| c_dug |
 c_dug Super Spammer
| Gone |
 Gone Nearly there...
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 17:30 - 26 Nov 2010 Post subject: |
make sure you drain all the oil and drain the filter. If you overfill it it could shear your chuff nut and cause all sorts of problems ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| c_dug |
 c_dug Super Spammer
Well thats two totally contradicting answers  ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| Gone |
 Posted: 17:33 - 26 Nov 2010 Post subject: |
One answer will cause you untold grief, the other is the path to fulfillment and biking nirvana...but it's your choice  |
| c_dug |
 c_dug Super Spammer
 Posted: 17:40 - 26 Nov 2010 Post subject: |
I'm a lazy broke bastard. I will go for the leave it option for the time being.
It's too bloody cold outside to be draining all the oil out  ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| Gone |
| tvr321 |
 tvr321 Nitrous Nuisance
 Posted: 19:03 - 26 Nov 2010 Post subject: |
A tiny bit over and it will burn it off no problem.
Mattsprattuk was joking  |
| woll |
 woll World Chat Champion
 Posted: 19:12 - 26 Nov 2010 Post subject: |
a mm is nothing, the full marks are only a rough guide. Even if there is too much then it'll either get burnt up or go out through the engine breather. ____________________ Current Bike- Suzuki DRZ400 SM K6
Damaged spleen, damaged kindey, 2 popped lungs, 2 broken ribs, broken face, broken wrist and 5 back fractures... remember kids walls hurt |
| HD |
 HD World Chat Champion
| c_dug |
 c_dug Super Spammer
 Posted: 19:39 - 26 Nov 2010 Post subject: |
Not sure what other hole you mean is but some bikes have a little bolt that you can remove that is at the exact hight the oil should sit, so when the oil comes out of the hole you know for sure it is at the right level.
If you mean it was coming out of the filler hole then it is way to much, even I can tell you that  ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| Howling TerrorOutOfOffice |
| HD |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 20:23 - 26 Nov 2010 Post subject: |
Start the bike up and rev it with the dipstick left out. You'll soon transfer the excess oil to the surrounding area. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| Glenben92 |
 Glenben92 Nearly there...
 Posted: 20:50 - 26 Nov 2010 Post subject: |
I overfilled by a mm or two last time, it won't do any harm, but being the obsessive fucker that i am, i took a mcdonalds straw and syphoned the excess out. a tiny bit over will be fine unless you've got mental issues like me  ____________________ 57 Huoniao HN125-8 - , 97 Kawasaki GPZ500S -
99 Yamaha FZS 600 -
Mod 2 Passed - 01/10/2010 |
| dragstaar |
 dragstaar World Chat Champion
| Walloper |
 Walloper Super Spammer
| Paxovasa |
 Paxovasa World Chat Champion
| dragstaar |
 Posted: 22:33 - 27 Nov 2010 Post subject: |
| Walloper wrote: |
Rubbish...
The loss of the Power Band is only temporary.
Soon as the excess 25ml of engine oil is used up the Power Band operates perfectly normal.
It is worrying at first though.  |
lulz i was being sarcastic.
Although i did replace my snapped power band with a cheaper one from WHsmiths. I got 100 of them for £4.00! |
| c_dug |
 c_dug Super Spammer
 Posted: 00:59 - 28 Nov 2010 Post subject: |
Bike seems way harder to start when cold that it did before I topped it up and gears seem clunky.
Maybe I should empty some out  ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| tutton |
 tutton World Chat Champion
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 02:13 - 28 Nov 2010 Post subject: |
you can fill it way past the fill level with no bad results,
the whole "you'll get excessively high oil pressure"
is a absolute bunch of shit, the oil pump decides how much oil to pump, it can't pump more oil because the level is higher, it will pump the same amount,
any excess oil will eventually be pumped out of the breather at the top of the rocker cover.
consider your selves educated  ____________________ the humans are dead
I kick arse for the lord
| MaybeGuy |
 Posted: 02:21 - 28 Nov 2010 Post subject: |
| hmmmnz wrote: | you can fill it way past the fill level with no bad results,
consider your selves educated  |
so the crank foaming the oil would have no detrimental effects whatsoever?
and i believe you missed the point of that post...
consider yourself educated ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| hmmmnz |
| dragstaar |
 Posted: 19:46 - 28 Nov 2010 Post subject: |
Fight! Fight! Fight! Fight! Fight! Fight!  |
The last post was made 15 years, 215 days ago. Instead of replying here, would creating a new thread be more useful? |
