indecators stop working
theshmoo
Bottomless Pit
PostPosted: 00:00 - 30 Jul 2004    Post subject: indecators stop working Reply with quote
my indicators have stopped working on my nsr125rr its their a fuse box or something i should check to find out whats wrong Sad
CBR 1100 blackbird.
broomy12
PostPosted: 00:17 - 30 Jul 2004    Post subject: Reply with quote
there should be a few of um floating about check on your user manual and see hwere they are hidding
broomy12
(fuses im on about)
tatters
Exxon Valdez
PostPosted: 00:37 - 30 Jul 2004    Post subject: Reply with quote
main fuse is located in the postive cable running form the battery, but its not that which is wrong because everythink would not work Smile .
can,t remeber were the other secondary fuses are, but remove both rear side panels and have a look most bikes have them there and see if any have blown/burned out, should be in a little rubber holder or a small black box.
also have a look at your flasher relay, and check that it has,nt fryed its self, check with a multimeter
and finaly the inducator switch (handel bars) which could be getting stuck or the contacts are worn out/correded (differcult to get open, and fragel)
broomy12
PostPosted: 01:03 - 30 Jul 2004    Post subject: Reply with quote
ooo yeah the relay i forgot to mention that sorry i had the same problem mine didnt flash at all n so i had to give the relay a good old hit back into the sockit n it worked Smile
theshmoo
Bottomless Pit
PostPosted: 09:32 - 30 Jul 2004    Post subject: Reply with quote
thanks ill give these things a try ill let you know how i get on Cool
CBR 1100 blackbird.
mr jamez
PostPosted: 11:20 - 30 Jul 2004    Post subject: Reply with quote
Only one fuse on the NSR as far as I know which is right next to the battery on the right hand side. The relay for the indicator on my NSR is under the fuel tank on the left hand side.
theshmoo
Bottomless Pit
PostPosted: 15:37 - 04 Aug 2004    Post subject: Reply with quote
it seems to be the flasher unit it costs £35 from honda i get it today and ill fit it and let you guys know how i get on it was located next to the cdi at the back of the bike under the seat. Smile
CBR 1100 blackbird.
Big Pete
PostPosted: 16:10 - 04 Aug 2004    Post subject: Reply with quote
Shocked Shocked £35?? get to halfords and buy a car one for under a tenner and wire it in.
Trust me, I`m an engineer
GarageOfPower.co.uk
baldy
PostPosted: 17:59 - 04 Aug 2004    Post subject: Reply with quote
Just use one from a old bike, most work on any as long as they are the same voltage and stuff.
One day i will rule the world, just not today.
PostPosted: 23:57 - 04 Aug 2004    Post subject: Reply with quote
Shocked 35 quid! tell them to pull the other one for surely it has bells on. Genuine honda flasher relays, 12 volt, two or three pin (count 'em) should set you back NO MORE than a fiver.
You checked the bulbs aren't blown? the japanese have taken built-in obsolescence to new heights as I found when my kawa popped all six instrument panel bulbs (on different circuits) within two days!
theshmoo
Bottomless Pit
PostPosted: 16:59 - 05 Aug 2004    Post subject: Reply with quote
went to halfords and tryed lots of relays also went to hanna auto electrics and hand 1 of thir sparks try and find me a relay that worked most lit up the lights but did not flash.the flasher unit from my nsr super sprint is a mitsba fr-2201 12.8v 85c/m 10wX2+3.4w (10wX2+A.P).got it from honda and it worked no more hands signals coming of round abouts Very Happy
CBR 1100 blackbird.
The last post was made 22 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 74.9 Kb
