Fuel Efficient Riding
WildGoose
White Van Man
PostPosted: 16:41 - 02 Aug 2004    Post subject: Fuel Efficient Riding Reply with quote
come on then, whats the trick, occasionally i get the CBR to run to 200km's per tank, usually following sedate 60mph motorway routes
when im out thrashing, i have seen as little as 122km's before running onto reserve Shocked
if there was some kind of incentive for riding sedately, then it might be a little easier, and the difference between 122 or 200 km's to a tank is fairly major
so how exactly do you need to ride in order to conserve your fuel?
Kris
PostPosted: 16:43 - 02 Aug 2004    Post subject: Reply with quote
Acceleration and high revs burn fuel faster I believe. Therefore ideal fuel-efficiency would be cruising at barely above tickover in top gear, with leathers on and tucked in behind the fairing.
www.prisonplanet.com
1stGarry
PostPosted: 16:48 - 02 Aug 2004    Post subject: Reply with quote
Buy a Honda C70!
1stGarry
Big Pete
PostPosted: 17:01 - 02 Aug 2004    Post subject: Reply with quote
1) - don`t accellerate, if you really need to, do it slowly rather than a giving it a big handfull.
2) - don`t brake, because then 1 kicks in.
3) minimise drag, i.e. sit behind trucks, vans, caravans anything bigger than you, and wear slippery gear and a rucksack (fills in the low pressure zone behind the rider)
4) - blow your tyres up to the maximum - it reduces rolling resistance.
5) - use the lightest chain you can, keep it well oiled (scottoiler or similar) and make sure your brake pads dont drag at all.
6) - keep the speed down, dont use indicators or headlights.
all of these will contribute towards higher mileage, but make for a boring ride Laughing
Trust me, I`m an engineer
GarageOfPower.co.uk
Scotty
Scooter Boi
Connect your starter motor to a mains outlet get quite a few extension leads then "start" button your ass to your desired destination.
I probably would have thoguht riding round in top gear in a peak torque level without much throttle would give good fuel comsumption.
Regards
Scott
Robby
Dirty Old Man
PostPosted: 17:09 - 02 Aug 2004    Post subject: Reply with quote
Keep the speed down and the throttle closed, or near to.
Annabella
Like a person, only smaller
PostPosted: 18:30 - 02 Aug 2004    Post subject: Reply with quote
Only 200km?
Goosey, there's something wrong with it.... I get around 260km before I hit reserve just riding normally. If I'm taking the grand ride to Cardiff normally it will do more if I just sit at around 90.
Avast! Pirates ahoy!
I did Cadwell! Very Happy
EuropeanNC30R...
Gay Hairdresser
PostPosted: 18:40 - 02 Aug 2004    Post subject: Reply with quote
That sounds very high Anna Shocked
Just done some rough calculations and assuming yours has 12 litres to reserve like mine, you're doing 60+ mpg. I struggle to get that kind of mpg sitting at 70mph Eh?
Annabella
PostPosted: 18:43 - 02 Aug 2004    Post subject: Reply with quote
Definately does 260km before it hits reserve. I've never run it past there... Thinking
andylanc
PostPosted: 19:09 - 02 Aug 2004    Post subject: Reply with quote
er not wishing to brag but I manage 180 miles before the Thundercat's little light comes on to tell me it's time for more go-go juice Embarassed
The big killer for fuel economy is heavy accelerating and braking, just drinks petrol that.
Danny
Ask Me About Stoppie School
PostPosted: 22:22 - 02 Aug 2004    Post subject: Reply with quote
Damn, I'm only getting 150 to a tank on my Thundercat Sad
Major_Grooves
The Doctor
PostPosted: 22:36 - 02 Aug 2004    Post subject: Reply with quote
I get over 250km to a tank on my CB500.
Good 'ol commuter bikes! Mr. Green
About me|@Major_Grooves|My company|Digg|Flickr
1stGarry
PostPosted: 22:58 - 02 Aug 2004    Post subject: Reply with quote
110 miles to a tank on my Buell S1.
45 - 50mpg.
Always the same, however I ride it.
1stGarry
Doddmaster
PostPosted: 23:01 - 02 Aug 2004    Post subject: Reply with quote
Look at you all complaining. I have had as little as 60 from a tank, I once managed over 90 Shocked
To conserve fuel, I jump in the Clio
XS1954
PostPosted: 23:07 - 02 Aug 2004    Post subject: Reply with quote
My bike does about 170 miles before the light comes on. You must be riding hard Danny.
You're a cock.
PostPosted: 23:52 - 02 Aug 2004    Post subject: Reply with quote
Well the Bandit manages around 180 miles on a tank full safely, The FZ750 a bit over 200 and the GPZ we are not really sure (but it will do 220 on a tank, but gets water in the tank easily which makes switching to reserve a dodgy idea).
As to efficiency the engine is at its most efficient on full throttle at the revs of peak torque. Trouble is that do that and you will accelerate quite rapidly.
The last post was made 22 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 88.66 Kb
