DNA 50 WATER TROUBLE
bikerbenny
PostPosted: 19:15 - 21 Nov 2010    Post subject: DNA 50 WATER TROUBLE Reply with quote
let me start by saying i know nothing about bikes , but i have a slight problem
gilera dna 50 , 04 plate
i bought the bike yesterday and noticed that the water bottle was empty , so i filled it up to the top , this morning , same problem NO WATER! , i filled up for the second time in 24 hours , 3 hours later , no water AGAIN! , what could be the problem , i have attached a picture of were the water is leaking
and the temprature gauge is always reading maximum heat lol
connornrg
PostPosted: 19:32 - 21 Nov 2010    Post subject: Re: DNA 50 WATER TROUBLE Reply with quote
you answered ur self!
Bikes (Not Bikes Really Just Shitty Mopeds)
**04 - Piaggio NRG MC3**02 - Yamaha Aerox 50/100**07 - Piaggio NRG Power - Shit.**
bikerbenny
PostPosted: 19:34 - 21 Nov 2010    Post subject: Re: DNA 50 WATER TROUBLE Reply with quote
could it possibly be a head gasket?
Glenben92
PostPosted: 19:58 - 21 Nov 2010    Post subject: Reply with quote
Well you NEVER fill a cooling system with water for a start. you fill it with coolant.
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
bikerbenny
PostPosted: 20:04 - 21 Nov 2010    Post subject: Reply with quote
oh no , told u i dont have a clue! , what would you recomend to do? what could happen now?
bikerbenny
PostPosted: 20:10 - 21 Nov 2010    Post subject: Reply with quote
so antifreeze and water?
P.
PostPosted: 20:18 - 21 Nov 2010    Post subject: Reply with quote
You do when theres a leak...
come to think of it...my supra only has water at the moment... should change that now Laughing
If its leaking, and you can see it. Fix that part?!
bikerbenny
PostPosted: 20:35 - 21 Nov 2010    Post subject: Reply with quote
obviously by the time i have traveled to were im going there is no water left to freeze so for the time being it is ok , so if i can see the leak shud i just try to some how cover were its leaking?
HD
PostPosted: 20:41 - 21 Nov 2010    Post subject: Reply with quote
To a point. But you may need to buy something and fit it instead of just putting a bit of gaffa tape over it Laughing
P.
PostPosted: 20:58 - 21 Nov 2010    Post subject: Reply with quote
If its a pipe, simple buy a new pipe, unless its right on the end of the current one. As long as there is enough left, snip the end, sorted!
If its something say leaking at the radiator.. It could be a new rad needed.
bikerbenny
PostPosted: 21:09 - 21 Nov 2010    Post subject: Reply with quote
cheers paddy , finally a non sarcastic , helpfull reply
could this lead to the bike losing some power?
the coolant bottle is now empty so in the morning if i put water in the bike to get me to work witch is 1.5 mile away , and i can put my life on it that there will be little water in the bottle by the time i get there , then put water in the bike before i head home , would this be ok to do?
it is distilled bottled water by the way? if that makes a difrence
Glenben92
PostPosted: 21:31 - 21 Nov 2010    Post subject: Reply with quote
Nooo, no water. Coolant. Summer and Winter Coolant. It's specifically designed for the job. Protects all the hoses and shit. Available most places that sell any servicing gear i'd imagine
Livefast123
PostPosted: 21:39 - 21 Nov 2010    Post subject: Reply with quote
If it's pissing out whats the point of using coolant Thumbs Up Water will be fine for now until you have fixed the leak. The only problem with water is that it will freeze and possibly crack your head if the temp gets real cold but seeing as it all leaks out that won't be a problem.
What you need to do is fill the bike before you go to work then stop halfway and keep the engine running. Look down into the area you have highlighted and see if you can locate the leak May be easier to use coloured coolant to see. As said if it is a rubber pipe then that would be dead easy to replace.
I'm not that familiar with the DNA 50 but it should have a water pump to circulate the coolant. Sometimes these wear and leak or the gasket leaks. Another possibility is that the water jacket on the head may have a small crack or the headgasket may have gone.
The first priority is to locate the leak. If you have run it at 'maximum heat' then you may have warped the head making the head gasket leak worse,
If you bought it from a garage then get it back there or if you bought it off ebay etc get doing the above Thumbs Up
Current ride - Yamaha MT-07
bikerbenny
could i ride it 1.5 mile with just water then put coolant in? after i have sealed the leak? and by coolant u mean anti freeze right?
cb1rocket
PostPosted: 21:54 - 21 Nov 2010    Post subject: Reply with quote
anti freeze and water or premixed if its so after you have fixed the leak. To be honest your riding the bike with quite a big leak by the sounds of things and it appears to me that unless you get the leak fixed, you risk kissing goodbye to the bike.
bikerbenny
here is the picture of where the leak is coming from..
any help will be much appreciated
cb1rocket
PostPosted: 21:56 - 21 Nov 2010    Post subject: Reply with quote
its not clear but it could well be the gasket has gone under the water pump housing.
Is it actually leaking from that point or dripping from there which is somewhere further up?
bikerbenny
PostPosted: 21:59 - 21 Nov 2010    Post subject: Reply with quote
its dripping from that point?
P.
PostPosted: 22:03 - 21 Nov 2010    Post subject: Reply with quote
Could well be a gasket, could be a crack in a pipe.
What you could do is make a note of what pipes go where on the outside of the engine.
Take off the bike, Lay it out on cardboard, get rubber bungs in the pipes(or use screws/bolts..ive seen it bodged lol!) then fill up without spilling on the cardboard and then look for a wet patch.
That will narrow down where the leak is, if it is outside of the engine.
Not sure how simple it is for you to do this, but its what I did with my cars radiator and piping.
As to the riding 1.5 miles to get coolant, of course you can...water will work just as well for such a short trip, but make sure you ratio it properly.
Also dont get confused... Ive got antifreeze to put in my car tomorrow, its labelled coolant/antifreeze. Ive used stuff just labelled coolant before and went through winter with 0 troubles!
Hope you get it sorted, I know what its like, had the car off the road for a week due to a radiator leak Sad
Livefast123
PostPosted: 22:06 - 21 Nov 2010    Post subject: Reply with quote
Can't really see from the pics but leaking water has a habit of travelling. However from that location I say waterpump seals / gasket are the prime suspect.
Done a google search, see this about pump seals / gasket :-
https://www.scootershack.co.uk/viewtopic.php?f=6&t=6262
Don't ride your liquid cooled ped with no coolant in it or your current problems are going to look minor in comparison!!
cb1rocket
PostPosted: 22:07 - 21 Nov 2010    Post subject: Reply with quote
as above get the bike fully inspected, I don't know how much £££££ you spent on the bike but at that rate you could be left with a bike worth nothing.
Get it sorted or if you don't know what your doing, then get someone who does know or a mechanic.
bikerbenny
PostPosted: 22:15 - 21 Nov 2010    Post subject: Reply with quote
cheers lads , will update tomorow , ill go and see my local bike bloke , see what he says , thermostat and gasket 4.99 on ebay..
dont sound too bad...
cheers..
Livefast123
PostPosted: 22:18 - 21 Nov 2010    Post subject: Reply with quote
Thermostat is not what you need although it wouldn't hurt replacing it.
Depending on what the garage says but i recon it will be the waterpump / gasket / impeller seals.
This - https://cgi.ebay.co.uk/WATER-PUMP-REPAIR-KIT-GILERA-RUNNER-DNA-50cc-WAT5-/130455692493?pt=UK_Motorcycle_Parts&hash=item1e5fc3e4cd
P.
PostPosted: 22:19 - 21 Nov 2010    Post subject: Reply with quote
cheers..
Whoa...thermostat? step back mate, the water pump seals could have gone, the thermostat could be perfect.
If you can, check the water pump, if the seals look like they have seen better days, then replace them. Smile Thumbs Up
Livefast123
PostPosted: 22:21 - 21 Nov 2010    Post subject: Reply with quote
Calm down Thumbs Up Look at my last post then see what the garage say!
The last post was made 15 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 124.81 Kb
