New, clueless and a bit scared... CBF125
Hevra
PostPosted: 09:18 - 08 Dec 2010    Post subject: New, clueless and a bit scared... CBF125 Reply with quote
Hello all,
I'm new to biking and am the first to admit that when it comes to mechanical things, I am totally clueless. I've had my CBF125 for a few days now, and am loving it, but I had a bit of an issue this morning on arriving at work.
I came into the office car park and when I parked up, I could not find neutral at all - yes yes I know, moron alert, but I tried going up and down the gears, tried going as far down as I could then going up one - but the neutral light on the bike never came on.
I've left it parked in what I assume is first, and am now bricking myself that I've somehow broken the gearing!
Apart from remembering that it's in gear when I leave tonight, can anyone suggest anything?
I do realise how pathetic this is, but I've never had anything with an engine before!
Thanks
H
_MJS_ : TLDR; MTFU, RTFM, DIY, tits and Gary. It's the only way you'll learn
CBF125 > XJ600S > V-Strom 650
PostPosted: 09:38 - 08 Dec 2010    Post subject: Reply with quote
Some bikes can be a bit of a pain in this regard.
The best things to try are:
Arrow Rolling the bike backward and forward then gently lifting the lever up.
Arrow Putting it in second then gently push down on the lever as you roll it forward.
PostPosted: 10:39 - 08 Dec 2010    Post subject: Re: New, clueless and a bit scared... CBF125 Reply with quote
You do often need a really gentle plip up to get it into neutral, especially on a 125.
As mentioned above, rolling it backwards and forwards can help.
If you can still start the bike, it's far from the end of the world to leave it in gear. I always do on a slope.
CptBlack
PostPosted: 10:44 - 08 Dec 2010    Post subject: Reply with quote
If you start it in gear, make sure you remember to hold the clutch in! Also, probably best to sit on it to just in case.
It's just practice. Both of my bikes took a while before you get the pressure right. If the bike had been sat for a few weeks while the previous owner had upgraded, may have stiffened up a bit. Finally, perhaps needs an oil change/top up?
Hevra
PostPosted: 11:02 - 08 Dec 2010    Post subject: Reply with quote
Thank you for the responses everyone Smile I noticed that it sails past neutral when shifting from 1st to 2nd without even a brief flicker of the neutral light, so perhaps I was being too vigorous this morning when parked and trying to find it. I’ll try again at home time and if I have no joy still, I’ll just set off from 1st.
I’ve sellotaped a bit of paper with ‘IN GEAR’ written on it to my keys, hehe... I made sure I parked somewhere with a clear run off but best not to tempt fate...
CptBlack: I bought this new (well, pre registered) on Saturday so shouldn’t have stiffened up yet – I’ll bear that in mind for future bikes though Smile
H
pepperami
PostPosted: 11:06 - 08 Dec 2010    Post subject: Reply with quote
Hello Mr/Mrs Hevra? and welcome to the wonderful world that is biking Thumbs Up
You need to tell the mighty BCF a bit more so they can impress you with their wisdom.
Is it a brand new bike?
Is it a very old bike?
Does it appear to have been well looked after by its previous owner?
Have you got an owners manual? if not you should have!!!!
Is the gear lever a bit loose?
Is the clutch lever a bit loose?
There are many things that can make a bikes gearbox a bit sticky but that does not mean that they cant be cured fairly easily if you know what to look for?.
You might find that it is just the nature of the bike and when you get the hang of it, you will have a certain way of getting neutral when you come to a stop, but check it out just to make sure the bike is in good working order.
EDIT: just seen Cptn Black`s post =what he said
CptBlack
PostPosted: 11:07 - 08 Dec 2010    Post subject: Reply with quote
Its probably more practice than something 'stiffening up' but it could be the gearbox needs oil working into it again and relubricating more than if it had just been left a few days, but as you'd ridden it to work it should be fine. Even with a new bike, it could have been sat in the show-room for a while.
locked
PostPosted: 11:15 - 08 Dec 2010    Post subject: Reply with quote
Hello Hevra and welcome.
I have the same bike and it does sometimes struggle to find neutral as well.
Best thing to do is to find first with the bike running. Slowley ease the clutch away until you find the biting point. Once you have, pull the clutch back in and shift up into neutral.
HTH Thumbs Up
yen_powell
PostPosted: 11:17 - 08 Dec 2010    Post subject: Reply with quote
H
Don't panic about starting it in gear. Being a modern bike there are about 3 switches/gizmos to stop you flying forward when you press the starter button.
If you turn the ignition switch on without the engine running you'll find that you won't be able make the starter turn unless you pull the clutch lever in. On the other hand, you will find it a lot easier to find neutral with the engine off anyway, so try it with the ignition switched on and the engine off.
XT1200Z and a DR350 in bits
Hevra
PostPosted: 11:34 - 08 Dec 2010    Post subject: Reply with quote
Mrs Smile
Thank you everyone - I will have a fiddle (fnarr) at hometime and let you know how I get on. Given I've only been riding for 4 days I'm sure it's me and not the bike, heartening to hear I'm not the only one though hehe!
H
27cows
PostPosted: 13:24 - 08 Dec 2010    Post subject: Reply with quote
On my commuter there's a single wire at the rear of the engine for the neutral light. This frequently gets corroded in winter and occasionally leads to the light not working. Nothing to do with difficulty getting the box into neutral, rather an electrical issue.
PostPosted: 13:42 - 08 Dec 2010    Post subject: Reply with quote
They'll usually snick into neutral very easily with the engine off.
Paxovasa
PostPosted: 14:11 - 08 Dec 2010    Post subject: Reply with quote
Hello,
When I have trouble finding neutral, I usually put the bike in first, release the clutch to the biting point, then pull in the clutch and the bike then goes into neutral easier.
PostPosted: 14:35 - 08 Dec 2010    Post subject: Reply with quote
Hi Hevra.
It's normal for neutral to be harder to find than other gears - it's done that way on purpose to stop you selecting it by mistake.
You didn't say whether you were trying to find neutral with the engine running or stopped. If the engine was running, try selecting it with the engine off - it should be very easy to do then. Confirm you have the bike in gear or in neutral by rolling the bike gently back & forth. Check that your neutral light actually works, you might have a blown bulb or bad connection.
Hevra
PostPosted: 15:16 - 08 Dec 2010    Post subject: Reply with quote
Initially I was trying to find it with the engine on as usual, but I had a go with it off and didn't have any luck then either. If I could roll it into the space though surely it must have been in neutral?
H
CptBlack
PostPosted: 15:18 - 08 Dec 2010    Post subject: Reply with quote
Yeah, shouldn't move more than an inch in gear. Ask a biker if one parks near you, or at a supermarket or somewhere, explain you've only just started riding and need someone to have a quick look. Or go back to the garage.
PostPosted: 15:32 - 08 Dec 2010    Post subject: Reply with quote
H
Yes. If you stop in first, turn off the engine and knock the gear lever up with the clutch out, it'll ususally go right into neutral.
If you can push the bike more than a few inches without pulling in the clutch, you're in neutral, suggesting your neutral light is on the blink (most likely, blown bulb).
Once you've been riding a bit, you'll get a feel for the gearbox and will be able to tell when it's shifted into neutral without even looking at the light. I don't even have a neutral light on one of my bikes.
Best not to rely on the neutral light too heavily anyway, they can stay on when you're in gear and they can not come on when you're in neutral. Of particular relevance is staying on when in gear, which does happen sometimes if you half engaged either first or second, they can also jump back into gear if you didn't get it squarely into neutral. One of several reasons why it's a good idea to keep your foot on the brake when you stop.
Another tip for gear shifting is to always let the lever return fully to its resting position before trying for another gear change.
Hevra
PostPosted: 18:40 - 08 Dec 2010    Post subject: Reply with quote
Well I managed to find neutral again, in fact I found it a few times inadvertently on the way home.
I had an absolute mare at one point, I stalled when turning into a side road and couldn't shift up from 1st - felt like the engine didn't 'catch'... I don't know the right name for it, but took me a couple of attempts to get into second, and then I stalled it on a right turn into a side road about 400 meters down the road and couldn't get into first once pulled over out of everyone elses' way.
Arghhh and I thought I'd been getting the hang of this biking lark ;_;
I am indeed a nobcat.
H
PostPosted: 18:50 - 08 Dec 2010    Post subject: Reply with quote
Know anyone else that rides bikes that could have a quick go?
New engines can actually be a bit 'stiff' to start with and tend to free up a bit after a while.
Are you definitely fully pulling the clutch in?
0l0dom0l0
PostPosted: 19:24 - 08 Dec 2010    Post subject: Reply with quote
On my Derbi I had, the gearbox was good, but required a very positive use. It would on occasion not go into first after being in neutral and the trick is just to let the clutch out enough to biting point, pull it in and try again.
Neutral was never hard to find though. Just keep practicing and you will get there eventually. You learn these things very quickly after the first time Smile.
If the bike is brand new, it will need running in, and after a few more miles and an oil change everything will probably settle down.
How many miles have you done?
Hevra
PostPosted: 19:29 - 08 Dec 2010    Post subject: Reply with quote
I could get my husband to try it, he's as new to biking as I am although he's a) been driving for 12 years and b) isn't a total pansy so perhaps he can work out what's going on.
Miles: it has done 53 so far, hehe
H
0l0dom0l0
PostPosted: 19:32 - 08 Dec 2010    Post subject: Reply with quote
Yeah 53 miles isn't really alot Smile.
Have another go and if you don't feel like its getting any better just find someone else to try it Smile.
PostPosted: 19:43 - 08 Dec 2010    Post subject: Reply with quote
Since it's a brand new bike, it could simply be that the clutch cable has stretched slightly as it's bedding in and just needs adjusting. If the clutch isn't disengaging fully when the lever is pulled all the way in, that can make both finding neutral and gear changes awkward sometimes.
PostPosted: 20:05 - 08 Dec 2010    Post subject: Reply with quote
Well, if you buy one of those Indian-made bikes... Wink
I agree with m'lurned colleagues - give it a little time to run in, but do check the tension on the clutch cable. There should be a little free play in the clutch lever before it tensions up, just about 1cm or so. Less and you risk running with the clutch partially engaged, more and you might not be able to engage the clutch fully.
It's dead easy to adjust - the end of the clutch cable sleeve will screw into the clutch lever, and be held tight with a locknut. Unscrew the clutch sleeve a little - that'll tension up the inner cable - then tighten up the locknut again.
If you fumble a shift from 1st to 2nd and end up in neutral, you may have to go back down to 1st again, then up to 2nd. This is pretty scary the first time it happens, but you'll soon get used to giving a good solid shift past neutral, or recovering it if you get stuck.
Hang in there, it gets easier quite quickly. Thumbs Up
The last post was made 15 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 131.96 Kb
