 Dazbo666 World Chat Champion
 Posted: 14:24 - 15 Dec 2010 Post subject: Front end rumble |
I've recently noticed a slight vibration / rumble that I can feel thru the bars. I'm thinking maybe wheel bearings??
The wheels were balanced when I got the tyres changed, and I've checked the tyre condition (almost new), tyre pressure (just fine), brakes (new pads are less than half worn) etc and everything so far seems fine... but still from about 40mph the front end feels like I'm running over a fine corrugated surface.
So could it be the wheel bearings... or something else?? ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
 craigT19 Jolly Green Giant
 Posted: 20:57 - 15 Dec 2010 Post subject: |
Tbh sounds like somebody has done a poor job balancing your wheel. Poorly balanced wheel problems get worse as your speed increases a wheel bearing issue will be bad all the time.
You can simply check your bearing one of 2 easy ways.
1. With the bike upright put the front wheel between your legs and hold it there, then try and turn the bars and feel for free play.
2. Lift the bike up into the air on the side stand and lower it onto the back wheel, get somebody to hold it there. Hold the tyre and turn the wheel to full lock both sides. Once it's on each full lock try and twist the wheel past the lock stop and look and feel for free play.
Both ways work easy enough. ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
 Posted: 20:26 - 16 Dec 2010 Post subject: |
Cheers for the advice I may get the balancing re-checked elsewhere, and if that turns out to be the problem, my usual garage will lose a customer. ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
 Posted: 10:45 - 17 Dec 2010 Post subject: |
Don't be 2 harsh on them, it could just be summon stupid like a wheel weight not sticking properly and coming off. ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
