Cold petrol??
st3v3
PostPosted: 14:09 - 03 Jan 2011    Post subject: Cold petrol?? Reply with quote
Odd one here, I haven't had the bike running for a couple months and it used to start normally after 30 kicks or so... Laughing
But now its different.
There is a very good spark from plug.
Battery is healthy and not an issue anyway.
Coil is connected (hence spark).
Petrol is flowing and adequate - but nothing.
Now, when i sit the plug on the cylinder head it sparks and the compression is very good but nothing, is the petrol too cold to 'make boom'? it's not flooded either, well not really. Thumbs Up
Paxovasa
PostPosted: 14:15 - 03 Jan 2011    Post subject: Reply with quote
Are you sure petrol is getting through.
Petrol will be ok.
st3v3
PostPosted: 14:24 - 03 Jan 2011    Post subject: Reply with quote
Yep, had fuel system apart, carb off and checked bore/reeds.
There is traces of petrol about and all the ingredients of a running engine are there; it's just not running. Crying or Very sad Laughing
Paxovasa
PostPosted: 14:30 - 03 Jan 2011    Post subject: Reply with quote
Take the plug out, clean it, warm it up, put a little petrol in the plug hole, put the plug in and see if it fires up. Thumbs Up
Ichy
PostPosted: 14:35 - 03 Jan 2011    Post subject: Reply with quote
take out the air filter and spray easystart, or similar*, in there while cranking it over, it may take two people.
If it fires then you know its likely to be fuel related. If it doesn't fire then its something else.
*I've heard of people using wd40, hairspray, and even lighter fuel to similar effect, it may work but I'm not going to try it Laughing
st3v3
PostPosted: 14:38 - 03 Jan 2011    Post subject: Reply with quote
Iv tried deodorant; not much joy but im gonna buy some easy start today, might help with the car later too.... Thumbs Up
Ichy
PostPosted: 14:40 - 03 Jan 2011    Post subject: Reply with quote
I'll add that to the list Laughing Laughing
Did you try lighting the spray before you sprayed it in the carb?
reckless_b
PostPosted: 17:51 - 03 Jan 2011    Post subject: Reply with quote
your petrol may have "gone off" these days petrol seems to go off rapidly if left, I had a kawa gt550 and if stood for about 2 weeks it would run like a pig untill it had some fresh, only today I've pulled my 600 yam radian out of the garage to have a de-stessing ride,back to work tomorrow, and this too ran poor, its been stood a few months, it would only run if it had at least half choke, it felt as if it was only running on 2 or 3,I too checked all the usuals spark etc, finished off by draining the tank, I'll give it a gallon of fresh tomorrow and see if it clears. By the way, I'd suggest draining the carbs as well, usually a drain screw on the float bowl.
40 years on the road on and sometimes off bikes with a very recent OFF
Teflon-Mike
tl;dr
PostPosted: 18:26 - 03 Jan 2011    Post subject: Reply with quote
Also if you haven't run the bike since October, when did you last put petrol in it?
Sounds daft, but you probably are on the right lines.
Each year, around Octover, they change the petrol at the pumps from 'Summer' formulation to 'winter' formulation....
strange but true. Google it, you'll find its actually a legal requirement!
Sumemr formulation is less volatile, so it doesn't evaporate as badly in summer warmth.
Winter formulation is less volatile against carb-icing.
Old petrol goes stale, and if its the wrong season formulation, and a poor cold-starting bike, MAY be the problem.
Drain tank, slosh some new (fresh from the pumps) petrol in it, see what happens.....
drzsta
PostPosted: 18:38 - 03 Jan 2011    Post subject: Reply with quote
i would think it's carb related, jets clear?
Scalli This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
temeluchus
PostPosted: 18:45 - 04 Jan 2011    Post subject: Reply with quote
I've found a good trick is putting your spark plugs in the oven, getting em good and hot, will almost always revive a non starter provided there are no drastic faults.
Teflon-Mike
tl;dr
PostPosted: 22:07 - 04 Jan 2011    Post subject: Reply with quote
Yes, age old 'trick'.. used to have to make sure my gran was out the kitchen before I tried it though!
Bit of caution needed, though. First picking the hot spark plug up to put back in the engine can scorch skin. Dont laugh!
Picking hot spark-plug up with pliers, you can easily crack the ceramic insulation. If you haven't already, dropping it on the tiled kitchen floor, after pulling it out and juggling it like a hot potatoe!OK, laugh!
Getting 'Smart' after scorching fingers, cracking cerammic etc, leaving plug in the plug-socket, while heating, so you can luft it out with the extension bar..... CAN melt the little rubber grippy thing inside the plug socket....
If your gran doesn't smell the lingering odour of evaporated petrol when she goes to stick the roasies in the oven..... she will the acrid stench of scorched rubber!
temeluchus
PostPosted: 22:35 - 04 Jan 2011    Post subject: Reply with quote
amateur!
thats why you use a long reach socket with some bog paper stuffed in it not a plug socket.
PostPosted: 11:14 - 05 Jan 2011    Post subject: Re: Cold petrol?? Reply with quote
No. Cold petrol's actually good for moar powahhhhh since it's denser.
Paxovasa
PostPosted: 11:58 - 05 Jan 2011    Post subject: Re: Cold petrol?? Reply with quote
Also cold air helps give the bike more bang, up until carb icing happens Razz
Chalky.
PostPosted: 12:12 - 05 Jan 2011    Post subject: Reply with quote
You could try firing up a blow torch and aiming the flame through though hole in the open tank lid?
Should warm it up.
Paxovasa
PostPosted: 12:19 - 05 Jan 2011    Post subject: Reply with quote
Should warm it up.
I prefer to use a cigarette lighter, to check if there is any fuel in the tank Wink
Chalky.
PostPosted: 12:42 - 05 Jan 2011    Post subject: Reply with quote
That's a possibility, but my mummy doesn't let me play with lighters Sad
PostPosted: 14:25 - 05 Jan 2011    Post subject: Reply with quote
Paxovasa wrote:
Should warm it up.
No, petrol vapour is heavier than air, so you have to turn the tank upside down before lighting up. SCIENCE! https://www.oceansofosyrus.com/forums/public/style_emoticons/default/NerdSmiley.gif
Wilson12345 This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
chrisjpartrid...
PostPosted: 18:02 - 05 Jan 2011    Post subject: Reply with quote
Easystart is good stuff though some say that it's bad for the engine over time.
As it's VERY highly combustable the engine will run on the stuff alone for a few seconds. This means you get some initial heat, but more importantly as the engine is "running" it'll burn any excess fuel and draw more fuel through to continue.
It's also good for testing a block as you can spray it into the cylinders without a carb even being fitted and the engine will run breifly.
I used to have a MK2 Golf diesel that I used to start up by spraying cheapo deoderant into the air intake - Worked there, but that was an engine with high compression so I guess anything that burns would get it going!
I'm not sure how that'd go on a 2 stroke but if in doubt Easystart is king* (*But it may kill your bike in time and is no sustitute for sorting the problem out properly later).
The stale fuel story rings true too, as does the fact that machines don't like resting for too long.
When I get my Lawnmower out for the first time every year I have to clean it out and use a little easystart to get it going, but after this it's good for the season.
st3v3
PostPosted: 13:21 - 06 Jan 2011    Post subject: Reply with quote
Wilson12345 wrote:
Yes, the petrol is too cold that's why the engine isn't starting Thinking
Would you care to either be constructive or post your idiotic rubbish elsewhere?
Thanks Wub
st3v3
PostPosted: 13:27 - 06 Jan 2011    Post subject: Reply with quote
Scalli wrote:
If normal is 30 kicks I would say there is something else amiss there
30 kicks is,.. Average on first start.
Once its running, it 'restarts' first time; everytime. But getting it goings usually a task. Im going to drain all fuel out and start from scratch.
The last post was made 15 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 134.73 Kb
