Handlebar Muffs
Mark65
PostPosted: 15:29 - 25 Nov 2010    Post subject: Handlebar Muffs Reply with quote
Well its that time again, as its frigin chilly in the mornings i have decided to try these out as it seems my fingertips are my weak point in the cold, so has any one tried the new version of the oxford muffs , the bone dry ones, are they any better or just the same design as the older ones?
thanks
Mark
craigT19
Jolly Green Giant
PostPosted: 16:02 - 25 Nov 2010    Post subject: Reply with quote
there the same as the old ones, pretty easy to fit, you just gotta cut a hole in them for the mirrors.
I fit a pair to my other halfs DT125 last winter and they worked well, didnt sag when wet or get caught in the levers... even when she crashed they held there shape after.
For the best results i found.
1. Remove your missors
2. put them over the bars and do up the poppers
3. Get them into possition making sure the levers dont fowl up
4. Feel where the mirror hole is and cut a small "X" in the fabric using a stanley knife blade (hole no more than 6mm across)
5. Slide the 2 leather washers over your missors and poke the mirrors through the holes and screm them into your threads.
6. Slide the leather washers onto the muffs and use super glue to slick them to the muffs but not the mirrors.
Done!! the super glue seals the hole and stops it expanding so it stays water proof and doesnt get bigger, ive tried al kinds of stuff to glue the washers on but tbh super glue always seemed to work best.
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
hellkat
PostPosted: 16:03 - 25 Nov 2010    Post subject: Reply with quote
Are they not for pussies?
DrDonnyBrago
PostPosted: 16:32 - 25 Nov 2010    Post subject: Reply with quote
No, they are for hands Wink .
Mark65
PostPosted: 17:31 - 25 Nov 2010    Post subject: Reply with quote
rofl Laughing Laughing Laughing Laughing craigT19 thank you
mr.kris
PostPosted: 17:38 - 25 Nov 2010    Post subject: Reply with quote
salty21 has a set on his super 4 they work mega well and he has combined them with heated grips for even better heat i finaly have a reson for walking around holding hands with him!!!!!
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
Imonster
PostPosted: 19:14 - 25 Nov 2010    Post subject: Reply with quote
Buy Tucano Urbano one's rather than go through the faff of doing this - they already have the holes there, and well fitting rubber grommets for either large or small bar weights.
Not slagging off the tip, it works and I did it for years before coming across the TU's. But I'm lazy, and also nice to be able to transfer the muffs from bike to bike without an issue.
Those who make peaceful revolution impossible will make violent revolution inevitable.
PostPosted: 21:03 - 25 Nov 2010    Post subject: Re: Handlebar Muffs Reply with quote
thanks
Mark
I'll sell you mine..reason. on both bikes ive ridden with them.. they dont keep me warm.
They keep me dry..but not warm. Ive tried fitting various ways.. and STILL I have freezing cold hands. Also a bit of hard riding pushed the right hand one against the front brake.. arse clench moment..
Mark65
PostPosted: 22:19 - 25 Nov 2010    Post subject: Re: Handlebar Muffs Reply with quote
##Paddy## wrote:
thanks
Mark
Doesnt sound good, my current winter gloves are 2x spada leather waterproof ones its only the past couple days its been really cold ive felt it, but i think i may be bad in the new year so its try these or try the lobster gloves, the tucanos are out of my price range really and on my ybr i dont think i run the risk of the wind lol, not sure which way to go.
Thanks for the input.
Mark
The Artist
PostPosted: 22:39 - 25 Nov 2010    Post subject: Reply with quote
I have some of these.
https://cgi.ebay.co.uk/MOTORCYCLE-BIKER-THERMAL-HANDLEBAR-BAR-MUFFS-WATERPROOF-/220577996812?pt=UK_Motorcycle_Parts&hash=item335b79200c#ht_620wt_905
Not brilliant but when it is cold, would definitely ride with them than without. Does push on front brake over 55.
Heated grips coming in the next 2 weeks so the combo should be good for the icyness. Probably be over by then knowing our weather.
neil.
PostPosted: 22:42 - 25 Nov 2010    Post subject: Reply with quote
I have used them for the last couple of years. They are much better than nothing at all but after 30-45 minutes of riding on a day like today (coldest this year from what I remember), my fingertips were a bit cold/tingly. However, my whole hands would normally be in agony/numbness/unable to move if I didn't have them. Paired with heated grips and it was fantastic, alas one of my grips broke so this winter I'm just using the muffs, but grips alone were useless as they only heated up my palms and not the bits of my hands that bore the brunt of the wind. They look big and stupid on a 125 but I don't care, they really are essential IMO. Wind chill is the culprit for killing your hands in winter and in my opinion, muffs are the best defence against it. Just takes getting used to the controls with them on but it's really not that much of an adjustment - you'll nail it after 5 minutes of riding.
hellkat
PostPosted: 23:47 - 25 Nov 2010    Post subject: Reply with quote
Truth be known, I'm always just a little bit frit that if I fall off, my hands will get stuck inside 'em.
I have ridden with them, had to ride the ex's bike home once with them on, most peculiar. But I expect once you get used to them, they help if you do long distances (which I don't).
defblade
PostPosted: 14:15 - 26 Nov 2010    Post subject: Reply with quote
When I fitted old style oxford ones to my old bike, I also ended up cutting a small hole for the bar-end weight bolts, and screwing those through the muff too (only big enough for the bolts, so the muffs were trapped/held between the weights and the grips). That kept the front end out not pushing on the levers, and also kept the hand-hole round - I found it tended to flatten itself shut otherwise, and I had to look what I was doing to get my hand back in.
PostPosted: 14:28 - 26 Nov 2010    Post subject: Re: Handlebar Muffs Reply with quote
Then sounds like you had crappy ones Smile.
Tucano Urbano are the ones to go for, as mentioned - they don't push back are tighter and have a nice furry bit around the entrance to the muff.... so in answer to Hellkat's comment... all in all, a muff a man would want to be inside Razz.
Yes, I've got my coat already!
PostPosted: 14:56 - 26 Nov 2010    Post subject: Re: Handlebar Muffs Reply with quote
Oxford bone dry one Question
TheDonUK
PostPosted: 16:24 - 26 Nov 2010    Post subject: Reply with quote
As said the Tucano Urbano ones are the best commercial ones, i have the old style large furry ones with the rubber grommets, have worked on all manor of bike over the years from innova/cg/ybr 125's to gs500/er5's to bandit/hornet/er6's.
The new neoprene ones are smaller and less likely to beep your horn accidentally when on left lock, some guys at work have the new style ones, but i see their envious eyes on a cold night Razz. If you are riding all night in these temps the muffs are a must.
PostPosted: 16:56 - 26 Nov 2010    Post subject: Reply with quote
I thought the new style ones you're talking about for scooters and the old style ones for bigger bikes?
Somewhere there's lists of which each is suitable for.
Paddy - I've got a set of Oxford ones. Pretty poor. Had to make guards to keep off the levers and they really need to be used in combination with heated grips - at which point they do work pretty well (heated grips along and the outside of my hands get cold I find.)
TheDonUK
PostPosted: 01:15 - 27 Nov 2010    Post subject: Reply with quote
my old style ones fit on the smaller handlebars of a innova...
PostPosted: 01:56 - 27 Nov 2010    Post subject: Reply with quote
I hope the Tucano Urbano muffs are good...Just ordered some. I was unable to indicate as i lost my thumb. [Brrrr]
Model Guide:
Aprilia Caponord 361
Aprilia Falco 361
Aprilia Futura 361
Aprilia Habana 360
Aprilia Leonardo 125/150/250 361
Aprilia Pegaso 650 361
Aprilia Rally 360
Aprilia RS 361
Aprilia Rsv1000 361
Aprilia RXV 360
Aprilia Scarabeo 125/150/200 360
Aprilia Scarabeo 250/400/500 361
Aprilia Scarabeo 50/100 360
Aprilia SI 750 Shiver 361
Aprilia Sonic 50 / GP50 360
Aprilia Sportcity 360
Aprilia SR (all models) 360
Aprilia Tuono 1000 361
Benelli 491 st/rr 360
Benelli Adiva 360
Benelli K2 50/100 360
Benelli Naked 50 360
Benelli Pepe 360
Benelli Tornado 361
Benelli Tre 361
Benelli Tre-K 361
Benelli Velvet 125/150/250 360
Betamotor Ark 361
Betamotor Eikon 50 /125/150 361
Betamotor Euro 350 361
BMW C1 125/200 360
BMW F 650 GS 360
BMW F 800 361
BMW F 800 GS 361
BMW G 650 Xcountry 361
BMW G 650 Xchallege 361
BMW G 650 Xmoto 360
BMW HP2 360
BMW K 100 361
BMW K 1200 GT 361
BMW K 1200 LT 360
BMW K 1200 R 361
BMW K 1200 RS 360
BMW K 1200 S 361
BMW K 75 360
BMW R 100 GS 360
BMW R 100 RS 360
BMW R 1100 GS 361
BMW R 1100 R 361
BMW R 1100 S 361
BMW R 1150 GS 361
BMW R 1150 R 361
BMW R 1150 RS 361
BMW R 1150 RT 361
BMW R 1200 C 361
BMW R 1200 CL 361
BMW R 1200 GS -without the plastic hand shield 323 361
BMW R 1200 R 361
BMW R 1200 RT 361
BMW R 1200 S 361
BMW R 1200 ST 361
BMW R 65 360
BMW R 80 GS 361
BMW R 80 R 360
BMW R 850 R 361
Buell Firebolt 361
Buell Lighting 360
Cagiva Navigator 361
Cagiva Raptor 361
Dadomotors DD 360
Daelim Cordi 360
Daelim Message II / Tapo 360
Daelim Otello / NS 125 361
Daelim S2 125/250 361
Derbi Atlantis 360
Derbi Gp1 361
Ducati 999 361
Ducati Monster 360
Ducati Multistrada 361
Ducati ST2/ST4 361
Garelli Capri 360
Garelli Ciclone 360
Garelli Confort/King 360
Gilera Fuoco 361
Gilera GP800 361
Gilera Nexus (from 2006) 361
Gilera Nexus (till 2005) 361
Gilera Runner 50/200 360
MBK Ovetto 50/100 360
Gilera Stalker 360
MBK Skycruiser 361
Harley all models 360
MBK Skyliner 125/150/250 361
Honda @ 125/150 ES 360
MBK Thunder 125 361
Honda Bali 360
Honda CB500/1300 361
Honda CBF with windshield 361
Honda CBF-N without windshield, with mirrors 361
Honda CBR 361
Honda CN 250 360
Honda Deauville 361
Honda Dylan 360
Honda Foresight 360
Honda Forza 361
Honda Goldwing 361
Honda Hornet 361
Honda Jazz 361
Honda Lead 360
Honda Metro 360
Honda NX 250 360
Honda Pan european 361
Honda Pantheon 125/150 360
Honda Pantheon 125/150 (from 2003) 360
Honda PS 360
Honda SH 300 361
Honda SH 50 old 360
Honda SH 50/100/125/150 m.y.'05-'06 360
Honda Shadow 360
Honda Silverwing 361
Honda SKY 50 360
Honda Swing 361
Honda S-Wing 125/150 361
Honda Transalp 360
Honda Varadero 361
Honda VFR 361
Honda VTR 361
Honda Zoomer 360
Italjet Jet-Set 150 361
Italjet Juppiter 250 361
Italjet Torpedo 50/125/150 360
Kawasaki ER-6F 361
Kawasaki Er-6n 361
Kawasaki Kle 361
Kawasaki KLE 500* 360
Kawasaki Versys 361
Kawasaki VN 360
Kawasaki Z 750/1000 361
Kawasaki ZR7 361
Kawasaki ZX-R 361
Kawasaki ZZ-ZX 361
Keeway Arn 125 360
Keeway F-act 360
Keeway Hurricane 360
Keeway Outlook 360
KTM 950 Supermoto/ enduro 361
KTM 990 Superduke 361
KTM Adventure 360
KTM LC4 360
KTM Supermoto 361
Kymco Agility 360
Kymco Bet & win 50/150/250 361
Kymco Classic 200 361
Kymco Dink / Spacer 50/125/150 361
Kymco Dink 50/125/200 (2006) 361
Kymco Gran Dink 250 361
Kymco Movie 125/150 360
Kymco People 50/125/150/250 360
Kymco People S 361
Kymco Vitality 360
Kymco Xciting 250/300/500 361
Kymco Xciting 500 (till 2006) 361
Kymco Yup 250 361
Kymco ZX 360
Linhai Eggy 360
Linhai Main Street 361
Linhai Monarch 361
Linhai Prince 50 360
Malaguti Centro 361
Malaguti Ciak 50/100/125/150 361
Malaguti F10 360
Malaguti F12 360
Malaguti F15 360
Malaguti Madison 125/150/180/250/400 361
Malaguti Madison 3 361
Malaguti Password 250 360
Malaguti Phantom max 360
Malaguti Spidermax 500 361
MBK Booster 50/100 360
MBK Doodo 125/150 360
MBK Flipper 360
MBK Kilibre 361
MBK Mach 50 360
MBK Skycruiser 361
MBK Thunder 125 361
Moto Guzzi Breva 361
Moto Guzzi California/Bellaggio 360
Moto Guzzi Griso 361
Moto Guzzi Nevada 361
Moto Guzzi Norge 361
Moto Guzzi Stone 361
Moto Guzzi V11 361
Moto Guzzi V65 360
Mv Brutale 361
Peugeot Elyseo 50/100/125/150 360
Peugeot Elystar 125/150 361
Peugeot Geopolis 361
Peugeot Jet force 360
Peugeot Looxor 50/100 360
Peugeot Ludix 360
Peugeot Satelis 361
Peugeot SV 250 360
Peugeot V-click 360
Peugeot Vivacity 50/100 360
Peugeot X-fight (Race) 50/100 360
Piaggio Beverly 125/200/250/400/500 361
Piaggio Beverly Cruiser 361
Piaggio Carnaby 125/200 361
Piaggio Fly 50/150 360
Piaggio Hexagon 125/180/250 360
Piaggio Liberty 50/125/150/200 360
Piaggio MP3 361
Piaggio Nrg
Piaggio Skipper ST 125/150 361
Piaggio Typhoon 360
Piaggio Vespa ET2/ET4 360
Piaggio Vespa GT/GTS 361
Piaggio Vespa LX 360
Piaggio Vespa PK/PX 360
Piaggio X7 361
Piaggio X8 361
Piaggio X9 125/150/250/500 (evol.) 361
Piaggio Xevo 361
Piaggio Zip 50/125 360
Polaris Scrambler 360
Suzuki Bandit 361
Suzuki Bandit S 361
Suzuki Burgman 125/150/200 361
Suzuki Burgman 250/400/K7 361
Suzuki Burgman 400 2006 361
Suzuki Burgman 650 361
Suzuki DL650 361
Suzuki Freewind 361
Suzuki GS 500 361
Suzuki GS 500 F 361
Suzuki GSF-S 361
Suzuki GSR 361
Suzuki GSX-R 361
Suzuki GSX-R GSX-F 361
Suzuki Intruder 360
Suzuki Sixteen 361
Suzuki SV650/1000 361
Suzuki SV650/1000S 361
Suzuki TU250X 361
Suzuki V-Strom 361
Sym DD 360
Sym Hd 200 361
Sym Joiride 125 360
Sym Joymax 361
Sym Mio 100 360
Sym Voyager 250 361
Sym VS 361
Triumph Bonneville 360
Triumph Daytona 361
Triumph Rocket III 360
Triumph Speed 361
Triumph Sprint 361
Triumph Tiger 361
Yamaha Aerox 360
Yamaha BT 1100 Bulldog 361
Yamaha Cygnus (from 2004) 360
Yamaha Cygnus (till 2003) 360
Yamaha Diversion 361
Yamaha Dragstar 360
Yamaha Fazer 361
Yamaha FJ 1200 '97 361
Yamaha FJR 1300 361
Yamaha Fz1 / Fz6 361
Yamaha Jog 360
Yamaha Majesty 125/150 361
Yamaha Majesty 250 361
Yamaha Majesty 400 361
Yamaha Maxter 125 361
Yamaha Midnight star 360
Yamaha MT01 / MT03 361
Yamaha Neo’s 50/100 360
Yamaha Xjr 361
Yamaha X-Max 361
Yamaha Xt 361
Yamaha Yzf 361
Yamaha R6/R1 361
Yamaha TDM 361
Yamaha T-Max 361
Yamaha Tricker 360
Yamaha Versity XC 300 361
Yamaha Vino 125 360
Yamaha Why 360
Yamaha X-City 250 361
Pat
Nai
PostPosted: 11:14 - 27 Nov 2010    Post subject: Reply with quote
That also bothers me. I can swallow the pride and fit them to the Rieju even if they look dorky, but I do flap over them... Hampering my ability to control the bike and if I fall off, what HK said.
PostPosted: 11:19 - 27 Nov 2010    Post subject: Reply with quote
I've crashed with them on (only at slow speed) and been fine - there's no real impediment for your hand coming out.
It takes longer to get used to it going in - generally I'm fine and could do it first time, but when I took both hands out at once, the results weren't amazing trying to get them both back in at the same time (not going that fast either, so slight moment of panic as the bike started to wobble!)
Doovy
PostPosted: 13:43 - 27 Nov 2010    Post subject: Reply with quote
+1 for the Tucano Urbano muffs
https://i2.photobucket.com/albums/y41/doovydoo/utf-8BSU1HLTIwMTAxMTE3LTAwMDE1LmpwZw.jpg
On my hornet. sh*t aerial picture i know. lol.
Nai
PostPosted: 15:14 - 27 Nov 2010    Post subject: Reply with quote
Ok, I am sold on them. I know i can get bar ends for my bike so I will try what was said a few posts up to stop them pressing on my brakes and clutch. Are muffs a universal fit or do I have to buy bike specific ones?
Edit :
As it goes, anyone here do a 40 mile of filtering a day in them? Do they effect your filtering ability at all?
neil.
PostPosted: 15:33 - 27 Nov 2010    Post subject: Reply with quote
Edit :
I filter for 10 or so miles per day out of a 30 mile commute. Not noticed any difference, apart from it being a pain to get my hand out to wave 'thanks' to drivers who move over etc.
tutton
PostPosted: 19:12 - 27 Nov 2010    Post subject: Reply with quote
I have a set of Tucano Urbanos for sale, ive never got around to fitting them to the zx6
The last post was made 15 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.23 Sec - Server Load: 0.66 - MySQL Queries: 15 - Page Size: 142.63 Kb
