| 1992rg125 |
 1992rg125 Derestricted Danger
| Kickstart |
 Kickstart The Oracle
| Barry_M2 |
 Barry_M2 World Chat Champion
| 1992rg125 |
| 1992rg125 |
| Barry_M2 |
| 1992rg125 |
| Kickstart |
| 1992rg125 |
| Kickstart |
| 1992rg125 |
| 1992rg125 |
| bryvw1973 |
 bryvw1973 Two Stroke Sniffer
| 1992rg125 |
| MarJay |
 MarJay But it's British!
| 1992rg125 |
| Kickstart |
| 1992rg125 |
| Kickstart |
 Posted: 22:33 - 13 Dec 2010 Post subject: |
For compression, get a compression tester, take out the spark plug and screw in the tester then crank the engine over with the throttle wide open until the reading on the tester stop going up.
As to the power valve, I presume that on the RG it operates when you turn on the igntion. If so check it actually does operate. You will probably need a manual to find out how you are meant to set it up and check it is right. Beyond that you probably need to strip it down and check it. The barrel is the same as the RGV250 I think and they are infamous for eating the power valves (and it will wreck the top end if this happens), and from memory about a 10k life wasn't unusual. Hopefully one of the former RGV250 owners can give more details.
| 1992rg125 |
| Kickstart |
 Posted: 19:34 - 14 Dec 2010 Post subject: |
Don't bother with the pipe and filter yet. Get it sorted first otherwise you are just adding something else to confuse problem solving.
Don't know about the TS con rod kit, but possibly not even if they are basically the same engine (con rod length is one of the things played with when deriving one engine from another for a slightly different purpose). Also fitting a new con rod is not a home job, certainly not something to be done by someone inexperienced.
Realistic top speed will be just short of 100mph true top speed. Indicated probably a bit higher.
| 1992rg125 |
 Posted: 19:51 - 14 Dec 2010 Post subject: |
i will not be the one rebuilding it
my dad raced karts and did his own engins 1986 rd125lc with
tzr crank
34 mm macoony
yz piston and rod
2 mm of the top of the barrel and packed up the bottom 2mm to raze the porting
got a real 110 mph but that engine would be completely unridable in a bike no power below 11000rpm and revs to 14000rpm
(but id have a very good go of it )
so hes doing the rebuild
he says the prox piston would be a good ider
so will the tsr piston kit fit
and what about the pv kit ____________________ ns125r1992
rg125f1992
next who knows |
| Kickstart |
| 1992rg125 |
| Kickstart |
The last post was made 15 years, 207 days ago. Instead of replying here, would creating a new thread be more useful? |
