Cushion Drive Rubbers
draigrwf
PostPosted: 16:40 - 04 Dec 2010    Post subject: Cushion Drive Rubbers Reply with quote
Has anybody changed these on the jinlun 250-5
Been told there is 4 of these on the rear wheel stripped wheel down but cant see any
Tols to look at these as when i change gear bike wobbles
cheers
Philious
PostPosted: 17:32 - 04 Dec 2010    Post subject: Re: Cushion Drive Rubbers Reply with quote
cheers
Aren't these normally mounted behind the sprocket on the rear wheel?
Previously; Honda XR125 - Yamaha DT125r - Aprilia Rs125 - Suzuki GS500e, Currently; Kawasaki ZX6R + ZX10R
Theory : Passed 28/7/09 Module 1: Passed 21/09/09 Module 2: Passed 23/09/09
Damon
PostPosted: 18:31 - 04 Dec 2010    Post subject: Reply with quote
they are under here
https://t0.gstatic.com/images?q=tbn:ANd9GcTD48IN3NabDSpAvN-Xa4GlyMEhbFMqau26gHXxF-I1wHtgVKz1
the sprocket will just pop out Thumbs Up
Teflon-Mike
tl;dr
PostPosted: 18:41 - 04 Dec 2010    Post subject: Reply with quote
Damon wrote:
Often there's a big circlip around the hub to stop them working out of thier own accord. Might not pull straight off.
Honda also liked to use metalastic bushes, press fitted into the wheel-hub, engaged by pins bolting direct to the sproket, rather than loose-bricks in a propper carrier, on thier little bikes. Dont know if any of the Copies have carried this over. If they have, then they are a nightmare to get out.
draigrwf
PostPosted: 18:50 - 04 Dec 2010    Post subject: Reply with quote
this is how my wheel looks like after taking off the sproket
[img][/img]
Damon
PostPosted: 18:53 - 04 Dec 2010    Post subject: Reply with quote
put the sprocket back on and pull it (might need a wiggle). Looks like the sprocket carrier is still on.
If that doesn't work, then as mike says there might be a cir clip holding it in place
draigrwf
PostPosted: 19:27 - 04 Dec 2010    Post subject: Reply with quote
Thanks will try tomorrow
Teflon-Mike
tl;dr
PostPosted: 19:57 - 04 Dec 2010    Post subject: Reply with quote
Your pic's not great, but looks like the old metalastic bush arrangement.
https://i178.photobucket.com/albums/w269/teflons-torque/XX-Forum%20Posts/hub.jpg
The four holes that the sproket bolts slot into are the cush-drive rubbers.
A = is the inner sleeve
B = is the outser sleeve
C = is the bush-rubber.
Its all one part, the two sleeves bonded to the rubber when the rubber was moulded.
FKD! = an anomoly in your picture I suspect to be FKD rubber!
This is NOT repeat NOT an 'easy fix'.
Those bushes dont like to come out. They are 'shrunk' into the wheel.
(well not on normal bikes, built with normal quality control, least wise! Chinky-takaway, micght just fall out, if you tip the wheel upside down! would also be poor quality rubber thats seen them fail so early, normaly that would be a 20 year part, though learner numptyness plays a part too, and a slack chain doesn't help!)
They are also not 'cheap'. For a Honda CB125 Super-Dream, List price at Dave-Silver-Spares is about £10 a bush, ie: £40 a set, though I suspect there is more than a small degree of 'Catalogue Part' price inflation going on there.... they want £32 for a £3 fuecking flasher unit!
Your problem will be that you probably wont find any-one that lists the part for your bike, at any price; which means trying to find a suitable susbstitute from dimensions & description.
Which would be great, if you could get the part out intact and measure it up, and describe it..... but of its properlyt fitted, you'll probably have to cut it out.... carefully!
So, first things first, measre up the pin that goes in teh middle, and then the depth of the inner bush.
Then attack it with a drill through teh rubber, to remove the inner sleeve.
Outer will have to be split in four places by using a small traingular file to file slots into it, without going too far and hacking up the allow of the wheel.
You can then measure the diameter of the hole in te wheel. You can then measure the diameter of the sproket pin to get the internal and external diameters of teh bush, and the width of the outer sellev (how deep it is into the wheel) and the length of the inner sleeve, to get the basic dimensions of the bush, so that you can describe it calling around motorfactors and bush and nearing stickists looking for a suitable, and more reasonably priced substitute. (Should be about a fiver each, tops)
Once procured you just have the problem of fitting them........
Heat whole wheel, carefully, bushes in freezer, then carefully press them into the holes with a g-clamp and a socket bearing on the outer sleeve so you dont pull the inner out of the rubber!
A used wheel of e-bay, or even a brand new one, may not be much more expensive and certainly less hassle, but..... new, and decent european metalastics will make a big difference to your gear-changes, as will decent chain & sproket. You'll have to adjust them less too.
There are 'bodges', and the cheap fix is to go for a 'solid' drive, with no cush-drive bushes...... simply get the old bushes out, then turn a set of solid plugs with holes in them to fit the bush-holes....
Thats the nicest of the cheap-fixes, BTW.... getting down and dirty, some nylon rod can be filed into a satisfactory plug, hammered in and drilled to take the procket pins.... but I am NOT advocating such bodgery in any way shape or form, nor the more bodge-wrorthy alternative of simply filling the holes with epoxy resin, then sticking the sproket over the top and drilling out a hole to take the srprocket pin... such bodgery is not cheap, it isn't clever, and it wont last!
draigrwf
PostPosted: 20:36 - 04 Dec 2010    Post subject: Reply with quote
thanks teflon-mike
my wheel is as youve shown
these is what been advertised on most sites
[img][/img]
Teflon-Mike
tl;dr
PostPosted: 23:19 - 04 Dec 2010    Post subject: Reply with quote
Jup, thats the more usual 'brick' type cush rubber that goes into a paddle type 'split-hub' cush drive.
PostPosted: 23:59 - 04 Dec 2010    Post subject: Reply with quote
LLexter very clearly wrote:
Sample images are to show a representation of the part only, actual items may differ between models
Just give LLExeter / CMPO a call, or send them a picture of your wheel - they're pretty good at matching parts.
draigrwf
PostPosted: 12:31 - 05 Dec 2010    Post subject: Reply with quote
Thanks all
Very helpfull
cheers
PostPosted: 13:39 - 05 Dec 2010    Post subject: Reply with quote
Mind you. I wouldn't have expected worn cush-rubbers to make the whole bike wobble.
They'd make the sprocket loose and wobbly but the back wheel itself should be held rigidly in place on its bearings
I'd be having a careful look at the wheel bearings. Being chinese, I'd also be checking the spacer is butting against the inner races properly.
Actually, being Chinese I'd also be checking there is no play in the swingarm bushes, that the swingarm itself isn't cracked, that the frame isn't cracked and that there isn't a broken engine mount.
Mate of mine had a Jailing trailie thing that was handling "funny". Back engine mount was broken and the frame was cracked through where the lug for the engine mount was welded on (which came first??).
Clean the bike up round the frame and swingarm area and have a good look round the frame using an inspection light, paying particular attention to where anything joins the frame and any welds. They have a habit (as did the Japanese at one point) of only welding the frame together where you can see.
Damon
PostPosted: 14:27 - 05 Dec 2010    Post subject: Reply with quote
Shocked
The last post was made 15 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 88.84 Kb
