| Hevra |
 Hevra Nova Slayer
 Posted: 09:18 - 08 Dec 2010 Post subject: New, clueless and a bit scared... CBF125 |
Hello all,
I'm new to biking and am the first to admit that when it comes to mechanical things, I am totally clueless. I've had my CBF125 for a few days now, and am loving it, but I had a bit of an issue this morning on arriving at work.
I came into the office car park and when I parked up, I could not find neutral at all - yes yes I know, moron alert, but I tried going up and down the gears, tried going as far down as I could then going up one - but the neutral light on the bike never came on.
I've left it parked in what I assume is first, and am now bricking myself that I've somehow broken the gearing!
Apart from remembering that it's in gear when I leave tonight, can anyone suggest anything?
I do realise how pathetic this is, but I've never had anything with an engine before!
Thanks
H ____________________ _MJS_ : TLDR; MTFU, RTFM, DIY, tits and Gary. It's the only way you'll learn
CBF125 > XJ600S > V-Strom 650 |
| MarJay |
 MarJay But it's British!
 Posted: 09:38 - 08 Dec 2010 Post subject: |
Some bikes can be a bit of a pain in this regard.
The best things to try are:
Rolling the bike backward and forward then gently lifting the lever up.
Putting it in second then gently push down on the lever as you roll it forward. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| N cee thirty |
 N cee thirty Banned
 Posted: 10:24 - 08 Dec 2010 Post subject: |
haha it'll be a first if you have broke the gearbox.
just get used to it and you'll find it.. eventually  ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| G |
 G The Voice of Reason
| CptBlack |
 CptBlack Trackday Trickster
| Hevra |
 Hevra Nova Slayer
 Posted: 11:02 - 08 Dec 2010 Post subject: |
Thank you for the responses everyone I noticed that it sails past neutral when shifting from 1st to 2nd without even a brief flicker of the neutral light, so perhaps I was being too vigorous this morning when parked and trying to find it. I’ll try again at home time and if I have no joy still, I’ll just set off from 1st.
I’ve sellotaped a bit of paper with ‘IN GEAR’ written on it to my keys, hehe... I made sure I parked somewhere with a clear run off but best not to tempt fate...
CptBlack: I bought this new (well, pre registered) on Saturday so shouldn’t have stiffened up yet – I’ll bear that in mind for future bikes though
| pepperami |
 pepperami Super Spammer
 Posted: 11:06 - 08 Dec 2010 Post subject: |
Hello Mr/Mrs Hevra? and welcome to the wonderful world that is biking
You need to tell the mighty BCF a bit more so they can impress you with their wisdom.
Is it a brand new bike?
Is it a very old bike?
Does it appear to have been well looked after by its previous owner?
Have you got an owners manual? if not you should have!!!!
Is the gear lever a bit loose?
Is the clutch lever a bit loose?
There are many things that can make a bikes gearbox a bit sticky but that does not mean that they cant be cured fairly easily if you know what to look for?.
You might find that it is just the nature of the bike and when you get the hang of it, you will have a certain way of getting neutral when you come to a stop, but check it out just to make sure the bike is in good working order.
EDIT: just seen Cptn Black`s post =what he said ____________________ I am the sum total of my own existence, what went before makes me who I am now!
| CptBlack |
| locked |
 locked Could Be A Chat Bot
 Posted: 11:15 - 08 Dec 2010 Post subject: |
Hello Hevra and welcome.
I have the same bike and it does sometimes struggle to find neutral as well.
Best thing to do is to find first with the bike running. Slowley ease the clutch away until you find the biting point. Once you have, pull the clutch back in and shift up into neutral.
HTH  ____________________ on the look out for my next bike....
Motorcycles are perfectly safe as long as you remember they're dangerous. |
| yen_powell |
 Posted: 11:17 - 08 Dec 2010 Post subject: |
| Hevra wrote: | Thank you for the responses everyone  I noticed that it sails past neutral when shifting from 1st to 2nd without even a brief flicker of the neutral light, so perhaps I was being too vigorous this morning when parked and trying to find it. I’ll try again at home time and if I have no joy still, I’ll just set off from 1st.
H | Don't panic about starting it in gear. Being a modern bike there are about 3 switches/gizmos to stop you flying forward when you press the starter button.
If you turn the ignition switch on without the engine running you'll find that you won't be able make the starter turn unless you pull the clutch lever in. On the other hand, you will find it a lot easier to find neutral with the engine off anyway, so try it with the ignition switched on and the engine off. ____________________ Blackmail is a nasty word........but not as nasty as phlegm!
XT1200Z and a DR350 in bits |
| Hevra |
 Hevra Nova Slayer
| 27cows |
 27cows World Chat Champion
| Paxovasa |
 Paxovasa World Chat Champion
 Posted: 14:35 - 08 Dec 2010 Post subject: |
Hi Hevra.
It's normal for neutral to be harder to find than other gears - it's done that way on purpose to stop you selecting it by mistake.
You didn't say whether you were trying to find neutral with the engine running or stopped. If the engine was running, try selecting it with the engine off - it should be very easy to do then. Confirm you have the bike in gear or in neutral by rolling the bike gently back & forth. Check that your neutral light actually works, you might have a blown bulb or bad connection. ____________________ a.k.a 'Geri'
| Hevra |
 Hevra Nova Slayer
| CptBlack |
 Posted: 15:32 - 08 Dec 2010 Post subject: |
| Hevra wrote: | Initially I was trying to find it with the engine on as usual, but I had a go with it off and didn't have any luck then either. If I could roll it into the space though surely it must have been in neutral?
H |
Yes. If you stop in first, turn off the engine and knock the gear lever up with the clutch out, it'll ususally go right into neutral.
If you can push the bike more than a few inches without pulling in the clutch, you're in neutral, suggesting your neutral light is on the blink (most likely, blown bulb).
Once you've been riding a bit, you'll get a feel for the gearbox and will be able to tell when it's shifted into neutral without even looking at the light. I don't even have a neutral light on one of my bikes.
Best not to rely on the neutral light too heavily anyway, they can stay on when you're in gear and they can not come on when you're in neutral. Of particular relevance is staying on when in gear, which does happen sometimes if you half engaged either first or second, they can also jump back into gear if you didn't get it squarely into neutral. One of several reasons why it's a good idea to keep your foot on the brake when you stop.
Another tip for gear shifting is to always let the lever return fully to its resting position before trying for another gear change. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Hevra |
 Hevra Nova Slayer
| G |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 19:24 - 08 Dec 2010 Post subject: |
On my Derbi I had, the gearbox was good, but required a very positive use. It would on occasion not go into first after being in neutral and the trick is just to let the clutch out enough to biting point, pull it in and try again.
Neutral was never hard to find though. Just keep practicing and you will get there eventually. You learn these things very quickly after the first time .
If the bike is brand new, it will need running in, and after a few more miles and an oil change everything will probably settle down.
How many miles have you done? |
| Hevra |
 Hevra Nova Slayer
| 0l0dom0l0 |
 Posted: 19:32 - 08 Dec 2010 Post subject: |
Yeah 53 miles isn't really alot .
Have another go and if you don't feel like its getting any better just find someone else to try it . |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 19:43 - 08 Dec 2010 Post subject: |
Since it's a brand new bike, it could simply be that the clutch cable has stretched slightly as it's bedding in and just needs adjusting. If the clutch isn't disengaging fully when the lever is pulled all the way in, that can make both finding neutral and gear changes awkward sometimes. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| Rogerborg |
 Rogerborg nimbA
 Posted: 20:05 - 08 Dec 2010 Post subject: |
Well, if you buy one of those Indian-made bikes...
I agree with m'lurned colleagues - give it a little time to run in, but do check the tension on the clutch cable. There should be a little free play in the clutch lever before it tensions up, just about 1cm or so. Less and you risk running with the clutch partially engaged, more and you might not be able to engage the clutch fully.
It's dead easy to adjust - the end of the clutch cable sleeve will screw into the clutch lever, and be held tight with a locknut. Unscrew the clutch sleeve a little - that'll tension up the inner cable - then tighten up the locknut again.
If you fumble a shift from 1st to 2nd and end up in neutral, you may have to go back down to 1st again, then up to 2nd. This is pretty scary the first time it happens, but you'll soon get used to giving a good solid shift past neutral, or recovering it if you get stuck.
Hang in there, it gets easier quite quickly.  |
The last post was made 15 years, 294 days ago. Instead of replying here, would creating a new thread be more useful? |
