NSR RR DeRestriction Help
MrSplosha
PostPosted: 00:14 - 15 Dec 2010    Post subject: NSR RR DeRestriction Help Reply with quote
Right, just changed Jets, Sparkplug, Put in CI626 and Tv-78, there is a slight difference but the revs are still limited to 10.5k and the top end is still on 80, eventually :/ Any help guys would be appreciated, the only thing on my mind is that wires need to be changed on the CDI?
MrSplosha
PostPosted: 20:02 - 15 Dec 2010    Post subject: Reply with quote
Thank you all so much for your help.
Livefast123
PostPosted: 20:51 - 15 Dec 2010    Post subject: Reply with quote
Do you think that the NSR experts spend every minute online just in case you need a question answered Rolling Eyes Patience is a virtue
You don't say which country the bike is from which effects the method of derestriction.
You don't say on your post wether you've removed the restrictions in the exhaust or the intake, if not these are the first places to try.
If you've got a swiss bike then i'm sure that they are electronically restricted which is what the 'hard' 10.5 rev limit is however I don't have any experience of the swiss bikes as mine is italian Thumbs Up I think you need to swap wires on the CDI.
Wait for alains to come he is the NSR god
Current ride - Yamaha MT-07
alains
PostPosted: 10:35 - 16 Dec 2010    Post subject: Reply with quote
hi , first of all what's your serial number (between the yokes , begining by ZDCJC22...........)
then i will see
nsr_J22_FOXEYE
PostPosted: 13:51 - 16 Dec 2010    Post subject: Reply with quote
Dude not cool.
Be patient and the answers will come to you, I would offer help but alain is the man Very Happy
Never Ride Faster Than Your Angel Can Fly
MrSplosha
PostPosted: 16:15 - 16 Dec 2010    Post subject: Reply with quote
ZDCJC22, ive checked the exhaust earlier, no restriction, i did read your manual alains where it said about the wires having to be swapped over but i didn't really understand what which ones i got to swap and how?
Edit : No Air intake restriction either.
alains
PostPosted: 16:46 - 16 Dec 2010    Post subject: Reply with quote
see the joined pict , this will show how the terminals are locked in the connector . introduce one branch of a fine tweezers between the plastic and the terminal you want to undo , push in gently , while slightly pulling the wire , when the terminal is unlocked the wire will come with you . before refitting the terminal in the connector push out the small bit , then when the terminal will lock in you will hear a little click and if you try to pull the wire it's impossible . if it is your bit is not out enough or you havnt push enough the terminal in the connector . the wires to be crossed are the green and the black/yellow
warning !! if you do not cross the wires (if you change a CI639 by a CI626) your CDI will be dead within 4 days
MrSplosha
PostPosted: 18:45 - 16 Dec 2010    Post subject: Reply with quote
Just changed the wires over, no difference at all :/ :@ its really irritating me lol the ci626 n tv-78 have made no difference at all to the bike, im at a loss, any other ideas what it could be, it still only revs to 10500
BTW its ZDCJC22A which is the italian import? Did i even need to change the wires over or shall i change them back? Its also an X Reg.
edit : there is a sticker on the inside of the frame near the air box that says NSR RY, but its an NSR RR? has that got anything to do with it?
alains
PostPosted: 20:21 - 16 Dec 2010    Post subject: Reply with quote
A means it's italian import
RY means 2000 model
you must have your compression tested something less than 125Psi means you need a top-end rebuild
this bike supposed to be unrestricted except the exhaust pipe
the guide will be :
- first check your jets (look the pict about the carb in my file) you need main=138 or 140 , idle (slow) =42 , power=65
- buy carbon membranes here
https://cgi.ebay.de/JOllify-Carbon-Membrane-Honda-NSR-125-R-JC22-036-/120545879378?pt=Motorrad_Kraftradteile&hash=item1c11182552
- buy a couple plugs BR9EIX here
https://cgi.ebay.co.uk/KAWASAKI-KX80-C-R1-NGK-SPARK-PLUG-BR9EIX-3981-/200542620102?pt=UK_Motorcycle_Parts&hash=item2eb14589c6
- finaly you need a race pipe (best is jollymoto 402 & 403) ~£260
MrSplosha
PostPosted: 20:33 - 16 Dec 2010    Post subject: Reply with quote
Changed the jets the other day wen i changed the cdi, spark plug, pv controller and the throttle needle, i just dont understand how nothing at all has changed, do you think there is still a restriction in the exhaust? could there be one elsewhere in the exhaust because i took the whole system off earlier and there was no restriction
MrSplosha
PostPosted: 00:05 - 17 Dec 2010    Post subject: Reply with quote
I thought that putting the CI626 and the TV-78 in would derestrict the revs but its exactly the same, is there anyway i could have put it in wrong? Surely it wouldnt run at all if there was something majorly long, Its really depressing me, i hear about how fast they are etc and i've done everything necessary yet still no change? :@
alains
PostPosted: 10:51 - 17 Dec 2010    Post subject: Reply with quote
you've worked on something you didnt need
in fact your bike is unrestricted (CI626 & TV78 are already fitted), but you have a problem somewhere else
- have your compression tested (see your local mechanics)
- watch your servo-motor pulley and look if it's working as the pict shows in my file https://www.geneva-racing.ch/~alains/NSRtips.doc
bottom page #10
then give me the results
The last post was made 15 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 76.29 Kb
