Front disc brake, normal functioning and adjustement
spetom
PostPosted: 19:17 - 08 Nov 2010    Post subject: Front disc brake, normal functioning and adjustement Reply with quote
I've owned 3 bikes including my current bike with front disc brakes, I notice on my last 2 bikes that while the rear drum brake wheel could be adjusted so it moved freely until the brakes are used, it seems the front wheel is never really free of the brake ever so slightly touching at all times.
Is this how discs are supposed to be? My current bike and my last bike both had discs and both operated in the same way, so the wheel turns but always has some slight resistance.
I've been searching for literature on the subject but nowhere can I find how you can adjust disc brakes.
Paxovasa
PostPosted: 19:19 - 08 Nov 2010    Post subject: Reply with quote
With floating disc's this shouldn't happen.
The pistons are not releasing properly, you need to give them a clean Thumbs Up
Ingah
PostPosted: 19:22 - 08 Nov 2010    Post subject: Reply with quote
Aren't you riding a CB500? (sorry if you're not, it's hard to keep track Embarassed )
If you are, it's perfectly normal Thumbs Up (if a little bit strange as it seems like it should be an avoidable inefficiency)
-- Ingah
spetom
PostPosted: 19:35 - 08 Nov 2010    Post subject: Reply with quote
Yea I'm on a CB 500. BTW Ingah I got those bits for the carb from davidsilvers.
I thought it was normal as I'd had the same previously with the Wuyang and CG.
Ingah
PostPosted: 19:46 - 08 Nov 2010    Post subject: Reply with quote
The jets and the washers?
Cheers, will update the website.
-- Ingah
Frost
PostPosted: 20:09 - 08 Nov 2010    Post subject: Reply with quote
The pads get pushed into the disc by pistons which retract when the lever is eased off. The pads however aren't attached to the pistons and will therefore continue to rub a little. Pulling the brake on will result in a front wheel that's hard to turn by hand, but the momentum of the bike easily turns it. This eventually causes the pads to free off from the disc. Try going for a ride, then when coming home using the engine and rear brake to stop, then try spinning the front wheel by hand, it'll be easy.
Teflon-Mike
tl;dr
PostPosted: 20:17 - 08 Nov 2010    Post subject: Reply with quote
But its a Honda, with thier notoriouse floating calipers. Worse a budget model, with the cost cutting examples!
Yes, perfectly normal. Honda use floating calipers and fixed discs. When well serviced they work wonderfully. But worn or neglected they dont, and will rub a bit.
If you are concerned about it, strip, clean and grease. Honda calipers dont like british winters. New float pins and grommets are often a worth while investment in the excersize, & pay particular attension to teh anti-rattle clips. They have a tendancy to rust and not work, or worse, go completely AWOL leaving the pads dangling,
Coppa-Slip is the Honda Caliper's best freind.
The last post was made 15 years, 72 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 53.24 Kb
