please help (rs125 derestriction)
jasepugh1984
PostPosted: 19:12 - 17 Nov 2010    Post subject: please help (rs125 derestriction) Reply with quote
ive got a 2007 rs125 and i wanted to just fit a power valve to it,just wondering what jets i should go for as its still goin to have a cat in the exhaust and also will i still need to fit a br10 spark plug,thanks,
Aprilia Rs125 2007 11kw (SOLD) - Honda CBR600RR 2008 (Current Summer Toy) - Honda Cb600 2000 (Current Work Commuter)
Robby
Dirty Old Man
PostPosted: 20:14 - 17 Nov 2010    Post subject: Reply with quote
Have a look in workshop manual for it, I doubt a change in jetting is necessary to just connect the power valve.
Also, you are unlikely to be fitting a power valve, it should be fitted just not connected to anything. You will probably just need the cables, and maybe the power valve controller.
If there is another restriction in the exhaust then it will need removing.
jasepugh1984
PostPosted: 20:43 - 17 Nov 2010    Post subject: Reply with quote
i would have thought you would need to upjet as its going to be a performance increase to the bike as its still restricted at the mo with a 132 main jet and a vhst 28 carb on it.im sure fully derestricted they have 185 main jets so i was thinking about starting at 150 and goin up
stirlinggaz
PostPosted: 21:22 - 17 Nov 2010    Post subject: Reply with quote
upjetting is a MUST, when adding the pv, as your changing the bike from 15bhp to around 23bhp.(you will gain the remaining 5bhp or so when you remove the cat)
its all in the official aprilia guide, which is available for download,
though your not going to be fully de-restricting it, as to complete the process you will have to change the expansion chamber for one without a cat.
have a look over on 125cc sportsbikes, as i uploaded the guide in the stickies.(if you cant get access to it, pm me as i have it on cd somewhere)
quite why you would want to go through the hassle of fitting the pv without upgrading the exhaust is beyond me, as it will probably be just a case of trial & error & the vhst carb is a bit of an unknown quantity. (as compared to the phbh which has been around for years & pretty much every combination of jets has already been tried)
iirc, others have done the same thing, when doing the de-restriction bit by bit (due to financial rerasons for example)
cheers,
GAZ
Syris the Indomitable
PostPosted: 09:40 - 18 Nov 2010    Post subject: Reply with quote
Yep! CDI needs attention
Exhaust needs attention
Rav Valve and solenoid actuator needs fitting
Carb needs upjetting and mixture screws adjusting.
De-restriction guide for the Euro 3 here.
https://tuul.tl//10722551.pdf
11 KW 132 JET
FULL-POWER JET 185
MIN. JETU3
FULL POWER S45
THROTTLE VALVE 45
FULL POWER 50
MIXTURE SCREW 1-3/4
FULL POWER 2-1/4
To ensure correct operation of
engine, idle should be set to 1200 rpm with engine warm, after accelerating two or three times up to 3000 rpm
Source this lovely forum: https://www.bikechatforums.com/viewtopic.php?p=2145760
In Greek mythology Ichor is what immortals have in the place of blood
Those that mind, don't matter...Those that matter, don't mind. Do you agree with this?
stirlinggaz
PostPosted: 13:05 - 18 Nov 2010    Post subject: Reply with quote
11 KW 132 JET
FULL-POWER JET 185
MIN. JETU3
FULL POWER S45
THROTTLE VALVE 45
FULL POWER 50
MIXTURE SCREW 1-3/4
FULL POWER 2-1/4
ignore the above info, as this is only for FULL de-restriction.
try running with 185 main jet & with the restrictive oem catted exhaust, & it will run like a bag of spanners.(been tryed many time before) Rolling Eyes
cheers,
GAZ
PostPosted: 17:04 - 18 Nov 2010    Post subject: Reply with quote
Ignor above because you can't do one without all the others.
Rebuilt RS's
He will won't have known anything about the 185 main jet if I hadn't have posted it.
jasepugh1984
PostPosted: 18:07 - 18 Nov 2010    Post subject: Reply with quote
so is there no point me just fitting a pv? dont want the bike to run like shit
PostPosted: 08:23 - 19 Nov 2010    Post subject: Reply with quote
Yep, to de-restrict an RS you need to follow the PDF guide.
Personally I would fit the PV soleoid actuator, sort the exhaust out(This is a cut and weldjob ), or buy an Arrows exhaust, sort the CDI out then give the carburettor to a mechanic to up-jet properly, even right down the jet sizes and and screw setting on a piece of paper and hand it in.
When fitted and all back together you may just have to adjust idle speed which is really easy. 100MPH
https://www.pjme.co.uk/
Another way:
More expensive:
Buy a dellorto 34mm carb
powervavle & solenoid
Buy Arrow arrow pipe
pippercross air filter
You acn even buy the some racing reeds!
Last edited by Syris the Indomitable on 08:31 - 19 Nov 2010; edited 2 times in total
stirlinggaz
PostPosted: 13:51 - 19 Nov 2010    Post subject: Reply with quote
Rebuilt RS's
Why would he want to know about the incorrect jet size? Rolling Eyes
i have de-rEstricted about a dozen rs125's & owned 7 or 8.
the best advice you can give him, is to ignore your posts...........as the pdf is not a definitive guide (not like the pre-07 guide) which is well known.
no need to cut & weld spanny or buy arrow, just buy a pre 03 aprilia spanny for 30 quid.
sort the cdi out? you mean drill the hole?
forget giving the vhst carb to a mechanic to upjet, even the aprilia Dealerships cant do it properly.
best thing you have said is buy a vhsb34.
pipercross air filter? aye right, ignore.
cheers,
GAZ
PostPosted: 20:06 - 19 Nov 2010    Post subject: Reply with quote
I don't believe the bible either, but friggin nut wrote it!
The last post was made 15 years, 85 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 78.14 Kb
