| Noxious89123 |
 Noxious89123 World Chat Champion
 Posted: 20:13 - 13 Dec 2010 Post subject: Removing corrosion behind brake piston seals |
I've heard people talk about corrosion building up behind seals causing brakes to stick, because of the extra pressure on the seals/pistons.
What is suitable to remove any corrosion in the grooves the seals sit in? My rear brake is a little sticky, and fancy having a go at stripping the calliper and giving it a good clean up and stick in some new seals, as it's only £11 all in for a set from David Silvers.
Pumping the piston out, cleaning it and greasing it with silicon grease sorts the problem, temporarily, but it soon returns. As far as I'm aware, the bike hasn't ever had them changed in 10 years, and it has seen road salt and the like. ____________________
'06 Honda CBR125RW-6 ~ '00 Honda CBR600F-Y ~ '07 Honda CBR600RR-7 ~ Bikeless
| Itchy |
 Itchy Super Spammer
 Posted: 21:37 - 13 Dec 2010 Post subject: |
Corrosion? Surely you mean dirt and road crud?
That is what causes pistons to jam, you might want to try better dust seals, or a smear of red rubber grease to prevent crud getting into the seals. My Honda ones need doing 6 months to a year. But some Yamaha ones are notorious for jamming up super quick.
Bog roll a bic pen top are pretty much all you need to remove the crud from the pistons. You can lever out the seals with the pen top. Then just use bog roll to wipe them down. Same with the grooves they sit in.
With the piston itself, just rub it against your hand, if you feel it scratch use soft plastic say a ruler to scrape off the rubbish. If it can't be scratched off then it might be time for a new piston. Some brake cleaner may also help but it is not needed.
Put some bog roll on the end of a match and swab the entire inside of the cylinder. Then rinse it with brake fluid, then reassemble carefully. Jobs done. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Robby |
 Robby Dirty Old Man
| Itchy |
 Itchy Super Spammer
| Noxious89123 |
 Posted: 22:23 - 13 Dec 2010 Post subject: |
Well I suppose the only way to find out if it's caused by corrosion or crud is to strip it down and take a look. Won't be doing it until the weather is a bit nicer, as I like to take my time and it's fcking cold ouside! No fun trying to do stuff with numb fingers.
Cheers guys.  ____________________
'53 Ford Ka 1.3 ~ '03 Vauxhall Astra SRi 1.8 ~ '52 Vauxhall Astra SRi 2.2 ~ '53 Vauxhall Astra GSi |
| evoboy |
 evoboy World Chat Champion
| Robby |
 Robby Dirty Old Man
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| Kickstart |
 Kickstart The Oracle
| chris-red |
 Posted: 11:02 - 14 Dec 2010 Post subject: |
I think Sickpup told me to run a dremmel with a wire wheel round the inside to clean it up. Make sure it is a brass wheel that won;t damage the ally. I'd get somebody to confirm this won't knacker your caliper though as my memory is fuzzy and he might have never said this.  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| Kickstart |
| MarkJ |
 MarkJ World Chat Champion
| DrDonnyBrago |
| Kickstart |
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 15:16 - 14 Dec 2010 Post subject: |
When I did mine, I got the majority of the stubborn crud off with a bent piece of 2.5mm copper wire, carefully scraped around the groove.
For the final clean I soaked a plastic kitchen scourer in brake fluid and scoured away to my hearts content, came up nice!
https://christianhomekeeper.org/files/2010/04/scotch-brite.jpg |
| stirlinggaz |
 stirlinggaz World Chat Champion
| Noxious89123 |
 Posted: 21:58 - 14 Dec 2010 Post subject: |
Bear in mind this is only the rear brake, the fronts are spot on
It doesn't exactly stick on, but it's as if the seals stick to the piston and pull it back into the calliper body slightly when brake pressure is released. It means that the rear brake lever permanently feels "long" because every time the brake is applied the piston moves out slightly before it applies pressure on the pads.
As I said above, cleaning and greasing solves the problem temporarily, and it feels massively better for it.
Thanks for all the advice guys; it's all very much appreciated. Will post up with the results when I finally get around to sorting it, which won't be for a long while yet!
EDIT: Just another thought:
Does bottled brake fluid have a shelf life. I've got a bottle which is unopened. Probably about a year old. This is ok, right?
When reattaching the brake line to the calliper, should I use new sealing washers and/or banjo bolt? I'd imagine the banjo is reusable but that the washers are a case of "you don't have to but..." ____________________
| Mrs Vale46 |
 Mrs Vale46 Nova Slayer
 Posted: 22:39 - 14 Dec 2010 Post subject: |
The way in which I clean all the brake calipers on all the bikes at my house is by taking them of and letting thm soak in hot soapy water ( use fairy liquid its the best I think lol) then using an old toothbrush and scrub away to ur hearts content.
I have given this advise to another brake/caliper problem sufferer hopefully its helpful as its the method I use on my nsr, my mum's fazer, my dads blackbird and the race bike. And its proven effective.
Emma-Louise |
| Kickstart |
| Noxious89123 |
| Kickstart |
| Robby |
 Robby Dirty Old Man
| Noxious89123 |
The last post was made 15 years, 151 days ago. Instead of replying here, would creating a new thread be more useful? |
