stripping and cleaning carbs
nowhere.elysium
The Pork Lord
PostPosted: 12:44 - 24 Nov 2010    Post subject: stripping and cleaning carbs Reply with quote
This may seem like a foolish question, but can I use white spirits to clean a set of carbs? I'm not sure if it'll damage the rubber components, or anything. Only reason I ask is because I've got some, and I need to get these carbs cleaned out - they've got two decades worth of muck in them.
Cheers in advance.
Raffles
PostPosted: 13:40 - 24 Nov 2010    Post subject: Reply with quote
Why not simply use petrol to clean them?
PostPosted: 14:08 - 24 Nov 2010    Post subject: Reply with quote
Cleaning is what women are for.
By which I mean: borrow their nail varnish remover.
nowhere.elysium
The Pork Lord
PostPosted: 16:13 - 24 Nov 2010    Post subject: Reply with quote
Had considered it, but it'll make my living room stink of petrol even more than usual. Actually, I'm trying to find a problem with that, but I can't. Sod it - Petrol it is Very Happy
The Artist
PostPosted: 16:32 - 24 Nov 2010    Post subject: Reply with quote
If you want to properly clean it you need carb cleaner.
Petrol will help a bit with physical cleaning but if you think about it, they are full of petrol all the time and that is the problem...
Petrol will do ok but it isn't brilliant at cleaning gummed up carbs.
Lynxx
PostPosted: 18:18 - 24 Nov 2010    Post subject: cleaning Reply with quote
buy a can of that carb cleaner (not the airsole) and leave them to soak if they are really bad, in an hour or 2 if its good cleaner it will have removed all the white or yellow crud. if its just a matter of dirt use petrol or carb cleaner in a can and some air from a air compressor, works best anyways.
The last post was made 15 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 48.15 Kb
