How do I unflood a Suzuki bandit engine?
damien600
PostPosted: 14:21 - 17 Dec 2010    Post subject: How do I unflood a Suzuki bandit engine? Reply with quote
Hi.
Can anyone help me I will be very grateful. I have a 1996 Suzuki bandit 600 and I think the engine is flooded how do I unflood it?
Thanks.
cb1rocket
PostPosted: 14:24 - 17 Dec 2010    Post subject: Reply with quote
take the plugs out is the best way then crank the engine over.
Generally if you have flooded the engine then the other way would be to turn off the fuel tap and open throttle wide open to remove the excess fuel.
As said first you better off taking out the plugs and giving them a clean because they will be totally fouled.
Has it been running rough? Miss-firing? Maybe time for new plugs
defblade
PostPosted: 14:27 - 17 Dec 2010    Post subject: Reply with quote
Take the spark plugs out and wait for the petrol in the cylinders to evaporate. Normally, waiting 10 mins is enough but if it's outside and you've got freezing temps, this can take ages (days or even weeks with the plugs in!).
If you want to speed things up a bit, use hot air (not any sort of flame Evil or Very Mad ) directed gently down through the hole; make sure you're in a well ventilated area for god's sake and no 'aving a fag while you're at it Rolling Eyes
You can also (some distance away) use a blow torch to dry off the business end of the plugs and warm them a bit before putting back together and trying again.
PostPosted: 14:51 - 17 Dec 2010    Post subject: Reply with quote
By the time you have stripped down to the plugs the fuel would have probably evaporated just leave it for a while.
Ichy
PostPosted: 14:52 - 17 Dec 2010    Post subject: Re: How do I unflood a Suzuki bandit engine? Reply with quote
What do you mean by flooded? Do you think fuel has poured into the cylinders or is it just that it won't start?
If its the second then just take the plugs out, give them a good clean, warm them up and put them back in.
PostPosted: 15:02 - 17 Dec 2010    Post subject: Reply with quote
Classic for a flooded engine is fuel off, choke off, throttle wide open and crank it until it either fires up or you are convinced it has cleared itself out. Or go inside, make a cup of tea, have a fag and try again once you've drunk the tea.
If you mean you think it has fluid locked (been lying on its side or similar and totally filled one or more barrells with fuel/oil), take the plugs out and crank it over a couple of times. Don't lean over the top of it when you do so. Then check the oil for fuel contamination and level.
Paxovasa
PostPosted: 15:33 - 17 Dec 2010    Post subject: Reply with quote
Just leave it for 10 mins Thumbs Up
Rogerborg This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
Paxovasa
PostPosted: 16:05 - 17 Dec 2010    Post subject: Reply with quote
Rogerborg wrote:
Set fire to it and use the insurance money to buy a bus pass - bikes are too complicated for you.
It is a suzuki, fire will not kill it. Water on the other hand will Wink
PostPosted: 16:47 - 17 Dec 2010    Post subject: Reply with quote
I read the first sentence and though 'AHA make a suzi rot funny' but you beat me too it.
The last post was made 15 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 64.79 Kb
