Rubbers between carbs and air box 1996 GPX
hornetmike
PostPosted: 21:28 - 12 Dec 2010    Post subject: Rubbers between carbs and air box 1996 GPX Reply with quote
Finally got the GPX running with out leaking fuel everywhere, but can not get the rubbers between air box and carbs back on. The closest I got was warming them up and fitting them which took hours and as soon as they cooled down they fell off.
Was thinking of replacing the air box with cone filters which are hard to find, is there something i can replace the hoses with ?
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
satans_BIG_helper
PostPosted: 21:34 - 12 Dec 2010    Post subject: Reply with quote
Unfortunately its a GPZ issue i have had 2 750's now and they both have the same issue.... What i did was put the rubbers in boiling hot water to make them stretchy and flex a bit.... then put them on the bike fight and argue to get them in place and make sure they are all pushed down onto the carbs as far as possible, then i wedge the airbox against the frame with a piece of wood to hold it there... wait for the rubbers to cool and then they should be well and truly in place..
Failing that you can order replacements if you have the part number.
Hope this helps
Dave
TS 50er >CG 125>AR 125>TZR250> z200(shit heap)> ZXR750 H2 > VT500 FT >XLR250 > Mito125mk1 (unlucky strike) > TZR250 3ma > GS550 > TDR250 > GSXR750 >GS1000 > Elefant 650 > GPZ750 > FZR600>z1000 (03) > KTM 640 LC4
(Yeah i forgot some too :S )
PostPosted: 22:00 - 12 Dec 2010    Post subject: Re: Rubbers between carbs and air box 1996 GPX Reply with quote
I'm a bit confused how they fell off when they cooled?
Normally they are a right ball-ache to get back on, but once they're on properly, they're on.
PostPosted: 03:42 - 13 Dec 2010    Post subject: Reply with quote
Aye. I normally get them mad-hot and fit them that way. Depending on design, you can sometimes even fold them back on themselves, install the airbox side then "pop" the other side back over the end of the carbs.
Never had them come off again once they were eventually fitted because the "memory" of the plastic is generally set in the correct place. Makes me wonder if you have the correct rubber on the correct carb or if they are upside down or similar. Kawasaki ones are often marked for orientation (so eg. it'll be one way up for the left side, the other way up for the right side) Last set of GPZ carb rubbers I fitted were marked 'L TOP' and 'R TOP'.
I would strongly encourage you to persist with the rubbers. The GPZ/GPX/ZZR series do not take well to running without the airbox. There is a lot of complex pressure wave jiggery-pokery and maths going on in there.
hornetmike
PostPosted: 20:20 - 14 Dec 2010    Post subject: Reply with quote
"i gave up on mine and sold the bike before i committed suicide."
I know how you feel now, got quoted £70 for new rubbers, only paid £150 for bike. Tried again to fit them with heat gun and got 3 on but they fell off when started bike.
Got to be a cheaper way
fiery tupp
PostPosted: 21:54 - 14 Dec 2010    Post subject: Reply with quote
A few ideas here you never know ? https://www.high-speed.ismysite.co.uk/phpBB3/viewtopic.php?f=34&t=8482
At least your not the first with this problem Smile
If you can't fix it with a hammer , use your head .
The last post was made 15 years, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.44 - MySQL Queries: 13 - Page Size: 48.58 Kb
