Faulty Indicators?
LiamBob
PostPosted: 09:56 - 27 Nov 2010    Post subject: Faulty Indicators? Reply with quote
Right my indicators are fine when I'm stationary with the engine turned off they function left and right fine. as soon as I start my engine and or rev it they go crazy (when they are set either left or right) they vary in pulse or just totally spaz out this worsens with vibration!
would this be possibly a faulty relay?
or maybe a loose wire somewhere?!
any input is greatly appreciated!
HD
PostPosted: 10:56 - 27 Nov 2010    Post subject: Reply with quote
Try to eliminate your cost-free causes first. So strip the wiring back and make new connections if need be. If its not that then look at your earths. If its not that then you can try a new relay.
Failing that I have no idea Laughing
Good luck Thumbs Up
don't ask me about earths
finpos
PostPosted: 11:15 - 27 Nov 2010    Post subject: Reply with quote
Find the regulator on the bike, unplug it, then test the indicators again.
f.
Ichy
PostPosted: 12:32 - 27 Nov 2010    Post subject: Reply with quote
What bike?
Does it make any difference if the headlight is turned on?
Does it affect the front, rear and any telltale that may be fitted?
Can you hear the relay clicking? Do the clicks match the flash rate?
What do you mean by 'spaz out'?
LiamBob
PostPosted: 20:07 - 27 Nov 2010    Post subject: Reply with quote
right thanks for the help guys. i think its the cold weather its been -5 the past 2-3 days and my bike gets left out over night (i work nights)
the relay is indeed faulty Sad
HD
PostPosted: 20:09 - 27 Nov 2010    Post subject: Reply with quote
Fit a new one then.
Raffles
PostPosted: 20:38 - 27 Nov 2010    Post subject: Reply with quote
What makes you think that the relay is knackered? If it works OK when the engine is stationary why would it ''spaz out'' when the engine is running? Me thinks that it is more likely to be an overcharging issue.
BTW you still haven't revealed the make and model of bike. I'm guessing something cheap and Chinese.
robocog
PostPosted: 20:56 - 27 Nov 2010    Post subject: Reply with quote
AC on the line would do that
(assuming its only going mad when engine is physically running)
Mine did that when I went batteryless - turns out the battery is an important part of turning AC into DC on my bike...LOL
Turns out the indicator realy gets really quite confused when fed with AC rather than DC
More symptoms mine showed...
Headlight got so bright when you rev it that it looks like its going to blow and went as dim as a dim thing with low rpm?
Could be reg/rectifier (or connections to and from it) gone bad
(I am assuming battery is OK and connected otherwise the indicators wouldn't work with engine off)
If you have a multimeter it may be worth checking the battery voltage with eng off and running
(also seeing if putting multimeter to AC and doing the same shows anything interesting)
Regards
Rob
Needs a bigger garage...
The last post was made 15 years, 222 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 54.36 Kb
