speeds are:
Read Speed: 285MB/Sec, Write Speed: 275MB/Sec
Some are MUCH better up to:
Read 1400MB/s, Write 1400MB/s
Generally they're only great for laptops atm as they use less power and allow it to boot much faster, but they are becoming cheaper, faster and longer lasting and in a few years will be the standard for desktops.
These days almost all come with fancy tech on them to spread the read & write locations about the drive space to reduce wear on each area. When they wear out they reduce in capacity, rather than lose data or just stop working. |
 Posted: 22:44 - 08 Nov 2010 Post subject: |
| TwoSock wrote: | Hmm.
They are still very expensive, they never need de-fragmenting, you can drop them with little or no effect (unlike plattered hard drives), and the read writes supposed to be a bit quicker. All I can say is that the one I had was a bit glitchy in my VAIO. O/S kept crashing, it was brand new.
I say the glitch trait is linked to the SSD because I have never experienced the anomaly before in other computers. A reboot sorts it.
But then it may have just been the one I had, I would read people reviews before splashing out. ____________________ In Greek mythology Ichor is what immortals have in the place of blood
Those that mind, don't matter...Those that matter, don't mind. Do you agree with this?
Last edited by Syris the Indomitable on 22:48 - 08 Nov 2010; edited 1 time in total |
| Inkognito |
 Posted: 23:00 - 08 Nov 2010 Post subject: |
They do last longer.
If you think about a non-volatile flash memory type pendrive.
Some allow 1 million write or erase cycles and have a 10 year data retention cycle.”
USB flash drives allow reading, writing, and erasing of data, with some allowing 1 million write/erase cycles in each cell of memory: if 100 uses per day, 1 million cycles could span 10,000 days or over 27 years. https://www.cfgear.com/how-long-does-a-flash-drive-last/
SLC based memory https://en.wikipedia.org/wiki/Multi-level_cell#Single-level_cell
SLC based memory is good for around 100,000 writes; more commonly used MLC https://en.wikipedia.org/wiki/Multi-level_cell for around 10,000. The USB connector can withstand approximately 1,500 connect/disconnect cycles.
SSD's are 30 to 200 times larger than pen drives so do the maths.
This is why they are very expensive, they last for ever.
My laptop takes one but they want £250 quid for it.
I think it's something to do with the connection type or something.
It's not as common as most are. ____________________ In Greek mythology Ichor is what immortals have in the place of blood
Those that mind, don't matter...Those that matter, don't mind. Do you agree with this? |
| Frost |
 Posted: 23:14 - 08 Nov 2010 Post subject: |
The worst drives take about 8 years of continuous use to kill, the better ones are 30+. When i say continuous, i mean it, actually trying to wear the thing out 24/7 rather that just using it. You'd have to write a script to thrash the shit out of it night and day
As far as i'm concerned capacity & price are why i don't have one. Sure you can get a 2TB one, but it's going to cost £6000. Currently the 64GB ones are reasonable (£100ish) but a lot aren't very fast. If they were 128GB 300mb/300mb and £100, i'd buy 2 and raid them  |
The last post was made 15 years, 321 days ago. Instead of replying here, would creating a new thread be more useful? |
