Bandit 650 K7 Won't start
hellzone
PostPosted: 09:38 - 16 Dec 2010    Post subject: Bandit 650 K7 Won't start Reply with quote
Hi All,
Got a 2007 Bandit, had from new.
Parked up last night - no problems, went to start this morning and the button doesn't do anything except turn the light off and back on, never had any starting problems.
Checked the battery voltage and it's hovering around 12.10 when ignition is off and 11.45 when ignition is on (drain from light)
Checked Fuses - all fine
No apparent warning on lights or display.
I'm guessing the button is working fine as the light is going out.
Is there a relay turning off the light? or is it switching off because the starter motor is drawing power?
Where can i find the starter relay?
Where can I find the solenoid?
Is there a way to test the starter motor and solenoid on the bike? or does it have to be off?
Thanks again
Kind regards
James
defblade
PostPosted: 12:12 - 16 Dec 2010    Post subject: Reply with quote
3 year old bike, 3 year old battery, very cold weather.... before doing anything complicated, I'd try jump starting it. If it fires straight up, you know the battery's died.
hellzone
PostPosted: 12:15 - 16 Dec 2010    Post subject: Reply with quote
Sorry I forgot to mention - the battery is 3 months old and there have been no signs of poor or sluggish starts, it starts immediately every single time
Paxovasa
PostPosted: 12:22 - 16 Dec 2010    Post subject: Reply with quote
Check the connections on the battery, give them a clean and make sure they are nice and tight.
Also put the battery on a charger as it may be low of charge. Thumbs Up
hellzone
PostPosted: 12:30 - 16 Dec 2010    Post subject: Reply with quote
Thank you for your advice, I'll give it a go but incase it doesn't work - any clues about the relay and the light questions?
Kind regards
James
PostPosted: 12:55 - 16 Dec 2010    Post subject: Reply with quote
Most new bikes switch off the light when the starter is pressed, to give the battery more juice, both of my do.
Put it on charge and try again, it sound to me like Alarm/immobilizer or clutch/side stand switch.
Paxovasa
PostPosted: 13:30 - 16 Dec 2010    Post subject: Reply with quote
Was their any noise when you pressed the starter button?
If it made a clicking noise then that would suggest the battery is to low to turn the starter but it would still have enough power to engage the lights.
hellzone
PostPosted: 13:33 - 16 Dec 2010    Post subject: Reply with quote
Absolutely nothing, i've tried several times and the only thing which happens is the lights go off (presumably via a relay)
Kind regards
James
Paxovasa
PostPosted: 13:38 - 16 Dec 2010    Post subject: Reply with quote
As chris red said "check the side stand and clutch switches". Thumbs Up
Raise the side stand and try starting it. Spray the switch with wd40 or similar as it may be sticking due to all the crud on the roads at the moment Thumbs Up
0l0dom0l0
PostPosted: 13:45 - 16 Dec 2010    Post subject: Reply with quote
Suzuki's need the clutch pulled in to start. It could be some water has got into the clutch switch?
If there isn't even a click or attempt from the starter motor, its more than likely going to be a 'safety' switch somewhere!
hellzone
PostPosted: 14:05 - 16 Dec 2010    Post subject: Reply with quote
I think I'm in love with you all, Center stand switch doesn't stop it but I looked closer into the Clutch Lever switch and what do you know? it fires up again Smile
Thank you so much!
PostPosted: 16:12 - 16 Dec 2010    Post subject: Reply with quote
I said it first and got no Karma Crying or Very sad
hellzone
PostPosted: 16:16 - 16 Dec 2010    Post subject: Reply with quote
You did, i have also rated you Wink
The last post was made 15 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 75.54 Kb
