Hi guy's!, I have a mate with a dinosaur of a computer?
Syris the Indomitable
PostPosted: 13:47 - 15 Nov 2010    Post subject: Hi guy's!, I have a mate with a dinosaur of a computer? Reply with quote
Basically he has windows 200o with a 1GHZ processor or something. Internet Explorer 5.5 does not support flash so he can't use Youtube, or stream stuff. ETC
His BIOS won't allow me to boot from USB so I can't install portable Linux.
What I am looking for a hardware friendly, user friendly as poss Linux distro ISO.
I was thinking along the lines of one of those netbook distro’s!
Then I need some free buring software to burn the ISO
I have Vista Premium at home maybe that has some software to allow me to burn ISO's not to sure.
Thanks!
In Greek mythology Ichor is what immortals have in the place of blood
Those that mind, don't matter...Those that matter, don't mind. Do you agree with this?
el_oso
PostPosted: 14:00 - 15 Nov 2010    Post subject: Reply with quote
imgburn is a good freeware utility for burning iso image files.
i have had good experience with puppy linux in the past. linux mint is a good distro for beginners. for older hardware i would suggest using the XFCE desktop as it is a bit lighter on resources
Duke 390
Car: Jeep Wrangler 4.0L
PostPosted: 14:23 - 15 Nov 2010    Post subject: Reply with quote
Cheers, i'll have a look at that.
PostPosted: 16:07 - 15 Nov 2010    Post subject: Reply with quote
LOL, cheers!
Astridax
PostPosted: 00:38 - 16 Nov 2010    Post subject: Reply with quote
Seemed To be a good guide:
https://www.brighthub.com/computing/linux/articles/43541.aspx
Another one to add to that list is dsl (damn small linux). They have a barebones version that is 40MB and will run on a 400 mhz PII processor. It has a event version if firefox that has flash, and its fully customizable like any linux, however the stock window manager flux box, isn't very user friendly, very minimalist. But ofcourse that can be replaced too.
Astridax
Astridax
PostPosted: 00:42 - 16 Nov 2010    Post subject: Reply with quote
Astridax
PostPosted: 00:43 - 16 Nov 2010    Post subject: Reply with quote
FMl, triple posted, why does my phone do this to me?
PostPosted: 02:39 - 16 Nov 2010    Post subject: Reply with quote
Puppy linux will run on 128Mb of RAM (entirely in the RAM and therefore stupidly fast). Older versions will run on 64Mb. They will run on a LOT less with a swap partition but will obviously be slower.
It was purpose designed to run on old computers.
Here is something very handy:
Burn a puppy live CD/Flash drive and run it on your own machine. There is a very clever tool included in puppy that allows you to make a bootable usb drive that pretends it is similtaneously a USB flash drive, a floppy drive and a USB CD ROM. The older machine should recognize it as a FDD and boot from there.
As I recall, you go into the utility and point it at the .iso file you want to be made bootable. I see no reason why it has to be only a puppy .iso file but this may well be the best distro for the limited resources available.
You can also make a bootable floppy disk using a utility called "wakepup" which allows a computer to boot from USB even if this is not allowed in the BIOS. It will boot from the floppy then find and point an older computer to the USB drive that has the puppy .iso file on it.
Astridax
PostPosted: 03:11 - 16 Nov 2010    Post subject: Reply with quote
+1 to all of the above post. An alternative to the above quote: You could get a bootloader such as grub and stick it on a floppy. Our perhaps use ultimate boot cd.
PostPosted: 09:54 - 16 Nov 2010    Post subject: Reply with quote
Cheers stinkwheel, I will download it today, and thanks to Astridax, that look good too.
So Is this like bootcamp in macs, a multi O/S boot loader.
https://www.gnu.org/software/grub/
blurredman
PostPosted: 10:50 - 16 Nov 2010    Post subject: Reply with quote
The last Netscape runs perfectly fine with the latest version of flash with Windows 95. But even 98/2k can go up to IE6, which is relatively widely used by some companies.
But speaking of linux distros, If that's what you want then it's probably best.
PostPosted: 12:05 - 16 Nov 2010    Post subject: Reply with quote
Seamonkey browser would run on win 2000. Very lightweight (it's the one included with puppy).
blurredman
PostPosted: 12:36 - 16 Nov 2010    Post subject: Reply with quote
Doesn't really matter, as long as the machine in question plays Abe's Oddysee, life is complete! Cool
Astridax
PostPosted: 13:13 - 16 Nov 2010    Post subject: Reply with quote
Yes it is like bootcamp, a multi O/s boot loader. It requires some setting up though. Most linux installs will automatically install it to the mbr.
This poses a problem for windows however. If you install windows after linux it will tear through grub. Best way to do it is install windows and then linux. I couldn't get grub to work with win 7 for some bizzare reason. So I had to use the windows multi boot loader and add a reference for the linux partition using easybcd. But hopefully that won't happen to you.
I think the problem with me is that I didn't want grub installed in the mbr, I had a separate boot partition. Windows however didn't like being booted from something not in the mbr. So the windows boot manager in the mbr would boot into windows first. So I edited the boot files for the windows boot loader to bring up a menu to boot windows or point to grub on the linux boot partition.
But again if you install grub to the mbr, that shouldn't happen to you. You should be able to insert a windows reference in the grub config files. Follow this:
https://apcmag.com/the_definitive_dualbooting_guide_linux_vista_and_xp_stepbystep.htm
If you need to boot into mac osx, you may need to look at osx86 project, for the chain loader file. I haven't done that for a while though so it may have changed.
PostPosted: 15:03 - 16 Nov 2010    Post subject: Reply with quote
K.Cheers all! Thumbs Up
The last post was made 15 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.44 Sec - Server Load: 2.51 - MySQL Queries: 13 - Page Size: 100.04 Kb
