Alpine stereo into Ford KA?
PostPosted: 22:43 - 06 Dec 2010    Post subject: Alpine stereo into Ford KA? Reply with quote
Help me here as the last time I fitted a car stereo was in arusty mk2 escort about 20 yrs ago.
I have an Alpine stereo (CDE-9850-Ri), which I want to fit into a 2001 Ford KA. The Alpine has a connector in the back with a bunch of wires all cut off and it has the colour codes on a sticker.
The vehicle wiring is unmolested with 2 multi-plugs and an aerial plug dangling in the hole.
I can find leads that are called Alpine to ISO, but not Alpine to Ford and the ISO ends aren't going to fit the car going by the pics.
I want to just plug the stereo into the car loom, what do I need?
Ariel Badger
PostPosted: 22:50 - 06 Dec 2010    Post subject: Reply with quote
Multi meter, soldering iron, shrink wrap and a bit of time. I had this problem fitting my Pioneer system into the van.
ian789
PostPosted: 22:57 - 06 Dec 2010    Post subject: Reply with quote
https://homepages.tesco.net/~esoteric/ka-audmods.htm
It seems you'll need to source a ISO to ford adapter.
This one might be it https://www.dvbcaraudio.co.uk/connects-ct20fd01-ford-harness-adapter-free-delivery-p-4455.html?osCsid=df8c29b22bdb1b731068404897a65812
Then it should be plug and play with your unit.
ian789
PostPosted: 23:01 - 06 Dec 2010    Post subject: Reply with quote
You may also need an adapter for the aerial if it wasn't included with the head unit.
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_176311_langId_-1_categoryId_165626
PostPosted: 23:43 - 06 Dec 2010    Post subject: Reply with quote
Right so I need two patch leads and an aerial adaptor? No wonder I couldn't find a patch lead. Looks like I better get shopping...
Wali - if it were my own car I'd chop up the loom and get out the soldering iron but I don't want to butcher the wiring on my daughter's 1st car.
PostPosted: 00:05 - 07 Dec 2010    Post subject: Reply with quote
Some are so simple its nuts, the VW Lupo I did.. slot straight in, no issues at all Cool
My supra... on the other hand, was like solving a rubiks cube with no fingers, whilst blind and under the influence Laughing
Solved by Ariels wise choice Wink
Robby
Dirty Old Man
PostPosted: 00:35 - 07 Dec 2010    Post subject: Reply with quote
You could try to use a couple of connectors, but you shouldn't need to.
You have a plug and wires on the back of the alpine stereo, so if you can get a ford - ISO adapter and chop off the ISO plugs then you can solder it up to the alpine plug. Wire colours will probably differ, but you'll find a manual on t'internet which will give the wiring colours fairly easily.
You may have more wires at one end than you need - things like a wire to operate an electric aerial, which you don't need and can remove if you don't have an electric aerial.
PostPosted: 13:48 - 07 Dec 2010    Post subject: Reply with quote
How old is the stereo? Not many normal ones recently (last 10 years) which haven't had the ISO plugs on the back, or just a lead from some proprietary connector to an ISO plug. Check to see if the wires go under a cover into a standard ISO connector.
Ford connectors are pretty common and so cheap. Hence buy one and chop it up (used a Ford one chopped up to put an ISO stereo into a 1990 car which had no plug in connector).
PostPosted: 21:11 - 07 Dec 2010    Post subject: Reply with quote
Thanks guys, I scoured ebay and found these two connectors.
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220699110782
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300497984124
Looks like the right thing so worth a punt for just over a fiver. If they don't work plug & play I can use the parts for a cut & shut Smile
The last post was made 15 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.25 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 62.79 Kb
