| Martay |
 Martay World Chat Champion
 Posted: 22:11 - 30 Nov 2010 Post subject: Cooling System (CAR) |
Hi,
Hope you dont mind me asking about the car but...
My car overheated on saturday, and when i stopped, the radiator was stone cold. Ive just changed the thermostat.
To do so, i had to partially drain the coolant. When i changed the thermostat and put everything back together, i refilled the coolant bottle.
Problem now is the engine temperature is still climbing, the radiator and heater is stone cold, as are the pipes.
Im assuming this is caused by air in the system? Theres no bleed valve on the radiator or bottle?
Anything else i can try?
Ta ____________________ Eat well, poo hard
Drives: Cavalier 2.0 16v
Rides: Slightly ratted Honda City Express  |
| 2Smoke |
 2Smoke Crazy Courier
| Livefast123 |
 Livefast123 Nearly there...
| Martay |
 Posted: 23:05 - 30 Nov 2010 Post subject: |
Thanks for the advice. Ive had a look around a Ford OC forum, and there is no bleed valve in the system. According to the haynes manual, you remove the expansion bottle cap, and run the engine. I have done this several times to no avail
Il try dumping all the coolant out, and refilling slowly. I have a water pump and cambelt kit here, as i was planning on getting the belt done before i had to spend on this.
Is there any way i can check the pump?
Thanks ____________________ Eat well, poo hard
| fiery tupp |
 fiery tupp Trackday Trickster
| Livefast123 |
| fiery tupp |
| Livefast123 |
 Posted: 23:34 - 30 Nov 2010 Post subject: |
You did put the new thermostat in the right way??  ____________________ Current ride - Yamaha MT-07 |
| Acemastr |
 Acemastr World Chat Champion
| Martay |
 Posted: 23:55 - 30 Nov 2010 Post subject: |
Hi,
Thanks for the help.
Il check to see if the pump is working. The coolant did have anti freeze in it, light green tint and tasted sweet.
I didnt check the new stat, but ive still got the old one, so il have a play to see it its works. If it does it would indicte something else wrong? Yes, i put it in the right way
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 08:49 - 01 Dec 2010 Post subject: |
| Livefast123 wrote: |
You did put the new thermostat in the right way??  |
THIS  |
| ORourke |
 ORourke Two Stroke Sniffer
 Posted: 10:59 - 01 Dec 2010 Post subject: |
| Martay wrote: | Hi,
Ta |
Correct - test the old one in a bowl of boiled water. If it opens, the problem will be somewhere else.
I take it the car is a Ford - I've had lots and lots, and I don't think that an airlock would be a very likely cause - especially since the problem started before you drained any of the coolant.
The whole system is very simple, so if the old thermostat tests fine, you should start looking at the water pump - that being the only other component that would create a lack of coolant circulation.
I don't know what car you have - so your water pump may or may not be hidden somewhere - if it's accessibly:
A lot of water pumps have a small hole through which coolant drips/flows if the pump bearings or impeller aren't working. So check for any leaks at the pump, and check (with the car started and warm) whether the hoses to and from the pump are hot. If they aren't that would be a definite sign that no water is circulating.
Have you heard any odd sounds from the car recently - I had a pump fail on a Sierra, is sounded just like a slipping belt - even the garage said the belt was slipping- turns out the bearings were on the way out. |
| P.addy |
 P.addy Red Rocket
| Robby |
 Robby Dirty Old Man
| Acemastr |
| P.addy |
 P.addy Red Rocket
| Martay |
 Posted: 20:03 - 01 Dec 2010 Post subject: |
Thanks for the advice, its all a great help
Ive just got in from work, and tested the old thermostat in a pan of water. It opened before the water boiled :'(
This means my little problem just got alot more expensive!!
Next step i fear is the water pump. Does anyone know if the pump on a mk4 fiesta (zetec engine) is cambelt or aux belt driven?
| Walloper |
 Walloper Super Spammer
| Bikeless |
 Bikeless World Chat Champion
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| Billing |
 Billing World Chat Champion
 Posted: 22:36 - 01 Dec 2010 Post subject: |
Seeing as you have the water pump already change it, as I said the symptoms are sudden and have come about right as the super cold weather was here, so I'd hazard a guess at a busted water pump, when I turned what we think is the w/p drive pulley I couldn't feel any resistance at all, which to me rings alarm bells
Edit: Btw guys, its a 1.25 Zetec unit ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
BCF Eastern members map here ---> g.co/maps/2tm8b PM me to be added to it! |
| Walloper |
| ORourke |
| Walloper |
 Posted: 09:49 - 02 Dec 2010 Post subject: |
Yeah... Change a water pump for no reason..
Tesdt for flow before you do the change. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| Acemastr |
The last post was made 15 years, 335 days ago. Instead of replying here, would creating a new thread be more useful? |
