Cooling System (CAR)
Martay
PostPosted: 22:11 - 30 Nov 2010    Post subject: Cooling System (CAR) Reply with quote
Hi,
Hope you dont mind me asking about the car but...
My car overheated on saturday, and when i stopped, the radiator was stone cold. Ive just changed the thermostat.
To do so, i had to partially drain the coolant. When i changed the thermostat and put everything back together, i refilled the coolant bottle.
Problem now is the engine temperature is still climbing, the radiator and heater is stone cold, as are the pipes.
Im assuming this is caused by air in the system? Theres no bleed valve on the radiator or bottle?
Anything else i can try?
Ta
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
2Smoke
PostPosted: 22:21 - 30 Nov 2010    Post subject: Reply with quote
There should be a bleed valve somewhere in the system. Have a good look. Otherwise I have heard of a method of bleeding air out where you top up the header tank, leave the cap off, run the engine until hot and air bubbles escape out of the tank.
Does your waterpump still work? If that fails then I guess most of the radiator will stay cold..
Paul
Livefast123
PostPosted: 22:55 - 30 Nov 2010    Post subject: Reply with quote
Sound like either you have a major air lock, the temperature guage sensor is faulty or the impeller on your water pump has failed meaning that no water is being circulated. The bleed valve may be on the surrounding pipework and may be a bolt in a metal pipe or a car tyre valve type thing in the rubber pipework.
First check does the engine actually get hot and does the fan come on. This will rule out electrical problems.
I would then take the bottom hose off the radiator and drain all the coolant. Then turn the heater on to maximum and start the engine. Fill the expansion tank slowly to avoid bubbles until you have filled to the coolant capacity and water runs without bubbles from the bleed valve. That way you can almost eliminate air locks as long as you found the bleed valve.
Finally if that doesn't work then I would say your waterpump is FUBAR. Pump normally costs 25 - 30 for a good one and i'm not sure but if it's run from the cambelt then a new cambelt kit will be needed.
Current ride - Yamaha MT-07
Martay
PostPosted: 23:05 - 30 Nov 2010    Post subject: Reply with quote
Thanks for the advice. Ive had a look around a Ford OC forum, and there is no bleed valve in the system. According to the haynes manual, you remove the expansion bottle cap, and run the engine. I have done this several times to no avail
Il try dumping all the coolant out, and refilling slowly. I have a water pump and cambelt kit here, as i was planning on getting the belt done before i had to spend on this.
Is there any way i can check the pump?
Thanks
fiery tupp
PostPosted: 23:28 - 30 Nov 2010    Post subject: Reply with quote
Did you check the themostat worked before fitting it even new ones are sometimes faulty ? heres how you might get more answers here . https://www.ehow.com/how_2189728_test-cooling-system-thermostat.html
If you can't fix it with a hammer , use your head .
Livefast123
PostPosted: 23:32 - 30 Nov 2010    Post subject: Reply with quote
Lol internet forums are a godsend, I always use them to fix my vehicles.
There should be a return pipe to the expansion tank, when the engine is up to temp then coolant should flow through this back into the tank if the pump is working properly.
Some pumps have plastic impellers and break up over time
fiery tupp
PostPosted: 23:33 - 30 Nov 2010    Post subject: Reply with quote
And this may help . https://www.ehow.com/how_7679_tell-cars-water.html
Livefast123
PostPosted: 23:34 - 30 Nov 2010    Post subject: Reply with quote
You did put the new thermostat in the right way?? Thumbs Up
Acemastr
PostPosted: 23:43 - 30 Nov 2010    Post subject: Reply with quote
I'd personally say that you have no anti freeze in the coolant.
2016 Toyota Tacoma Limited
Martay
PostPosted: 23:55 - 30 Nov 2010    Post subject: Reply with quote
Hi,
Thanks for the help.
Il check to see if the pump is working. The coolant did have anti freeze in it, light green tint and tasted sweet.
I didnt check the new stat, but ive still got the old one, so il have a play to see it its works. If it does it would indicte something else wrong? Yes, i put it in the right way Smile
Ta
Suntan Sid
PostPosted: 08:49 - 01 Dec 2010    Post subject: Reply with quote
THIS Thumbs Up
ORourke
PostPosted: 10:59 - 01 Dec 2010    Post subject: Reply with quote
Martay wrote:
Hi,
Ta
Correct - test the old one in a bowl of boiled water. If it opens, the problem will be somewhere else.
I take it the car is a Ford - I've had lots and lots, and I don't think that an airlock would be a very likely cause - especially since the problem started before you drained any of the coolant.
The whole system is very simple, so if the old thermostat tests fine, you should start looking at the water pump - that being the only other component that would create a lack of coolant circulation.
I don't know what car you have - so your water pump may or may not be hidden somewhere - if it's accessibly:
A lot of water pumps have a small hole through which coolant drips/flows if the pump bearings or impeller aren't working. So check for any leaks at the pump, and check (with the car started and warm) whether the hoses to and from the pump are hot. If they aren't that would be a definite sign that no water is circulating.
Have you heard any odd sounds from the car recently - I had a pump fail on a Sierra, is sounded just like a slipping belt - even the garage said the belt was slipping- turns out the bearings were on the way out.
PostPosted: 13:16 - 01 Dec 2010    Post subject: Reply with quote
Most coolant is antifreeze also... atleast most of them contain the same non freezing substance.
My supra overheated (hole in radiator.) Installed new radiator, whole system was empty.
Toyota manual says to do the following.
Take of the RADIATOR cap, sod the little coolant tank and fill the radiator with WATER.
Then start the car and put heaters on full heat and blowing on the actual fans, not the windscreen heater. Turn off the aircon..no need.
Keep filling the radiator until the bubbles stop coming out (thats an air lock being forced out)
After you are satisfied its working properly... drop the water and redo with the antifreeze (i only dropped 2L of water out of my radiator as ive got coolant concentrate mixes 33/67 with the water... do yours however you wish anyway..)
Then re-run the engine, lets it all mix and you are done.
Took me 20 mins tops, and my car like i said has been perfect since!
I did this and my car has been 100% perfect since.
Robby
Dirty Old Man
PostPosted: 18:51 - 01 Dec 2010    Post subject: Reply with quote
Someone on here had a similar problem on an old escort when it got cold last winter. The problem in the end was a weak coolant mixture, which was taking on the consistency of a slush puppy at about 2 degrees below freezing. The water pump snapped off its impeller blades trying to pump this.
I know that a lot of car traders and general idiots tried to claim that ford coolant was sealed for life a few years ago, one of told me that when I bought a 10 year old escort. If previous owners have believed this and your car is a few years old, it could well be the problem.
New water pump, flush the cooling system (if it's old enough to be that weak, it's old enough to sludge up) and refill with pink (5 year) coolant. Cost about a quid more than the blue (2 year) stuff. Make it up strong, I go 50/50. Peace of mind can now be achieved.
Acemastr
PostPosted: 19:51 - 01 Dec 2010    Post subject: Reply with quote
Pink stuff is for cars younger than 98 and blue is for cars older than 98, got some blue stuff the other day
PostPosted: 19:58 - 01 Dec 2010    Post subject: Reply with quote
My car is 94.. and has blue..
My bike is also 89...and has it.
Martay
PostPosted: 20:03 - 01 Dec 2010    Post subject: Reply with quote
Thanks for the advice, its all a great help Smile
Ive just got in from work, and tested the old thermostat in a pan of water. It opened before the water boiled :'(
This means my little problem just got alot more expensive!!
Next step i fear is the water pump. Does anyone know if the pump on a mk4 fiesta (zetec engine) is cambelt or aux belt driven?
Ta
Walloper
PostPosted: 20:09 - 01 Dec 2010    Post subject: Reply with quote
You check water pump flow by loosening a hose clip and slackening the hose till you get a CONSTANT DRIP of coolant from the opening you create.
Start the engine and watch to see if the CONSTANT DRIP changes to a POUR or faster drip.
This indicates that there is flow.
Any pump only creates flow.
The slushy anti-freeze is a good point.
Fill with a pre-mixed solution or fill with 50% antifreeze and 50% water mix.
If there is no bleeding point on the engine That is a point some place higher or as high as the top surface of the cylinder head.
Then the engine is of a type where bleeding is not required as any trapped air will be purged as the system is SLOWLY filled.
But helping the fill by squeezing the hoses can help push any stubborn air out.
Run the engine with tank lid off to get all air out.
Bikeless
PostPosted: 21:20 - 01 Dec 2010    Post subject: Reply with quote
Water pump is driven by the aux belt,if your car has the HCV behind the firewall,sometimes these can stick half shut and half closed and cause overheating probs.
cagiva gezzer
PostPosted: 22:33 - 01 Dec 2010    Post subject: Reply with quote
Friend has Zetec 1.25 Fiesta. Lovely car, but at random it always decided to overheat.
Would overheat, pull over, cool down and work fine for another week or so.
She took it to a Ford dealer and they removed the thermostat. It now runs cold / rich all the time but doesn't overheat.
Billing
PostPosted: 22:36 - 01 Dec 2010    Post subject: Reply with quote
Seeing as you have the water pump already change it, as I said the symptoms are sudden and have come about right as the super cold weather was here, so I'd hazard a guess at a busted water pump, when I turned what we think is the w/p drive pulley I couldn't feel any resistance at all, which to me rings alarm bells Thumbs Up
Edit: Btw guys, its a 1.25 Zetec unit
Walloper
PostPosted: 22:38 - 01 Dec 2010    Post subject: Reply with quote
That is an amateur fix which is super counter productive.
There are still cowboys in the maintenance business even in dealer workshops.
It will kill that engine early doors.
It is called fixing a symptom but ignoring the cause.
ORourke
PostPosted: 09:37 - 02 Dec 2010    Post subject: Reply with quote
I'd concur - if you have a pump - test the old one and if neccesary change it and see what happens. I bought one of my Sierras two days before a very harsh freeze, and hadn't checked the anti-freeze. The coolant had hardly any anti-freeze and the pump broke up trying to circulate half frozen water.
When I put the new pump in - there was a surprising amount of resistance to turn, so you might be onto something.
Walloper
PostPosted: 09:49 - 02 Dec 2010    Post subject: Reply with quote
Yeah... Change a water pump for no reason.. Embarassed
Tesdt for flow before you do the change.
Acemastr
PostPosted: 12:05 - 02 Dec 2010    Post subject: Reply with quote
That's what i said Confused
The last post was made 15 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 133.46 Kb
