Adding spotlights to a 125 ... is it worth it?
huskie69
PostPosted: 20:52 - 01 Dec 2010    Post subject: Adding spotlights to a 125 ... is it worth it? Reply with quote
Hi All
I've been riding a Skyjet 125 (Chinese jobby) for a month now and I'm not very happy with the output from the full beam headlight. I'm not sure but I think it's rated at 35W (it's not the original as that blew a few months back). It's really pitiful and I can't see more than a few metres in front of me. I need something a bit more substantial and I used to have a pair of spotlights on my car which were perfect.
I was wondering if it an acceptable modification to the bike in terms of electrical load - I'm thinking a 110W pair. Would the battery/alternator take it? I've read that people have used relays, other people have said the loads just too much and others have said wait until they their big bike - this isn't an option for me at the moment and it'll be summer before I can consider getting my big bike.
Has anyone done this before on a 125?
TIA
huskie69
PostPosted: 20:59 - 01 Dec 2010    Post subject: Reply with quote
As a side note - if the mods (as in mods vs rockers!) could add 20 spotlights to their Lambrettas back in the 60s, surely it'll be a piece of piss to do this 50 years later!
truslack
PostPosted: 21:01 - 01 Dec 2010    Post subject: Reply with quote
Not worth it unless you ran them total loss with a pair of batteries in panniers - which makes handling on ice "fun"
truslack
PostPosted: 21:05 - 01 Dec 2010    Post subject: Reply with quote
I think they do H3 HID "Bulbs" with ballasts at 30/35w - one of those could be useful with some fresh wires and a relay.
Martay
I added some LED spot lights to my 125, wired to the highbeam. Helped, but still not fantastic.
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
PostPosted: 21:32 - 01 Dec 2010    Post subject: Re: Adding spotlights to a 125 ... is it worth it? Reply with quote
I'd start with a better standard light - maybe see if you can get the unit from a modern (good) naked bike?
Maybe add in a 55w HID and your bike should still power it ok, but have vastly better useful light output.
Raffles
PostPosted: 22:18 - 01 Dec 2010    Post subject: Reply with quote
Lambrettas and Vespas weren't made in China Laughing
PostPosted: 22:21 - 01 Dec 2010    Post subject: Reply with quote
Agreed, I wouldn't fancy your chances of having 110W spare, but you should be able to get a decent bulb in there.
35W stock Chinese glow-worm BA20D
https://2.bp.blogspot.com/__DYtEEjm5wE/SdPeCERUCgI/AAAAAAAAACY/Hi0Y4oAPCyA/s320/dim_lights.jpg
50W 7500K bulb
https://3.bp.blogspot.com/__DYtEEjm5wE/SdPeFoQbyVI/AAAAAAAAACg/jF32MofLYcU/s320/bright_lights.jpg
hmmmnz
yeah i'd go the hid route, i ordered a set for a bmw r1200gs for $50 nz including postage to here, from this dude postage took about a week from chinky land, but the product was good,
just find out what lamps you have in the bike, make sure you get hi/low ones if you have a dual filament bulb in your bike
the humans are dead
I kick arse for the lord
Raffles
PostPosted: 23:21 - 01 Dec 2010    Post subject: Reply with quote
Rogerborg wrote:
Agreed, I wouldn't fancy your chances of having 1100W spare
Fixed for ya Wink
huskie69
PostPosted: 23:45 - 01 Dec 2010    Post subject: Reply with quote
50W 7500K bulb
That's a nice improvement! I have a single headlight, dual filament setup - does the BA20D bulb have another name (H3, H4, H7, H11 etc)? Did you also replace the bulb fitting as and was this difficult?
I take it this isn't HID but just a standard bulb too?
dragstaar
PostPosted: 00:22 - 02 Dec 2010    Post subject: Reply with quote
HIDs are the way to go man! I got some recently, and they are absolutely amazing.
You know that pothole that you didn't see in the night and did your rim and spinal discs on? well you'll see it with HIDs. Seriously, night driving is such a pleasure with them
Arrow HID conversion kits are ILLEGAL. I did my research. I'll try and find the link on Direct Gov. However, if you want legal HIDs then you'll have to get the whole headlight unit.
Conversion kits are a cheap alternative, but just make sure you get a non-blue colour temp, so 4300K is perfect, and adjust your beam so it doesn't dazzle and you'll be fine
PostPosted: 00:23 - 02 Dec 2010    Post subject: Reply with quote
Well, I know it's not H3, but I don't know if it's equivalent to any of the others. I just mentioned BA20D because that's what's in my bike - I have no idea what's in your Skyjet. Best check and see.
No fitting replacement, it was just a bulb replacement. It was sold as a 7500K (that's colour temperature) 'Xenon' bulb, 50W/50W. Looks like this:
https://www.scootmotoshop.com/prod/472798G.jpg
The only curiosity was that the dipped and main beam filaments were inverted. The bulb is 'handed'; it can only go in one way, so the wiring must actually be different. I just swapped the terminals over where they joined the loom, problem solved.
huskie69
PostPosted: 00:33 - 02 Dec 2010    Post subject: Reply with quote
My Skyjet also takes a dual filament BA20D so this is exactly what I'm after - don't think I can justify the outlay on an HID conversion and its not worth the risk if they're not even legal in the uk (never mind the fact that they probably make night driving a lot safer!).
Any chance you'd be able to tell me where you got your bulb from - I've googled the arse out of 50W dual filament BA20Ds but not having much luck.
dragstaar
PostPosted: 00:38 - 02 Dec 2010    Post subject: Reply with quote
Whatever bulb you get, remember this.
anything up to 4300K get brighter as you go up (4300K being the brightest), anything beyone 4300k will be dimmer but bluer. so really 7000K will be dimmer than 4300K
Teflon-Mike
tl;dr
PostPosted: 00:40 - 02 Dec 2010    Post subject: Reply with quote
Twenty years ago, My AR125 was nicked and came back a bit worse for wear. As it was cheaper to buy an after-market fairing than replace the smashed original, and the head-lamp had gobe awol, I bought a power-bronze twin-beam fairing for it.
https://i178.photobucket.com/albums/w269/teflons-torque/00_genral/BIKE_024.jpg
Twin 50/55w Cibies. State of the art lighting at the time...... flattened the battery entirely, withing about two miles!
110w 'Spare', you'll be lucky to have 110w TOTAL!
A headlamp wattage upgrade will be the way to go, but you wont really be able to go much more than 10-20w over standard, becouse of the heat, and the load on the generator. I also wouldn't trust the Shainghai noodles connecting the bulb to battery either, and would either re-wire using decent grade wiring, and or relay the new lamp.
There are upgrade conversion kits for the more curiouse bulb fittings, when you find one that will go into your head-lamp shell, I advice you order two spare bulbs, over the conversion bulb and adaptor.
When your mucking about, almost garanteed you'll pop it or drop it, or fry it, so you want a spare for that. Then you want a real spare on shelf or carefully wrapped up and under teh seat for if ever the one in the lamp blows, becouse you know you'll not get either standard or upgrade quickly or easily.
I've been trying to convince standard car head-lamp bulbs into old CB125 headlamps recently, and if you have a little inginuity and dexterity, it CAN be done, giving the advantage of a cheaper and more available bulb.
Last thought, on the CB125, I've also LED's all the other lamps to take load onff the generator for the upgraded head-lamp. Expensive doing thjem all, but saves a remarkeable number of watts!
There was more power being sucked in the dash-lights than the tail-light for instance!
PostPosted: 02:53 - 02 Dec 2010    Post subject: Reply with quote
Dammit, me neither. I got it from this eBay seller but he doesn't have them in stock at the moment.
Googling "7500k ba20d" leads back to this thread. Rolling Eyes
I'll keep looking and see if I can turn anything up - I'll need a replacement myself sooner or later.
Teflon-Mike
tl;dr
PostPosted: 20:08 - 02 Dec 2010    Post subject: Reply with quote
That's why I said buy three, when you first upgrade!
huskie69
PostPosted: 20:32 - 02 Dec 2010    Post subject: Reply with quote
@rogerborg
I was gonna hassle this guy: https://bikeinabox.blogspot.com
The garage door looks kinda familiar, as does the jacket! Nice blogging btw Smile
huskie69
PostPosted: 21:13 - 02 Dec 2010    Post subject: Reply with quote
Ahah - think I might have found some - take a gander at these:
https://cgi.ebay.co.uk/270667113215
Coming from China so will have to wait a bit but they're 50/55w, seem to be dual filament and cheap enough that I've got 3. If they're decent enough then I'll be happy knowing I haven't blown my wad on a pricey HID conversion Smile
Now to pimp my Chinese bitch (with LEDs)
hmmmnz
PostPosted: 00:13 - 03 Dec 2010    Post subject: Reply with quote
id still go the hid option, they are just plug and play, so when you get your next bike, take them with you, you don't have to alter your loom at all,
and you get 2 sets so sell the other set to a mate or get a set as spare,
the humans are dead
PostPosted: 00:19 - 03 Dec 2010    Post subject: Reply with quote
If I was buying bulbs, I'd go for a decent make personally.
Note that the bulbs can easily be just as 'illegal' as HID - as they are not original kit.
The last post was made 15 years, 131 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.01 - MySQL Queries: 13 - Page Size: 128.11 Kb
