| st3v3 |
 st3v3 Super Spammer
 Posted: 14:09 - 03 Jan 2011 Post subject: Cold petrol?? |
Odd one here, I haven't had the bike running for a couple months and it used to start normally after 30 kicks or so...
But now its different.
There is a very good spark from plug.
Battery is healthy and not an issue anyway.
Coil is connected (hence spark).
Petrol is flowing and adequate - but nothing.
Now, when i sit the plug on the cylinder head it sparks and the compression is very good but nothing, is the petrol too cold to 'make boom'? it's not flooded either, well not really.  ____________________ Roger wrote: Women don't get damp for clingy puppies. Get some better happy pills, hit the gym & buy a medallion the size of a dinner plate. Job done |
| Paxovasa |
 Paxovasa World Chat Champion
| st3v3 |
 st3v3 Super Spammer
 Posted: 14:24 - 03 Jan 2011 Post subject: |
Yep, had fuel system apart, carb off and checked bore/reeds.
There is traces of petrol about and all the ingredients of a running engine are there; it's just not running.  ____________________ Roger wrote: Women don't get damp for clingy puppies. Get some better happy pills, hit the gym & buy a medallion the size of a dinner plate. Job done |
| Paxovasa |
 Posted: 14:30 - 03 Jan 2011 Post subject: |
Take the plug out, clean it, warm it up, put a little petrol in the plug hole, put the plug in and see if it fires up.  ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
| Ichy |
 Ichy World Chat Champion
 Posted: 14:35 - 03 Jan 2011 Post subject: |
take out the air filter and spray easystart, or similar*, in there while cranking it over, it may take two people.
If it fires then you know its likely to be fuel related. If it doesn't fire then its something else.
*I've heard of people using wd40, hairspray, and even lighter fuel to similar effect, it may work but I'm not going to try it  |
| st3v3 |
 st3v3 Super Spammer
 Posted: 14:38 - 03 Jan 2011 Post subject: |
Iv tried deodorant; not much joy but im gonna buy some easy start today, might help with the car later too....  ____________________ Roger wrote: Women don't get damp for clingy puppies. Get some better happy pills, hit the gym & buy a medallion the size of a dinner plate. Job done |
| Ichy |
 Posted: 14:40 - 03 Jan 2011 Post subject: |
I'll add that to the list
Did you try lighting the spray before you sprayed it in the carb? |
| reckless_b |
 reckless_b Trackday Trickster
 Posted: 17:51 - 03 Jan 2011 Post subject: |
your petrol may have "gone off" these days petrol seems to go off rapidly if left, I had a kawa gt550 and if stood for about 2 weeks it would run like a pig untill it had some fresh, only today I've pulled my 600 yam radian out of the garage to have a de-stessing ride,back to work tomorrow, and this too ran poor, its been stood a few months, it would only run if it had at least half choke, it felt as if it was only running on 2 or 3,I too checked all the usuals spark etc, finished off by draining the tank, I'll give it a gallon of fresh tomorrow and see if it clears. By the way, I'd suggest draining the carbs as well, usually a drain screw on the float bowl. ____________________ 40 years on the road on and sometimes off bikes with a very recent OFF |
| Teflon-Mike |
 Posted: 18:26 - 03 Jan 2011 Post subject: |
| reckless_b wrote: | your petrol may have "gone off" these days petrol seems to go off rapidly if left, I had a kawa gt550 and if stood for about 2 weeks it would run like a pig untill it had some fresh, only today I've pulled my 600 yam radian out of the garage to have a de-stessing ride,back to work tomorrow, and this too ran poor, its been stood a few months, it would only run if it had at least half choke, it felt as if it was only running on 2 or 3,I too checked all the usuals spark etc, finished off by draining the tank, I'll give it a gallon of fresh tomorrow and see if it clears. By the way, I'd suggest draining the carbs as well, usually a drain screw on the float bowl. |
Also if you haven't run the bike since October, when did you last put petrol in it?
Sounds daft, but you probably are on the right lines.
Each year, around Octover, they change the petrol at the pumps from 'Summer' formulation to 'winter' formulation....
strange but true. Google it, you'll find its actually a legal requirement!
Sumemr formulation is less volatile, so it doesn't evaporate as badly in summer warmth.
Winter formulation is less volatile against carb-icing.
Old petrol goes stale, and if its the wrong season formulation, and a poor cold-starting bike, MAY be the problem.
Drain tank, slosh some new (fresh from the pumps) petrol in it, see what happens..... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| N cee thirty |
 N cee thirty Banned
| drzsta |
 drzsta World Chat Champion
| Scalli |
This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
 Scalli Derestricted Danger
| temeluchus |
| Teflon-Mike |
 Posted: 22:07 - 04 Jan 2011 Post subject: |
| Temeluchus wrote: | I've found a good trick is putting your spark plugs in the oven, getting em good and hot, will almost always revive a non starter provided there are no drastic faults. |
Yes, age old 'trick'.. used to have to make sure my gran was out the kitchen before I tried it though!
Bit of caution needed, though. First picking the hot spark plug up to put back in the engine can scorch skin. Dont laugh!
Picking hot spark-plug up with pliers, you can easily crack the ceramic insulation. If you haven't already, dropping it on the tiled kitchen floor, after pulling it out and juggling it like a hot potatoe!OK, laugh!
Getting 'Smart' after scorching fingers, cracking cerammic etc, leaving plug in the plug-socket, while heating, so you can luft it out with the extension bar..... CAN melt the little rubber grippy thing inside the plug socket....
If your gran doesn't smell the lingering odour of evaporated petrol when she goes to stick the roasies in the oven..... she will the acrid stench of scorched rubber! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| temeluchus |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| Paxovasa |
| Chalky. |
 Chalky. World Chat Champion
| Paxovasa |
| Chalky. |
 Posted: 12:42 - 05 Jan 2011 Post subject: |
That's a possibility, but my mummy doesn't let me play with lighters  |
| Rogerborg |
 Rogerborg nimbA
| Wilson12345 |
 Wilson12345 Could Be A Chat Bot
 Posted: 14:47 - 05 Jan 2011 Post subject: |
Yes, the petrol is too cold that's why the engine isn't starting  ____________________ Seem to not have enough karma to post :l |
| chrisjpartrid... |
 chrisjpartrid... Two Stroke Sniffer
| st3v3 |
 st3v3 Super Spammer
| st3v3 |
 st3v3 Super Spammer
The last post was made 15 years, 53 days ago. Instead of replying here, would creating a new thread be more useful? |
