GSXR 600 SRAD Buying Advice
skithepowder
PostPosted: 18:55 - 09 Dec 2010    Post subject: GSXR 600 SRAD Buying Advice Reply with quote
Going with a friend to check out a 97 GSXR SRAD tomorrow, 33000 miles. Had new chain and sprockets, owned by a mechanic with lots or receipts. I know all the paperwork to check, MOT, Tax, Vin no and engine no against v5. And know to check the basic mechanics, brakes, bearings, engine sound, looking for signs of track use such as holes drilled for retainers in the sump and hero blobs and footpeg wear, tyres electrics etc etc
Is there anything specific mechanically to look for in these bikes that often goes wrong, aside from signs of being thrashed at trackdays?
mad4it028
PostPosted: 19:37 - 09 Dec 2010    Post subject: Reply with quote
the best advice i can tell you is 33000miles + suzuki wouldnt touch it with a barge pole
i just bought a zx6r to break when i got there my 1st thoughts were hmmm ive got all the parts needed to rebuild this back on the road then once the ignition was on i saw 30000+miles n thought nah fuck that ill break it!
MaybeGuy
PostPosted: 19:42 - 09 Dec 2010    Post subject: Reply with quote
milage is irrelavent. ignore that guy.
look for headlight lugs snapped off (give the front end a good lift to see if it moves). both up AND down. shouldnt be movement. test ride it. if the wing mirrors practically vibrate over minor bumps then avoid.
smell the oil, make sure it doesnt smell like fuel. they like to hydro lock, dumping oil into the sump if the fuel pump is dodge. easy to fix, but doesnt do your engine any good and you dont know what else they've got slack on. avoid.
other than that, knocks and rattles, the usual. if it rattles at idle but not as you rev it, chances are its the cam chain. doesnt matter that much as its cheap and easy to fix (haggling point).
blah blah blah common sense etc
PostPosted: 19:51 - 09 Dec 2010    Post subject: Reply with quote
The oil is supposed to be in the sump Very Happy
Agree, 33k miles on a roadgoing GSXR is nothing to worry about at all. Condition of the mechanicals is more important but don't put any weight on the 'owned by a mechanic' bit - many mechanics neglect their own machines because they are sick of working on them day in day out.
D O G
PostPosted: 19:59 - 09 Dec 2010    Post subject: Reply with quote
Shit modifications are probably the worst thing about SRADs - aftermarket undertrays with the shotgun lights can be badly wired and poorly installed, mini indicators are the same - are they really secure? Plus if resistors have not been correctly fitted then they will flash quickly. I'd much rather a stock bike.
Finish is not that good on the fastenings - and the paint starts to peel on the fork bottoms, but you'll notice that soon enough.
Aside from that and god awful yellow screens which some degenerates fit to them you should be OK.
MaybeGuy
Brick Wall you know what i mean.
if your fuel pumps fucked your oil will smell like fuel. ive only ever come across that on my srad, but the same happened to my friends. so clearly a common thing.
D O G
PostPosted: 20:07 - 09 Dec 2010    Post subject: Reply with quote
Happened on mine too.
Gazdaman
I did a trackday!!!
PostPosted: 13:27 - 10 Dec 2010    Post subject: Reply with quote
Definitely agree about headlight lugs, they were the first thing to snap on mine when I dumped it. And they sure aint cheap to replace.
Cam chain tensioners are pretty crap if it's still on an original one. Replacing with a manual one is a decent mod. So listen for cam chain-y noise.
But other than that, SRADs are bloody good bikes, my 600 is the only bike I truely miss.
Gaz
MaybeGuy
PostPosted: 15:17 - 10 Dec 2010    Post subject: Reply with quote
D O G wrote:
aside from that and god awful yellow screens which some degenerates fit to them you should be OK.
choke on shit
Livefast123
PostPosted: 17:47 - 10 Dec 2010    Post subject: Reply with quote
Milage is irrelevant as long as it has been mechanically looked after.
One listen to the engine should be enough to tell you wether to buy it or not Thumbs Up
Current ride - Yamaha MT-07
Ol
PostPosted: 12:02 - 11 Dec 2010    Post subject: Reply with quote
Think Redoko's selling his, looks pretty mint - if i had enough money i'd have bought it already !!! drop him a PM!
MaybeGuy
PostPosted: 14:03 - 11 Dec 2010    Post subject: Reply with quote
im currently debating buying the one on ebay that doesnt have a mudguard for £750.
mistergixer
PostPosted: 14:49 - 11 Dec 2010    Post subject: Reply with quote
Coloured screens full stop. They should be left in the '90s along with Iridium visors. This goes double for purple screens fitted to green Kwackers - especially when accompanied with other purple anodised tat.
My SRAD came with a blue screen and shitty poorly wired tiny indicators courtesy of the previous owner.
They were removed.
Mistergixer - style guru.
Space Monkey #7
MaybeGuy
PostPosted: 15:09 - 11 Dec 2010    Post subject: Reply with quote
and srads?
Redoko
PostPosted: 16:48 - 11 Dec 2010    Post subject: Reply with quote
Mines for sale.
https://www.bikechatforums.com/viewtopic.php?t=209860&highlight=
mistergixer
PostPosted: 18:35 - 11 Dec 2010    Post subject: Reply with quote
mattsprattuk wrote:
and srads?
SRAD 600s carried on until 2000.
Space Monkey #7
MaybeGuy
PostPosted: 18:43 - 11 Dec 2010    Post subject: Reply with quote
so did the genital warts i gave your mum
slyrob
PostPosted: 18:47 - 11 Dec 2010    Post subject: Reply with quote
Redoko wrote:
I remember this bike from the Brighton rideout, was certainly very clean looking bit of kit, I would buy it to replace the dead thundercat if it wasn't a little above what I wish to pay, however it certainly looked worth the money Thumbs Up
Pitslayer wrote "it could be Ndubz.....ruining this once great place with donkey gobbling loafer knobbing "music".
silky666 wrote "In my eyes, when you shake cocks with the devil, you may as well go for the full reach around"
Villers wrote "as reliable as a ginger stepchild on smack"
mistergixer
PostPosted: 18:53 - 11 Dec 2010    Post subject: Reply with quote
Oh wow, a 'mum' joke, i thought they too died out in the 90's, along with coloured screens and iridium visors.
It's just a shame you didn't join them.
Mum jokes - the recourse of the mentally substandard since 1990.
Space Monkey #7
MaybeGuy
PostPosted: 19:49 - 11 Dec 2010    Post subject: Reply with quote
what on earth are you talking about?
Yarri
PostPosted: 20:55 - 11 Dec 2010    Post subject: Reply with quote
Choke can sometimes get stuck, but thats minor. Low beam on gsxr srad is a fucking joke, otherwise they're decent.
Theory Passed: 23/10/2008 Very Happy 49/74 Bike Test Passed: 05/01/2009 Very Happy 1 minor
Theory Car Passed: 22/07/2009 Very Happy 48/74 Car Test Passed: 22/10/2009 Very Happy 2 minor
Few minutes of life of the biker could be more interesting then the whole lifes of many people
mistergixer
PostPosted: 14:12 - 12 Dec 2010    Post subject: Reply with quote
Sorry for confusing you, i should have realised i was dealing with a mental pygmy.
I guess you must have struggled with some of the longer words, probably best to ask a grown-up for help.
Space Monkey #7
MaybeGuy
PostPosted: 14:49 - 12 Dec 2010    Post subject: Reply with quote
what is the point of you in this thread other than failing to instigate a reaction?
mistergixer
PostPosted: 16:58 - 12 Dec 2010    Post subject: Reply with quote
Surely the fact that you're responding suggests that i have instigated a reaction.
You're not the sharpest knife in the drawer, are you?
I also find it quite comical that, given some of your previous posts (for example the one about the bullied kid hanging himself), you have the audacity to accuse others of 'pointlessly' commenting in threads for no other purpose than attempting/failing to 'instigate a reaction'.
https://www.serialmouse.com/wp-content/themes/green-marinee/images/potKettle_enough.jpg
https://www.toothpastefordinner.com/030607/pot-kettle-fat.gif
Space Monkey #7
MaybeGuy
PostPosted: 17:02 - 12 Dec 2010    Post subject: Reply with quote
Neutral
The last post was made 15 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 3.89 - MySQL Queries: 13 - Page Size: 139.4 Kb
