CG125 - Brake pedal adjustment for boots? quietening exhaust
kramdra
PostPosted: 21:42 - 08 Nov 2010    Post subject: CG125 - Brake pedal adjustment for boots? quietening exhaust Reply with quote
Hello,
I got some new boots, but I cant move my foot down like I used to, so its very difficult to use it the rear brake..
I had to move the clutch leaver quite a lot to get my foot under it - rear brake no adjustment...
I could bolt a small piece of aluminium bar to the top, raising it up, but would prefer a proper fix/adjustment...?
My exhaust is also too loud, Im sure its not the standard... but it goes silent if I partly cover the hole... what can I do about it? without buying new
thanks Smile
Mark
PostPosted: 13:11 - 09 Nov 2010    Post subject: Reply with quote
Are you sure about the brake? I thought CG brake pedals were on a spline and could be rotated same as the gearshift. Confused
No idea about the exhaust. Could be the baffles have collapsed, or been drilled out and the end cap replaced. What's the bike's history?
johnsmith222
PostPosted: 13:30 - 09 Nov 2010    Post subject: Reply with quote
On my CG125 I would have to take my foot off the footpeg and stomp down on the rear brake so you should be able to do this also.
If I'm not mistaken, you can't adjust the rear brake pedal position, however if the issue is that you have to push the pedal really far down before it does anything, then there's a nut on a threaded bar that points towards the back of the bike. You can tighten this and this will turn the rear drum brake cam. You need to watch that the rear brake doesn't rub though because you're effectively taking up any slack before the rear brake goes on.
Just take your foot off the peg and stomp on it. Mainly use engine braking, the brakes on the CG are pretty shit at the best of times anyway.
[quote="Rogerborg"]Are you sure about the brake? I thought CG brake pedals were on a spline and could be rotated same as the gearshift./quote]
Possibly on newer models. Not mine though and not the OP's.
Teflon-Mike
tl;dr
PostPosted: 14:16 - 09 Nov 2010    Post subject: Reply with quote
I think this is a posture problem, probably something to do with the brake & clutch levers being so far apart compared to on a car, such that he is struggling to work the clutch with his foot! Shocked Shocked Laughing :wink
Raffles
PostPosted: 15:01 - 09 Nov 2010    Post subject: Reply with quote
Are your new boots MX armoured type?
nowhere.elysium
The Pork Lord
PostPosted: 15:30 - 09 Nov 2010    Post subject: Reply with quote
I'd be more interested in trying to break the boots in.
Wear them around the house for a few days.
PostPosted: 15:49 - 09 Nov 2010    Post subject: Reply with quote
Ah, thanks. I was thinking of the CM125 - it's surprising that the CG isn't adjustable.
kramdra
PostPosted: 23:10 - 09 Nov 2010    Post subject: Reply with quote
your right I just need to wear them in and get used to it.. I dont want to be stomping the pedal,. Today I managed to use it a bit but mostly I forgot...
these are the boots
https://www.phmotorcycles.co.uk/clothing/motorcycle-boots/stivale-gunna-calf-boots
It doesnt help my front brake light switch is bad...but on order! :p
the bike doesnt have much history, but the exhuast is painted matt black probably to hide rust... seemed in ok condition when I took it off sunday.
thanks
Mark
DrDonnyBrago
PostPosted: 13:27 - 10 Nov 2010    Post subject: Reply with quote
these are the boots
thanks
Mark
Wear the boots around the house, do some lunges and get them to soften up. New leather boots are usually a pig to ride in.
The last post was made 15 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 68.62 Kb
