Clutch cable snapped...
benandthe
PostPosted: 21:19 - 28 Dec 2010    Post subject: Clutch cable snapped... Reply with quote
Great, the bloody clutch cable snapped on my way to my cousins house, I got stuck about 5 miles from home, had to crunch the bugger through the gears.... Not a good evening. Luckily everything should be open again tomorrow and hopefully I can get a new cable!
I hope......
What's the best way to maintain the cable, when I get it replaced?
Cheers guys. Smile
Paxovasa
PostPosted: 21:21 - 28 Dec 2010    Post subject: Reply with quote
You need to learn how to do clutchless gear changes. Thumbs Up
make sure you lube the cable and adjust it when required.
kingsknight
PostPosted: 21:23 - 28 Dec 2010    Post subject: Reply with quote
The blood from baby pandas is the best way to maintain the cables on your bike!
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
PostPosted: 21:27 - 28 Dec 2010    Post subject: Reply with quote
Replace it yourself, its an easy enough job. Oil the cable first and dont be so hard on the clutch.
I went through 2 GSXR750 clutch cables due to constant use around town to and from work. Not fun. Glad I now have hydraulic clutch
rac3r
PostPosted: 21:30 - 28 Dec 2010    Post subject: Reply with quote
How can you even ride without the clutch won't it just stall?
Chequered Flag
yen_powell
PostPosted: 21:33 - 28 Dec 2010    Post subject: Reply with quote
If you rev the engine, push the bike forward with your feet then knock it into gear you can pull away. It's a fine line though, stalling or a wheelie are also a possibility.
XT1200Z and a DR350 in bits
benandthe
PostPosted: 21:36 - 28 Dec 2010    Post subject: Reply with quote
Exactly how I did it, I worked on the principle of if you can bump start it by rolling it and dropping the clutch, then it should work by rolling with the engine on and dumping her in 1st. Very Happy
And I don't know if I can even get a hydraulic clutch set up for my bike....
PostPosted: 22:35 - 28 Dec 2010    Post subject: Reply with quote
It can be done. But as said above, Touch and go with stalling or moving. Not good for the clutch either I hear. I managed to limp home the few miles when mine broke.
PostPosted: 23:02 - 28 Dec 2010    Post subject: Reply with quote
Clutch cable is an easy swap. If you can't get one to fit straight away, you can try an emergency cable kit that'll let you bodge up a new inner until you can get a replacement.
This is the Mito that you swapped your shagged out CBR for, right? Well, karma certainly has a sense of humour. Thumbs Up
johnsmith222
PostPosted: 23:04 - 28 Dec 2010    Post subject: Reply with quote
Try and plan your route so that you stop as little as possible. If you do have to stop either. If you have to stall, do it on a hill.
Get the bike into neutral, with the killswitch to the off position. once rolling at a fast speed, click it into first and turn the killswitch on with the ignition turned on.
after that you're sorted.
If safe to then consider running a red light. The most important thing is your safety. Many junctions are not safe to even consider doing this. Normally left turns are safe, provided you can see that there is nothing coming. Closed junction left turns could be dangerous.
Or you could always just make sure the cable is well lubed. Always keep a spare clutch cable in your garage.
yen_powell
PostPosted: 23:08 - 28 Dec 2010    Post subject: Reply with quote
Buy two cables. Tape them together, cover the two ends of one of them with duct tape to protect the inner from the weather.
Feed them both through the frame, engine and handlebars as you would a single cable. Connect the uncovered cable and now you have a spare already in place if it ever happens again. It''l now only take moments to swap the ends over once you have removed the duct tape.
TanacoiusD This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
evoboy
PostPosted: 23:27 - 28 Dec 2010    Post subject: Reply with quote
I thought you werent meant to lube the nylon lined cables as it makes them swell up?
I find the cables normally snap at the lever end where the build up of crap eats through the cable.
APT Motorcycles
comfortably_numb
PostPosted: 00:59 - 29 Dec 2010    Post subject: Reply with quote
I`m a great believer in buying 2,1 for now,1 for a spare.When setting of for the day,in My case,up in the Dales,I always chuck a few spare bits in My rucksack.
Its not happend to Me yet,but can You amagine how smug You would feel if You were out with Your mates,cable goes,You park up with Your Pals saying "Or thats fucked things up hasnt it ",and You just pop one out your bag,bang it on,then tare of popping a wheelie with a big bastard smile on your face,,,,
Well,,thats how I see it anyroad..
cg125 sold,bandit600 sold,drz400 sold,gsx750f summer,gn125 winter.
benandthe
PostPosted: 12:47 - 29 Dec 2010    Post subject: Reply with quote
Yup, exactly what's happened here.
Nowhere stocks mito cables, so gonna have to order online and hope they get to me before the weekend when I have work next... :s
Souleh
PostPosted: 14:54 - 29 Dec 2010    Post subject: Reply with quote
Take yours down to the shop - theres bound to be something suitably similar.
I have 2 spare zx6r ones here now thanks to an ebay muck up.. feels good t have backup. Horrible thing to snap mid ride!
Robby
Dirty Old Man
PostPosted: 15:30 - 29 Dec 2010    Post subject: Reply with quote
Good luck getting cables for it. Have a look in the back of motorcycle mechanics magazine, there could be a place that will make up cables for you for a reasonable price.
Last time I looked at the price of cables for an obscure cagiva they were about £30 each, with a 6 week wait to get them.
Imonster
PostPosted: 16:20 - 29 Dec 2010    Post subject: Reply with quote
Wemoto seem to have them in stock for £15-£17, depending on which one he needs.
Those who make peaceful revolution impossible will make violent revolution inevitable.
benandthe
PostPosted: 16:25 - 29 Dec 2010    Post subject: Reply with quote
Got a call from Rob at mito mondo, he could have it to me by the end of the week... lol and for £14
Anyway, it doesn't matter now, luckily the end that snapped had a bit the unscrewed and i simply cut off and tidied up the split end and pushed it back through.
Easy-peasy.... a little bit too easy for my liking, but it's fixed! Very Happy
Ed Case
PostPosted: 16:58 - 29 Dec 2010    Post subject: Reply with quote
I've had three Laverdas and they're notorious for busting clutch cables.The answer I found was that at least once a year remover the cable from the handlebar lever, bodge a good blob of grease in the hole where the barrel on the end of the cable fits in and then re-assemble. These cables almost always break at the first 2/3mm from the nipple usually because the barrel nipple isn't free to turn in the lever hence fatigue sets in and 'pop' goes your cable.
tutton
PostPosted: 18:51 - 29 Dec 2010    Post subject: Reply with quote
A reccomendation here to venhill, they do made to measure lines, send em your old and theyll make a new and uprated one for you at a decent price and fast delivery, can change the colour outer case of the cable with no price difference!
benandthe
PostPosted: 19:25 - 29 Dec 2010    Post subject: Reply with quote
Ah, the bugger went again..... Sad
I've ordered a new one though with purple hosing. Very Happy
It's coming up to the new year, and once it hits new year I'm going to set about re-spraying the bike. Very Happy
It's going to be beautiful. Smile
salty21
PostPosted: 20:09 - 29 Dec 2010    Post subject: Reply with quote
you strike me as the kinda guy who likes to live life right on the edge Laughing
The last post was made 15 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 128.31 Kb
