HID Kits
rac3r
PostPosted: 23:07 - 18 Dec 2010    Post subject: HID Kits Reply with quote
I was thinking about doing some useful mods to my bike like the Tutoro oiler like Titz mentioned and also HID's.
At the moment I have those fake HID bulbs off ebay Laughing which are OK surprisingly. My question is how hard are they to fit? What's involved? Also those of you that have them what do you think?
I'd like to install the projectors too but it involves baking the headlight Shocked
Chequered Flag
cb1rocket
PostPosted: 23:15 - 18 Dec 2010    Post subject: Reply with quote
I just got a kit off ebay from china so I'm down the same route of waiting to fit them but mine is the H4 type with pants more wiring! Its the Hi/Lo version.
Probably end up using them on a CG rather than my CB1.
Not used a TUTORO but I have used a loobman to good effect and they do work. Thumbs Up
dragstaar
PostPosted: 23:58 - 18 Dec 2010    Post subject: Reply with quote
I've got a HID kit for my Bandit which I ordered on Ebay. if you contact them and ask them to send it without the box they'll reduce postage. And get them from a UK seller, you have far better communication.
HID's are the bees knees. I don't know how i did night riding without them.
Few things to remember, Fitting a conversion kit (a retro fit) is illegal, HIDs are friggin' bright so need to be aimed properly so as not to blind people. This is why you need the whole headlight unit with auto-levelling etc, which is considerably more expensive. If you do get HIDs, then just make sure they're aimed properly.
Heres the legal shebang if you want https://www.dft.gov.uk/pgr/roadsafety/drs/hidheadlamps
They are dead easy to fit. You literally have a circuit.
The circuit isn't massively clear, but you have the HID bulb which connects to a transformer/ballast, which supplies the 12,000volts needed to ignite the bulb. The bulb will then settle at a much lower power consuption within a minute or so. There will be a plug from the ballast in which to connect the bike's bulb connector. So treat the ENTIRE HID unit (wires, everything) as a bulb, and just plug it in!
Your next thing to consider, are the temperature of the Bulbs. Anything up to 4300k are yellowy, and get brighter as you go up. 4300k is the brightest bulb, and is pure white.
https://i1138.photobucket.com/albums/n521/dragstaar/hid.jpg
Anything higher than 4300k gets dimmer again, but has a bluey tint. I have 6000k because they are bright enough, and they have that tart's blue Smile
HID bulbs have no filament, they create an arc of light by igniting the Xenon gas. This requires a huge amount of power, which the Ballast provides, then settles, and uses less power than a standard halogen bulb.
The hardest part is finding somehwere to mount the ballast. I advise getting the slimline ballast (well worth it for the extra fiver or so) as this widens your options for mounting. Good velcro will easily hold it in place.
rac3r
PostPosted: 00:42 - 19 Dec 2010    Post subject: Reply with quote
Cool. A couple of questions: my bike has low beam on the left and high on the right, do I need a full kit of 2? Also is it just plug and play then? Difficulty out of 10? Laughing
Thanks
Chequered Flag
dragstaar
PostPosted: 01:02 - 19 Dec 2010    Post subject: Reply with quote
Yup, same as mine. that makes it so much easier.
Don't fit a HID to your main beam. It doesnt work well. Because you'll use your main beam for flashing etc, it'll kill your battery. it'll draw 12,000v every time you hit that passing light. Stick to just the dipped beam. Trust me, its bright enough Wink
Fitting, honestly, is decievingly daunting. It seems like a complicated task, but its piss easy. When you get the kit, put it together indoors. I'd be very worried about the state of your mental health if this took more than 3 minutes, as in actually, if you take more than 180seconds putting it together, you need to see a doctor. Its that easy. (IF, you get the better quality plug connector ones. most of them are, anyway). all you do is clip the wires together in a logical order (they wont fit any other way lol).
Once you've done this, everything will be connected to something, other than one plug, which goes into your headlight connector. (this is why you must buy the correct one, i.e. h4, h7, 9006 etc)
The hardest part is figuring out where to shove the ballast. I have a fairing on my bike, so i stick it in there, nice and dry in there too, but not too near anything hot. Then i just wire the calbes along the frame, and connect it up.
What i advise, is before sticking it in, just keep everything out, and just connect it, to see if it works!
I'd say difficulty: 1. Seriously
Effort: 4, because you need to figure out a suitable spot, and maybe take fairings off.
rac3r
PostPosted: 01:07 - 19 Dec 2010    Post subject: Reply with quote
Thank you very much! Thumbs Up
Reading that link you gave means they're not strictly legal are they? Laughing But I can't see you getting done unless they're aimed stupidly
Chequered Flag
The Tot
PostPosted: 02:21 - 19 Dec 2010    Post subject: Reply with quote
Rac3r, do a search post for HID's under my name and there's some useful info there. I gave Dragstaar some advice on his, my suggestion is to use the same seller as us - hids direct off ebay.
They're NOT legal but they are VERY effective in winter and low light conditions. It's literally plug in and play if you're installing H7's.
4300K is ample. 6000K was bling enough for my old ninja. Went for 4300K on the blade because I wanted crystal white light.
My Osram Night Racers are those 90% jobbies (filament bulb) and i would say they're about 3800K because whilst it MAY look silvery compared to normal filament bulbs, they are still yellow by comparison to even 4300K's! Stick one of these as your high/main beam and you're laughing - very long & strong beam.
Never argue with autism
weasley
PostPosted: 12:03 - 19 Dec 2010    Post subject: Reply with quote
Strictly speaking, the xenon gas is ionised, not ignited. Wink
Good useful info here though. And the law on these is unclear; the intent is that they are illegal but it would appear to be very difficult to actually prove this.
PostPosted: 15:57 - 19 Dec 2010    Post subject: Reply with quote
While HIDs are technically regarded as illegal now, it seems that next year the MOT is being changed to make having the dodgy conversions being an automatic failure (and doing the job properly would mean self leveling, self cleaning system and all the appropriate markings on the light).
PostPosted: 16:37 - 19 Dec 2010    Post subject: Reply with quote
rob yarrr wrote:
fml,when they bringing this in keith ?
Next year....
rac3r
PostPosted: 16:54 - 19 Dec 2010    Post subject: Reply with quote
I might have to ask the MOT dude at work and see what he says
Chequered Flag
PostPosted: 18:02 - 19 Dec 2010    Post subject: Reply with quote
Seems to be due in time for 2012. Whether that is 1st Jan 2012 or some times earlier I have no idea.
Page 8 of this has a brief note:-
https://www.dft.gov.uk/vosa/repository/MoT%20-%20Issue%2048%20-%20Oct%202010.pdf
HID kits will come under 'headlamp bulb and unit incompatibility, headlamp levelling devices"
motobiker
PostPosted: 20:21 - 19 Dec 2010    Post subject: Reply with quote
MYTH ALERT !!!
Changes to the MOT relating to after market HID fitment.
CARS ONLY. Thumbs Up
The problems with HID that these changes to the MOT are designed to address simply do not apply to Motorcycles.
where.. adjustment to aim is simple.
and self cleaning is not necessary.
Current rules will not change as far as bikes are concerned.
1999 R1100GS + 2006 F800S
(Nottingham)
Sooner or later opinions fade and the name on the tank matters not. I think that happens somewhere between 3rd and 4th gear. Enjoy the ride... everything else takes care of itself.
dragstaar
PostPosted: 20:41 - 19 Dec 2010    Post subject: Reply with quote
The Tot wrote:
everything that Dragstaar knows
Seriously Rac3r, this is the man to direct all your questions to. He helped me out loads, and gave me all the directions when i fitted mine, and i was (and some will say still am) a noob when it comes to HIDs
The seller we used is on the link in the thread where tot helps me out loads with my HIDs
let us know how it goes!
PostPosted: 20:49 - 19 Dec 2010    Post subject: Reply with quote
We will see, but as bike headlights are far more difficult to adjust than cars and probably far more likely to be affected by passengers I see no reason why it won't apply to bikes.
All the MOT change is doing for HID light is bringing the MOT into line with what is already not legal and there seems to be no separate and different set of regulations for the use of HIDs on bikes than cars.
dragstaar
PostPosted: 20:55 - 19 Dec 2010    Post subject: Reply with quote
At the moment the beam needs to fall within the set guidelines, must not be over 6000k in temp. And when retro fitting them (most new BMWs come with them factory fitted, these are ok) you can't use a conversion kit, you need the whole shebang. Namely, whole headlight unit with projectors and autolevelling etc etc. Its all on the link above
yandy_yay
PostPosted: 21:01 - 19 Dec 2010    Post subject: Reply with quote
well i've had HID since i got the bike, was nearly the first mod i did, but i didn't touch the exsisting wiring so when it comes to MOT i just pop the lamp out cable-tie the wires out the way, stick a normal H$ bulb in, and pull the fuse for the HID balast box. they aint never said anything about it Thumbs Up soon as i've got the green ticket i just pop the hid lamp back in jobs a good un.
past bikes: (20 years ago) cg-125 (wriiten off), C-50 (thrashed n' finnaly scrapped), CZ-125 (nicked - never recovered, insurance payout was more than i paid for it !!!)
Current bikes: GN 125(now sold), Divvy 600s.
PostPosted: 21:05 - 19 Dec 2010    Post subject: Reply with quote
rob yarrr wrote:
whats the actual regulations for HIDS atm ? to pass the MOT
Nothing special currently. As long as the beam checks out as OK and the colour is close enough to be regarded as white then it should be OK.
Passing an MOT and what is actually being legal are different.
motobiker
PostPosted: 21:18 - 19 Dec 2010    Post subject: Reply with quote
The link is all about CARS.
The EU Directive that has brought this all about is ONLY about cars.. nowhere does it mention motorcycles. Not in the main part.. nor in the addendums.
Doesn't bother me either way.. I don't have HID on my antique.
However.
The changes to the MOT are already in the hands of the testers... despite it being a year away. The biggest problem for them is identifying CARS that have chipped ECUs... which will be an automatic fail. thats causing a bigger buzz than HID. And may in fact be such a big problem that the changes may be pushed further back in time... a year to prepare not being long enough.
as has been said.. ask the tester. if he is a bike only man.. don't be surprised if he gives you a puzzled look.
(Nottingham)
PostPosted: 21:37 - 19 Dec 2010    Post subject: Reply with quote
The EU directive is here:-
https://eur-lex.europa.eu/LexUriServ/LexUriServ.do?uri=OJ:L:2010:173:0047:0072:EN:PDF
It doesn't mention motorcycles or cars. It applies to vehicles.
rac3r
PostPosted: 22:30 - 19 Dec 2010    Post subject: Reply with quote
Yep all the advice from Titz has done me well so far, even directed be to right place to train for my test and it worked!
If I get them I'll post up in my thread in the gallery Thumbs Up
As for MOT I can see it being similar to having a race can on the bike....
Chequered Flag
The last post was made 15 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 139.71 Kb
