Removing corrosion behind brake piston seals
Bike Chat Forums Index -> The Workshop via View All Topics
Noxious89123
PostPosted: 20:13 - 13 Dec 2010    Post subject: Removing corrosion behind brake piston seals Reply with quote
I've heard people talk about corrosion building up behind seals causing brakes to stick, because of the extra pressure on the seals/pistons.
What is suitable to remove any corrosion in the grooves the seals sit in? My rear brake is a little sticky, and fancy having a go at stripping the calliper and giving it a good clean up and stick in some new seals, as it's only £11 all in for a set from David Silvers.
Pumping the piston out, cleaning it and greasing it with silicon grease sorts the problem, temporarily, but it soon returns. As far as I'm aware, the bike hasn't ever had them changed in 10 years, and it has seen road salt and the like.
Itchy
PostPosted: 21:37 - 13 Dec 2010    Post subject: Reply with quote
Corrosion? Surely you mean dirt and road crud?
That is what causes pistons to jam, you might want to try better dust seals, or a smear of red rubber grease to prevent crud getting into the seals. My Honda ones need doing 6 months to a year. But some Yamaha ones are notorious for jamming up super quick.
Bog roll a bic pen top are pretty much all you need to remove the crud from the pistons. You can lever out the seals with the pen top. Then just use bog roll to wipe them down. Same with the grooves they sit in.
With the piston itself, just rub it against your hand, if you feel it scratch use soft plastic say a ruler to scrape off the rubbish. If it can't be scratched off then it might be time for a new piston. Some brake cleaner may also help but it is not needed.
Put some bog roll on the end of a match and swab the entire inside of the cylinder. Then rinse it with brake fluid, then reassemble carefully. Jobs done.
Robby
Dirty Old Man
PostPosted: 22:05 - 13 Dec 2010    Post subject: Reply with quote
No, he means corrosion in the caliper. The alloy corrodes behind the dust seals into white powder, forcing the seal to grip the caliper a bit more. Main cause of brakes feeling wooden. Older bikes need it doing every 5-10 years, I assume modern alloy is better.
Take out the seal, scrape out the corrosion with a dentists pick or a very small screwdriver. Don't scrape too hard, the stuff will flake off with very little pressure. Rinse with brake cleaner and reassemble with new seals.
Itchy
PostPosted: 22:10 - 13 Dec 2010    Post subject: Reply with quote
How old do you mean when you say old? My early 90s bikes and late 80s bikes never did this.
Noxious89123
PostPosted: 22:23 - 13 Dec 2010    Post subject: Reply with quote
Well I suppose the only way to find out if it's caused by corrosion or crud is to strip it down and take a look. Won't be doing it until the weather is a bit nicer, as I like to take my time and it's fcking cold ouside! No fun trying to do stuff with numb fingers.
Cheers guys. Karma
evoboy
PostPosted: 01:24 - 14 Dec 2010    Post subject: Reply with quote
Got to admit that non of my 80's or early 90's bikes have ever had this issue.
My xj600 has seen 4 winters and barely gets cleaned or maintained, let alone the brakes looking it. Never had an issue.
My 2000 model zx6r was terrible for it with the 6pots, swapped them out for a set of gsxr1100 ( early 90's!) nissin 4 pots.... not had a problem yet!
I just used to use a small flat headed screw driver and brake cleaner to get rid of the white crap.
APT Motorcycles
Robby
Dirty Old Man
PostPosted: 07:47 - 14 Dec 2010    Post subject: Reply with quote
My 1997 CBR600 was quite furred up, I assume it hadn't been looked at for 13 years. Both of my 1980 CB250RSAs were very corroded, but may not have been looked at for 30 years. My 1999 CB500 feels like it needs a look at the next pad change.
I know Yamaha RDs can be quite bad for it, but it may just affect some models more than others. A good smear of red rubber grease around the piston will doubtless slow the process down considerably, and they need to be very corroded before the brakes start sticking. Also seems to be more of an issue on bikes that have been standing for a long time with old brake fluid in, and stainless brake line fittings should accelerate the process.
Try stripping your caliper and see. They may feel fine now, but feel much better after having the corrosion scraped out. Far more feel with no corrosion, but you need a lot of corrosion before it feels as bad as a worn pad slider pin.
DrDonnyBrago
PostPosted: 09:58 - 14 Dec 2010    Post subject: Reply with quote
My CBR was spotless behind the brake seals, dirty as feck behind the dust seals though. Use a ball of tissue pressed into the groove and wipe it hard the whole way round. Use something plastic if required to scrape out any remaining crud.
PostPosted: 10:53 - 14 Dec 2010    Post subject: Reply with quote
Seems to happen to most bikes. Charlottes Triumph Thunderbird is really bad for it (but is a doddle to strip down). The ZZR600, FZ750 and FZR600 are quite bad for it. Both the 600 and 1200 Bandits have been fine. Most Italian stuff doesn't seem to suffer.
PostPosted: 11:02 - 14 Dec 2010    Post subject: Reply with quote
I think Sickpup told me to run a dremmel with a wire wheel round the inside to clean it up. Make sure it is a brass wheel that won;t damage the ally. I'd get somebody to confirm this won't knacker your caliper though as my memory is fuzzy and he might have never said this. Laughing
PostPosted: 11:04 - 14 Dec 2010    Post subject: Reply with quote
Never done it myself but this is the way recommended by someone I know who does a hell of a lot of brake calipers. Brass is softer than the ally so shouldn't damage it.
MarkJ
PostPosted: 11:26 - 14 Dec 2010    Post subject: Reply with quote
I find a really small, like 1mm, allen key is good for getting the crud out. The angle of it helps as you don't have to angle a straight thing like a screwdriver in at funny angles to get all the crap out. Just don't press too hard.
DrDonnyBrago
PostPosted: 13:57 - 14 Dec 2010    Post subject: Reply with quote
They make stiff nylon wheels too, these would be my choice for use on aluminium.
I've used brass dremel wheels on aluminium bike parts before (not brake calipers though) and whilst they don't tear into it like a steel brush they do affect the surface. You end up with small dimples and a mottling in the surface of the aluminium, sometimes you get a brass colour transferred over too.
PostPosted: 14:09 - 14 Dec 2010    Post subject: Reply with quote
Worth trying the nylon brushes (probably easier to get than the brass ones) but not sure they would shift the compressed ally oxide.
Suntan Sid
PostPosted: 15:16 - 14 Dec 2010    Post subject: Reply with quote
When I did mine, I got the majority of the stubborn crud off with a bent piece of 2.5mm copper wire, carefully scraped around the groove.
For the final clean I soaked a plastic kitchen scourer in brake fluid and scoured away to my hearts content, came up nice!
https://christianhomekeeper.org/files/2010/04/scotch-brite.jpg
stirlinggaz
PostPosted: 17:45 - 14 Dec 2010    Post subject: Reply with quote
had this happen on a few bikes. (older ones, different makes)
now i just leave the caliper soaking in some solvent (paint thinners) or scrape out with a set of pick things (poundland, set of 4 or 5, hooked,angled,pointed etc - handy as f*ck),a good spray of brake cleaner & finish off with dremel & brass wire wheel.
the plastic/nylon bristled one started to melt,lol
cheers,
GAZ
Noxious89123
PostPosted: 21:58 - 14 Dec 2010    Post subject: Reply with quote
Bear in mind this is only the rear brake, the fronts are spot on Smile
It doesn't exactly stick on, but it's as if the seals stick to the piston and pull it back into the calliper body slightly when brake pressure is released. It means that the rear brake lever permanently feels "long" because every time the brake is applied the piston moves out slightly before it applies pressure on the pads.
As I said above, cleaning and greasing solves the problem temporarily, and it feels massively better for it.
Thanks for all the advice guys; it's all very much appreciated. Will post up with the results when I finally get around to sorting it, which won't be for a long while yet!
Karma
EDIT: Just another thought:
Does bottled brake fluid have a shelf life. I've got a bottle which is unopened. Probably about a year old. This is ok, right?
When reattaching the brake line to the calliper, should I use new sealing washers and/or banjo bolt? I'd imagine the banjo is reusable but that the washers are a case of "you don't have to but..."
Mrs Vale46
PostPosted: 22:39 - 14 Dec 2010    Post subject: Reply with quote
The way in which I clean all the brake calipers on all the bikes at my house is by taking them of and letting thm soak in hot soapy water ( use fairy liquid its the best I think lol) then using an old toothbrush and scrub away to ur hearts content.
I have given this advise to another brake/caliper problem sufferer hopefully its helpful as its the method I use on my nsr, my mum's fazer, my dads blackbird and the race bike. And its proven effective. Smile
Emma-Louise
PostPosted: 23:47 - 14 Dec 2010    Post subject: Reply with quote
The fluid should be fine as long as the bottle hasn't been opened. DO NOT shake the bottle of fluid before use (it will get air bubbles that will take ages to settle out, and which will make bleeding the brakes a pain).
You should use fresh copper washers. They are silly money bought a couple at a time but fairly cheap if bought in quantity.
Noxious89123
PostPosted: 00:15 - 15 Dec 2010    Post subject: Reply with quote
As I thought. Hel sell them for 52p each! Wemoto are much more reasonable at 18p each. I'll probably buy a pack of 10. Handy to have when you need them.
PostPosted: 00:23 - 15 Dec 2010    Post subject: Reply with quote
In bulk from a fastener supplier is probably cheaper.
Something like these is also possible (not 100% sure on the size of them though).
Robby
Dirty Old Man
PostPosted: 08:11 - 15 Dec 2010    Post subject: Reply with quote
I get my washers in bulk on ebay, usually 2 or 3 quid for a 20 pack. Individual ones are really expensive. Not as bad as buying individual sump plug washers though, particularly when you can buy a big pack of superior dowty washers for a couple of quid.
Noxious89123
PostPosted: 00:13 - 16 Dec 2010    Post subject: Reply with quote
Good to know, cheers guys Thumbs Up
The last post was made 15 years, 151 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Workshop via View All Topics All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 1.86 - MySQL Queries: 13 - Page Size: 131.81 Kb
