| spetom |
 spetom Trackday Trickster
| Paxovasa |
 Paxovasa World Chat Champion
 Posted: 19:19 - 08 Nov 2010 Post subject: |
With floating disc's this shouldn't happen.
The pistons are not releasing properly, you need to give them a clean  ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
| Ingah |
 Ingah World Chat Champion
 Posted: 19:22 - 08 Nov 2010 Post subject: |
Aren't you riding a CB500? (sorry if you're not, it's hard to keep track )
If you are, it's perfectly normal (if a little bit strange as it seems like it should be an avoidable inefficiency) ____________________ -- Ingah |
| spetom |
| Ingah |
| Frost |
 Frost World Chat Champion
| Teflon-Mike |
 Posted: 20:17 - 08 Nov 2010 Post subject: |
| DaFrostyOne wrote: | The pads get pushed into the disc by pistons which retract when the lever is eased off. The pads however aren't attached to the pistons and will therefore continue to rub a little. Pulling the brake on will result in a front wheel that's hard to turn by hand, but the momentum of the bike easily turns it. This eventually causes the pads to free off from the disc. Try going for a ride, then when coming home using the engine and rear brake to stop, then try spinning the front wheel by hand, it'll be easy. |
But its a Honda, with thier notoriouse floating calipers. Worse a budget model, with the cost cutting examples!
Yes, perfectly normal. Honda use floating calipers and fixed discs. When well serviced they work wonderfully. But worn or neglected they dont, and will rub a bit.
If you are concerned about it, strip, clean and grease. Honda calipers dont like british winters. New float pins and grommets are often a worth while investment in the excersize, & pay particular attension to teh anti-rattle clips. They have a tendancy to rust and not work, or worse, go completely AWOL leaving the pads dangling,
Coppa-Slip is the Honda Caliper's best freind. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
The last post was made 15 years, 73 days ago. Instead of replying here, would creating a new thread be more useful? |
