| huskie69 |
 huskie69 Spanner Monkey
| huskie69 |
| truslack |
 truslack World Chat Champion
| N cee thirty |
 N cee thirty Banned
 Posted: 21:02 - 01 Dec 2010 Post subject: |
hmm well i'd say stick with it,as the chinese wires will fry under anymore load
what about a big torch ?  ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| truslack |
| Martay |
 Martay World Chat Champion
 Posted: 21:05 - 01 Dec 2010 Post subject: |
I added some LED spot lights to my 125, wired to the highbeam. Helped, but still not fantastic. ____________________ Eat well, poo hard
Drives: Cavalier 2.0 16v
Rides: Slightly ratted Honda City Express  |
| G |
 G The Voice of Reason
| Raffles |
 Raffles World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 22:21 - 01 Dec 2010 Post subject: |
| hmmmnz |
 hmmmnz Super Spammer
yeah i'd go the hid route, i ordered a set for a bmw r1200gs for $50 nz including postage to here, from this dude postage took about a week from chinky land, but the product was good,
just find out what lamps you have in the bike, make sure you get hi/low ones if you have a dual filament bulb in your bike ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| Raffles |
| huskie69 |
| dragstaar |
 dragstaar World Chat Champion
 Posted: 00:22 - 02 Dec 2010 Post subject: |
HIDs are the way to go man! I got some recently, and they are absolutely amazing.
You know that pothole that you didn't see in the night and did your rim and spinal discs on? well you'll see it with HIDs. Seriously, night driving is such a pleasure with them
HID conversion kits are ILLEGAL. I did my research. I'll try and find the link on Direct Gov. However, if you want legal HIDs then you'll have to get the whole headlight unit.
Conversion kits are a cheap alternative, but just make sure you get a non-blue colour temp, so 4300K is perfect, and adjust your beam so it doesn't dazzle and you'll be fine |
| Rogerborg |
 Rogerborg nimbA
 Posted: 00:23 - 02 Dec 2010 Post subject: |
Well, I know it's not H3, but I don't know if it's equivalent to any of the others. I just mentioned BA20D because that's what's in my bike - I have no idea what's in your Skyjet. Best check and see.
No fitting replacement, it was just a bulb replacement. It was sold as a 7500K (that's colour temperature) 'Xenon' bulb, 50W/50W. Looks like this:
https://www.scootmotoshop.com/prod/472798G.jpg
The only curiosity was that the dipped and main beam filaments were inverted. The bulb is 'handed'; it can only go in one way, so the wiring must actually be different. I just swapped the terminals over where they joined the loom, problem solved. |
| huskie69 |
| dragstaar |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 00:40 - 02 Dec 2010 Post subject: |
Twenty years ago, My AR125 was nicked and came back a bit worse for wear. As it was cheaper to buy an after-market fairing than replace the smashed original, and the head-lamp had gobe awol, I bought a power-bronze twin-beam fairing for it.
https://i178.photobucket.com/albums/w269/teflons-torque/00_genral/BIKE_024.jpg
Twin 50/55w Cibies. State of the art lighting at the time...... flattened the battery entirely, withing about two miles!
110w 'Spare', you'll be lucky to have 110w TOTAL!
A headlamp wattage upgrade will be the way to go, but you wont really be able to go much more than 10-20w over standard, becouse of the heat, and the load on the generator. I also wouldn't trust the Shainghai noodles connecting the bulb to battery either, and would either re-wire using decent grade wiring, and or relay the new lamp.
There are upgrade conversion kits for the more curiouse bulb fittings, when you find one that will go into your head-lamp shell, I advice you order two spare bulbs, over the conversion bulb and adaptor.
When your mucking about, almost garanteed you'll pop it or drop it, or fry it, so you want a spare for that. Then you want a real spare on shelf or carefully wrapped up and under teh seat for if ever the one in the lamp blows, becouse you know you'll not get either standard or upgrade quickly or easily.
I've been trying to convince standard car head-lamp bulbs into old CB125 headlamps recently, and if you have a little inginuity and dexterity, it CAN be done, giving the advantage of a cheaper and more available bulb.
Last thought, on the CB125, I've also LED's all the other lamps to take load onff the generator for the upgraded head-lamp. Expensive doing thjem all, but saves a remarkeable number of watts!
There was more power being sucked in the dash-lights than the tail-light for instance! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Rogerborg |
 Rogerborg nimbA
| Teflon-Mike |
 Teflon-Mike tl;dr
| huskie69 |
 Posted: 20:32 - 02 Dec 2010 Post subject: |
@rogerborg
I was gonna hassle this guy: https://bikeinabox.blogspot.com
The garage door looks kinda familiar, as does the jacket! Nice blogging btw  |
| huskie69 |
| hmmmnz |
| G |
The last post was made 15 years, 135 days ago. Instead of replying here, would creating a new thread be more useful? |
