CBR600F6 Replacement engine issues
But.It.Was.A.Bargain.Luv
PostPosted: 20:31 - 27 Nov 2010    Post subject: CBR600F6 Replacement engine issues Reply with quote
https://www.youtube.com/watch?v=wHM12h_EQ94
Hi chaps,
Managed to ruin my 06 engine (46k) but got another one for £400 with 12k on it.
That said, since fitting I've got a few issues which are below and on the vid. Any ideas appreciated.
Cheers peeps
Paul
As per video desc.
A replacement engine with 12k on it. After fitting, its sluggish low down in the rev ranges, and will sometimes idle high or low to the point it stops. Can smell fuel but checked obvious hoses. Coils are new this year off the old engine as are the plugs. Battery was 12.4v so I'm topping it up at the moment. Any ideas and thoughts appreciated!
PostPosted: 20:52 - 27 Nov 2010    Post subject: Reply with quote
Have you set the carbs back to stock and balanced them?
That and the fact theres no airbox on there?
DrDonnyBrago
PostPosted: 20:57 - 27 Nov 2010    Post subject: Reply with quote
It's FI paddy ^.
Who fitted the engine for you? I'd check that all of the throttle body rubbers are on properly. Does it do the same thing with the airbox and filter and ram air ducts in?
i know you have no air filter in at the moment, but are you using the standard filter and standard exhaust system?
PostPosted: 21:03 - 27 Nov 2010    Post subject: Reply with quote
DonnyBrago wrote:
It's FI paddy ^.
Karma Thumbs Up
Looked the same as my old 89 FZR from the top minus the airbox, thats why I queried the carbs Laughing
That aside then what he said ^^ Check its all seated properly. Have you checked all the plugs are still ok? You said they came from your old engine that died?
PostPosted: 21:24 - 27 Nov 2010    Post subject: Reply with quote
DonnyBrago wrote:
It's FI paddy ^.
Garage fitted - not Honda.
Yep does the same thing with it all on.
I put the stock exhaust back on, just to see, and did make power delivery a little smoother.
It's still very sluggish and slow to respond low down in the rev range though. Once it's over 4-5k it's fine, but the throttle response is slow and sluggish below that.
Cheers
Paul
Paddy Blake
PostPosted: 22:30 - 27 Nov 2010    Post subject: Reply with quote
Are you sure the new engine is the same year and used the same cdi/ecu.
Paddy Blake
PostPosted: 22:47 - 27 Nov 2010    Post subject: Reply with quote
I was going to say check the shims gap but 1st service for them is 16k
I think.
Maybe there is more than 12k on it.
The last post was made 15 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 51.24 Kb
