clunk intio gear
fbmbmx
PostPosted: 20:51 - 08 Nov 2010    Post subject: clunk intio gear Reply with quote
Is it normal for you bike to make a clunk noise when you select a new gear?
Mine does and was just wondering if this is normal. I ride a gsxr k3 is that helps
Thanks
Suzuki gsxr 600-2003
PostPosted: 21:00 - 08 Nov 2010    Post subject: Reply with quote
Mine clunks when the engine is cold, warm and it's fine.
crackfinder
PostPosted: 21:01 - 08 Nov 2010    Post subject: Reply with quote
I suppose that depends on what you mean when you say "select a New gear"
If you mean while stationary it clunks when you go from neutral to first...all bikes do that to some degree,
Benson_JV
From neutral to first every bike I've ever heard makes a good clunk. Other gears I suppose it depends on the bike. Nothing to worry about I should imagine Thumbs Up
PostPosted: 21:05 - 08 Nov 2010    Post subject: Reply with quote
...From neutral in to first Thumbs Up
HD
PostPosted: 21:06 - 08 Nov 2010    Post subject: Reply with quote
Yep. And, according to my dad, Suzuki's are worse!
I wouldn't worry at all.
fbmbmx
PostPosted: 21:11 - 08 Nov 2010    Post subject: Reply with quote
That's okay then Smile its quite a nice sounding clunk if there is one.
Dosent sound like a grinding or snapping just a
"That's a gear" clunk lol
weasley
PostPosted: 22:41 - 08 Nov 2010    Post subject: Reply with quote
And, if anyone's interested, here comes the science bit...
Most bikes have a wet clutch - this means the clutch is immersed in oil. Now, in a dry clutch, when you pull the clutch lever the friction plates separate and there is no connection between the engine and the gearbox - this is what allows you to make a gear change. However, in a wet clutch the oil gets between the friction surfaces and acts like a viscous coupling - this means that there is a small amount of drive being transmitted through the oil to the clutch plates. In this way there is always a little bit of pressure driving through the gearbox, hence the 'clunk', as the input shaft is still spinning a bit when you select the gear. A cold oil is thicker and makes the situation 'worse'.
This is the same reason that it is more difficult to push a bike in gear, even with the clutch pulled in. Also why the back wheel often spins a little when the engine is running and its up on a paddock stand, even in neutral (as you also get a small viscous-coupling effect across the gearbox shaft-to-gears).
fbmbmx
PostPosted: 22:51 - 08 Nov 2010    Post subject: Reply with quote
yey i understood science for once Smile. Thanks for making that clear. Im happy now
Ariel Badger
PostPosted: 23:26 - 08 Nov 2010    Post subject: Reply with quote
However........It could be broken.
PostPosted: 23:36 - 08 Nov 2010    Post subject: Reply with quote
My GSXR would make a sattisfying clunk into first.
The new one does if I'm still moving but it does the same clunk heading into second. At first I was worried about it but she seems to run fine.
Ariel Badger
PostPosted: 23:48 - 08 Nov 2010    Post subject: Reply with quote
Some bikes have a clunk engineered into the design. The new Bonnys from Triumph were deemed to unclunky in development by the focus groups that tested and a retro feel was built into the box.
L4Isoside
I'd say Yamaha's are worse!
The kawak makes quite a clunk too, quite like it actually its "satisfying" Laughing
Bloke
PostPosted: 23:53 - 08 Nov 2010    Post subject: Reply with quote
My yamaha sounds like I used a hammer to change from neutral to 1st. After that it's not so bad.
2008 VFR800 VTEC
ollieholt
PostPosted: 03:06 - 09 Nov 2010    Post subject: Reply with quote
my fazer when cold is like the bolt action on a howitzer! sounds good though in a perverse sort of way, i always try and get the oil at least a bit warm before setting off though lol.
Laughing < This? Well this is just a day brightner.
V2
PostPosted: 07:32 - 09 Nov 2010    Post subject: Reply with quote
If you grease your filanges regularly then it can minimise this clunk, greased filanges ftw!
PostPosted: 07:37 - 09 Nov 2010    Post subject: Reply with quote
I grease my gfs flange as regularly as 3 kids will allow, But not as regularly as I would like. Laughing
Whosthedaddy
PostPosted: 09:51 - 09 Nov 2010    Post subject: Reply with quote
Thats also due to the fact that its a Kwak! My ZX's were really noisy when cold, almost a charm of their nature I suppose. At least you know when its in gear?
The last post was made 15 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 97.51 Kb
