speedo broke
minesweeper
Whoah there!
PostPosted: 12:14 - 16 Aug 2002    Post subject: speedo broke Reply with quote
My speedo needle is no longer spinning around Sad went out for a hack half way through it jsut went to 0 now wont move even at redline in 6th Rolling Eyes what could be wrong gents? the cable?
matt
TiN
Pocket Tin
PostPosted: 12:18 - 16 Aug 2002    Post subject: Reply with quote
heh...I have the same problem! Very Happy...except that I probably cause it, 'cos I took it apart in the first place Rolling Eyes
Anyhoo, to check your speedo cable, simply unplug it from your clocks, and then watch the end of the cable whilst moving your bike forwards/backwards. If the cable is ok, then the cable should rotate.
Alternatively, you can just go a ride, and keep an eye on your Odo/tripmeter.
TiN
dotgems.net
minesweeper
Whoah there!
PostPosted: 12:19 - 16 Aug 2002    Post subject: Reply with quote
My trip meter, that i use for fuel isnt moving either
Joe Camel
PostPosted: 00:27 - 17 Aug 2002    Post subject: Reply with quote
check the wheel end chaps, if the cable is intact possible cause is the drive tab has broken off in the hub, if so, hmmmm problem. Need hub drive,
CYA Sad
***THE VOICES MADE ME DO IT***
***NOT STOCK & TWO SMOKIN BARRELS***
EuropeanNC30R...
Gay Hairdresser
PostPosted: 00:28 - 17 Aug 2002    Post subject: Reply with quote
that happened to me, the speedo was reading less and less until it was permanently on zero and the tripmeter wasnt working. I found the speedo gearbox had given up.
Dylan
PostPosted: 11:14 - 17 Aug 2002    Post subject: Reply with quote
Take the speedo cable off at the bottom and attatch a drill to it. Start the drill and if the needle moves then you know its the gear thingy in the hub.
Dyl
The last post was made 24 years, 74 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 46.33 Kb
