Paint for front forks
GREENI3
PostPosted: 21:56 - 03 Jan 2011    Post subject: Paint for front forks Reply with quote
I have a Suzuki AY50 and it has 'Showa' front forks. Unfortunately, there's a bit of rust on them, so I was thinking of painting over it.
What sort of paint should I use on them?
herulach
PostPosted: 22:11 - 03 Jan 2011    Post subject: Reply with quote
I'll save tef the typing and link to this thread:
https://www.bikechatforums.com/viewtopic.php?t=200019&highlight=
some good advice in there.
YBR 125>FZS600
lozzypop1
Certified MILF!
PostPosted: 12:45 - 04 Jan 2011    Post subject: Reply with quote
Which part of the forks are corroding? The chromey bits? or the non-chromey bits?
If it's the non-chromey bits and they are aluminium, use a brush on 'etch' primer then paint whatever colour you want, or alternatively get them powder coated.
If it's the chromey bits... buy new chromey bits.
(And yes, I have it on good authority that "chromey bits" IS the techy poo term.)
GREENI3
PostPosted: 15:56 - 04 Jan 2011    Post subject: Reply with quote
I need to know what they're made from so I know what paint to buy.
Here's a picture with an arrow pointing to he part of the forks where it's rusting. (By the way, these aren't my forks)
devojunior
PostPosted: 16:18 - 04 Jan 2011    Post subject: Reply with quote
From my experiance it would look rubbish just painted over the rust,my advise to you would be to get some cleaning tools like wire brushes that sort of thing and give then a really good scrub.
once cleaned up then you will be fine with most poiants id have thought iv always used hafords cheap stuff and had great results but remember the finish will only be as good as the prep you do first good look
GREENI3
PostPosted: 16:27 - 04 Jan 2011    Post subject: Reply with quote
Ok. Like you said, I was going to get some wire wool and prep the surface before painting it.
Do you know what that part of the forks are made from? It's either chrome or alloy, I'm not sure Confused
GREENI3
PostPosted: 13:42 - 08 Jan 2011    Post subject: Reply with quote
Do you think I could use silver alloy paint & lacquer on my forks?
Ichy
PostPosted: 14:06 - 08 Jan 2011    Post subject: Reply with quote
They are steel of some type, alloy generally don't rust.
Use any old paint you like, just remember that the finish is only as good as the base that you start from.
GREENI3
PostPosted: 14:34 - 08 Jan 2011    Post subject: Reply with quote
Thanks for the reply. That's all I needed to know. Much appreciated Very Happy
PostPosted: 14:36 - 08 Jan 2011    Post subject: Reply with quote
My Dad used alloy wheel paint on his forks that came out really well.
The last post was made 15 years, 95 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 61.51 Kb
