| loukas |
 loukas L Plate Warrior
| P.addy |
 P.addy Red Rocket
 Posted: 20:04 - 29 Dec 2010 Post subject: |
cant even read that on my phone.
Maybe using full stops and the enter button is the best advice! |
| iooi |
 iooi Super Spammer
1st bit of advice.... This forum has a workshop section designed just for this type of thing....
I'm assuming when you say 14V that is with the engine running. If not then check the zero on the meter. You should be seeing less than 13V on a std battery and only 14V if the engine is running.
I would also guess your bike runs total loss system as such it needs the engine running to power any eletrics such as lights etc.
Could well be that they have fucked the battery when they stole the bike.
Fix the switches, change the battery and all should be OK. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| fiery tupp |
 fiery tupp Trackday Trickster
 Posted: 20:10 - 29 Dec 2010 Post subject: |
I would go for battery, either run down or damaged ( shorted ) when the thieving arsewipes have been ragging it about ?  ____________________ If you can't fix it with a hammer , use your head . |
| loukas |
| Toothless Jack |
 Toothless Jack Banned
| P.addy |
 P.addy Red Rocket
| Toothless Jack |
| ms51ves3 |
 ms51ves3 Super Spammer
| P.addy |
 P.addy Red Rocket
| loukas |
| iooi |
 iooi Super Spammer
| Toothless Jack |
| P.addy |
 P.addy Red Rocket
| loukas |
| iooi |
 iooi Super Spammer
 Posted: 22:22 - 29 Dec 2010 Post subject: |
Not enough power in the battery.
It takes a lot out of a battery to not only turn the engine over, but also to power the plug to spark the engine. If your is dropping to 7V with just a light on, then its not got enough juice to turn the starter, let alone spark the plug.
You could hook it upto a car battery and jump start it.
Or bump start it.
Put it in 2nd gear and push the bike with the clutch in, then release the clutch to start.....
Just remember to pull the clutch back in as soon as it fires up if you are not sat on the bike or it will be off on its own
Sorry if you already know how to do that, but many people don't  ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| tutton |
 tutton World Chat Champion
| loukas |
 Posted: 01:02 - 30 Dec 2010 Post subject: |
| tutton wrote: | | iooi wrote: | Not enough power in the battery.
Or bump start it.
Just remember to pull the clutch back in as soon as it fires up if you are not sat on the bike or it will be off on its own Sorry if you already know how to do that, but many people don't  |
Dont quote me on this but if my brain serves me correctly the op's is a moped - aprillia sr50 no gears so no bumpage! |
Yeah it's not a geared bike, will try charging the battery tomorrow and see how that works, nice one for the advice though all of you. |
| P.addy |
 P.addy Red Rocket
 Posted: 08:48 - 30 Dec 2010 Post subject: |
Well, just to sum up, give it a full charge.
Should register roughly 12.2 > 12.8 I think, anything after a full cahrge around there is alright??
When its on the bike, turn ignition on, if your lights come on at the same time then that may draw some current...but it should remain the same if not.
When you crank it over it should start if the bikes not busted in any way, if it does when its running, you should see 14v~
If its working fine then all you needed was a recharge, if the battery starts giving up again, its on its way out.
Hope you fix it. |
| loukas |
 Posted: 15:26 - 30 Dec 2010 Post subject: |
| ##Paddy## wrote: | Well, just to sum up, give it a full charge.
Hope you fix it. |
Cheers mate it's on charge now, fingers crossed. |
The last post was made 15 years, 266 days ago. Instead of replying here, would creating a new thread be more useful? |
