quad core temps too low ?
willi
PostPosted: 22:17 - 06 Nov 2010    Post subject: Reply with quote
the cooler the better i would say.
wat goes around comes around.
Inkognito
PostPosted: 22:30 - 06 Nov 2010    Post subject: Reply with quote
Some fans work better than others.
Mine is about the same as yours but i have 4 extra fans in the tower.
The cooler the better Razz
Frost
PostPosted: 23:11 - 06 Nov 2010    Post subject: Reply with quote
There might be such a thing as too low, but i suspect it would be below -272 Laughing My hex core runs colder than my actual room is, but them it's on the floor by a cold window. Your mate might be suggesting that a sensor is incorrect as he considers the reading impossible. My thermodynamics isn't up tot he task of telling you if thats strictly true or not though.
The Artist
PostPosted: 23:17 - 06 Nov 2010    Post subject: Reply with quote
Sensor is probably ballsed up. No biggy. Mine used to say 25c when it was new, go to 31c at full tilt. Doesn't mean it actually was 25c, but if it went to 40c, I would know something was up.
L4Isoside
PostPosted: 23:20 - 06 Nov 2010    Post subject: Reply with quote
Sounds like the sensor is giving a false reading, a computer cannot read lower than room temp on air alone.
Hetzer
PostPosted: 23:40 - 06 Nov 2010    Post subject: Reply with quote
Do you have the temp-program calibrated with the chip's correct TJ-Max?
Frost
PostPosted: 23:53 - 06 Nov 2010    Post subject: Reply with quote
So do you have 4 fans total, or 4 cpu fans? Mine only has the 1 cpu fan, but i can disconnect it and provided my system isn't under a lot of load the temp stays constant. Bloody big heat sync on it though, barely fits in the case!
Frost
PostPosted: 00:45 - 07 Nov 2010    Post subject: Reply with quote
Thats more case cooling than CPU specific cooling. So a quick sanity check would be to compare the CPU and system temps. They should both be about the same / cpu higher.
Hetzer
PostPosted: 13:03 - 07 Nov 2010    Post subject: Reply with quote
rob yarrr wrote:
well i just downloaded it and ran it,not changed anything from its standard
doesn't seem to be many things you can change on the program anyway
Download CoreTemp, look up the TJ-Max value for your specific chip and enter it into the CoreTemp program's Offset options.
The last post was made 15 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 92.34 Kb
