Derbi Senda Oil Help
HD
PostPosted: 19:32 - 11 Dec 2010    Post subject: Derbi Senda Oil Help Reply with quote
My bike is chucking out oil. Its pouring out of the exhaust, over the holder, down the exhaust, onto the swingarm, onto the chainguard, oily spark plugs, making the bike run shit!
Grrr!
Can anyone help tell me how to adjust the oil pump. It is clearly throwing out too much oil. Teh father adjusted the cable but it seems mostly the same... Just need to know how to lean the mixture!
Help Sad
HD
PostPosted: 20:43 - 12 Dec 2010    Post subject: Reply with quote
Cheers for the help. oN A VERY close look we saw that there are two faint lines and one on the actual bike. The two are on the oil pump on the bit that moves. I have put the line on the bike in between the two and it just about perfect smokiness, gonna see if it runs down the bike now and then adjust it if it does, if not leave it.
So just to summarise if anyone else does end up with the same problem:
Arrow Loosen the cable
Arrow Adjust the oil pump so the two faint lines are by the ones on the actual bike (left hand side of the oil pump section)
Arrow Re-tighten cable
Yes as simple as that and it was a lingering problem for weeks!
satans_BIG_helper
PostPosted: 21:43 - 12 Dec 2010    Post subject: Reply with quote
One of those lines should be for when the throttle is closed and the other mark WOT (wide open throttle),
if the marks are far apart that is, if they are narrow lines then it should be for when the throttle is closed but on some italian bikes i have seen the mark be for when its on WOT.
TS 50er >CG 125>AR 125>TZR250> z200(shit heap)> ZXR750 H2 > VT500 FT >XLR250 > Mito125mk1 (unlucky strike) > TZR250 3ma > GS550 > TDR250 > GSXR750 >GS1000 > Elefant 650 > GPZ750 > FZR600>z1000 (03) > KTM 640 LC4
(Yeah i forgot some too :S )
HD
PostPosted: 22:45 - 12 Dec 2010    Post subject: Reply with quote
The two lines are about 1cm maybe even less apart. Probs about 8mm. I imagine one is for less oil, one is for more. Over or under either is extreme, that is what I think.
Ill get a pic and edit it tomorrow to show you what I mean.
And the bikes spanish Wink
I used to think it was Italian Embarassed
truslack
PostPosted: 23:36 - 12 Dec 2010    Post subject: Reply with quote
With an italian engine and oil pump, japanese forks, largely italian electrics etc
HD
PostPosted: 19:07 - 13 Dec 2010    Post subject: Reply with quote
Well some cockhead on here told me it was spanish! Laughing
Yes, gullible is written on the ceiling Wink
truslack
PostPosted: 19:15 - 13 Dec 2010    Post subject: Reply with quote
Derbi are spanish, the bike may even have been assembled there, but Minarelli (am6 engine) are italian, Showa (forks) are Japanese, etc.
cheekythomas
PostPosted: 22:34 - 13 Dec 2010    Post subject: Reply with quote
Why do people keep confusing derbi as running a AM6 engine?? Derbi run derbi engines... Not AM6s!!
The old engine was built by Derbi, the newer DB050 is built by piaggio, neither were built by minarelli.
Also if it's really oily, make sure you a decent oil, if it's the newer engine it should be a fully synthetic to make it all burns off cleanly.
truslack
PostPosted: 22:50 - 13 Dec 2010    Post subject: Reply with quote
The engine in my derbi was identical to my Am6 engined rS50, thus its italian, by design if nothing else.
HD
PostPosted: 08:50 - 14 Dec 2010    Post subject: Reply with quote
Certainly is sir! Silkolene Comp 2 Smile
cheekythomas
PostPosted: 13:08 - 15 Dec 2010    Post subject: Reply with quote
Well your senda had a different engine fitted... Derbi have never used the AM6 engine... ever.
So you had a home built, or just never looked hard enough. Wink
truslack
PostPosted: 13:50 - 15 Dec 2010    Post subject: Reply with quote
Having done more research, I stand corrected (although a lot of the castings are identical, as are the mounting points). They still use the same electrics though Laughing
HD
PostPosted: 18:54 - 15 Dec 2010    Post subject: Reply with quote
Been talking to my dad and he wondered if when I had the cylinder rebored and a slightly larger piston if the bore is now too big for the rings so it is letting it through more.
What you lot think?
The last post was made 15 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.71 - MySQL Queries: 13 - Page Size: 78.57 Kb
