ignition working but seams doddgy
broomy12
PostPosted: 01:13 - 30 Jul 2004    Post subject: ignition working but seams doddgy Reply with quote
well i thought we was on this kinda subject i dunno if its right or not. i got a ns125r and i can take the keys out when the bike is turned on and it stays on is my ignition all messed up and in need of a new one cuz i ant come across that before. write back asap as im tired but waiting for my dad to get home from the pub. he forgot his key the nob head
broomy12
PostPosted: 20:33 - 01 Aug 2004    Post subject: Reply with quote
anyone can help. anyone?
Guest
PostPosted: 20:49 - 01 Aug 2004    Post subject: Reply with quote
Get a piece of string, thread it through the key and then tie it into a loop. Next time your dad goes to the pub, slip it over his head as he goes out the door.
It's normal, when you switch off and take the key out, for the engine to stop. It's a security sort of thing.
If your bike keeps running and you've got the key in your hand then it sounds like the ignition switch is Kerry Packered. About £28 from M & P
PostPosted: 20:50 - 01 Aug 2004    Post subject: Reply with quote
Dude, you are giving me a headache with your typing. You may be dyslexic but you used some full-stops, so why not the capital letters after them? A few more punctuation marks would not go amiss too.Wink
Not exactly clear what you are talking about. Do you mean that you can pull the key out with the ignition switch in the 'on' position? Or, do you mean that when you switch the ignition off and remove the key, the engine keeps running?
Both are possible but would have a different cause.
PostPosted: 22:40 - 01 Aug 2004    Post subject: Reply with quote
Earth wire not connected to the ignition switch, probably.
broomy12
PostPosted: 10:55 - 02 Aug 2004    Post subject: Reply with quote
OK, ok. Yes. It still runs when i take the keys out when the ignition is on.
PostPosted: 13:32 - 02 Aug 2004    Post subject: Reply with quote
Ok, some bikes allow you to do that to avoid the key-fob scratching the yokes, but I think in your case, someone has screwdrivered the ignition lock at some point. Can you turn the ignition with a different key or a screwdriver? If so, someone has stolen the bike at some point and forced the ignition, you need a new ignition barrel.
broomy12
PostPosted: 14:09 - 02 Aug 2004    Post subject: Reply with quote
No. Only one key will turn it on. I think i may just get a hole new ignition barrel. Thanks for your help.
PostPosted: 23:26 - 02 Aug 2004    Post subject: Reply with quote
Which it will do on many bikes if the earth wire to the ignition switch is broken / disconnected. That wire is used to ground the ignition coil out to kill the spark and so stop the engine.
The last post was made 22 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 60.03 Kb
