Suggest decent cable connectors?
Adam80UK
PostPosted: 22:18 - 04 Jan 2011    Post subject: Suggest decent cable connectors? Reply with quote
My aftermarket mirrors with indicators require removing them to adjust the arm angle, which in turn involves removing scree, then VERY annoying wellnuts, and display unit just to disconnect indicators.
I want to cut the wires at the point they go through the fairing before the go into the display unit, and connect with some kind of connector.
I want this connector to ideally be black, waterproof, and easy to clip and unclip.
Any suggestions please?
Current: '07 Suzuki SV1000 & '07 Honda SH300i (again).
Previously owned: '08 Yamaha R1, '10 Kawasaki Z1000, '07 Honda SH300i, '04 Suzuki SV1000S, '11 Honda CB1000R, '09 Kawasaki ZX-10R, '08 Aprilia Tuono 1000R, '07 Triumph Daytona 675, '95 Honda CBR600F.
woll
PostPosted: 22:37 - 04 Jan 2011    Post subject: Reply with quote
I'd personally solder them on, and shrink wrap the joints.
Shaft
PostPosted: 23:23 - 04 Jan 2011    Post subject: Reply with quote
I might be stating the bleeding obvious, but wouldn't the trick be to keep trial fitting the mirrors, until they're in the right place, then screw/bolt it all up?
Adam80UK
PostPosted: 23:30 - 04 Jan 2011    Post subject: Reply with quote
Well that's no benefit at all lol.
Adam80UK
PostPosted: 23:31 - 04 Jan 2011    Post subject: Reply with quote
CHR15 wrote:
Looks perfect thanks, will go for these I think.
Adam80UK
PostPosted: 23:33 - 04 Jan 2011    Post subject: Reply with quote
Problem is if one gets knocked or anything that's it, the bolt holding arm in place goes through base plate and up the arm of the mirror, so only way to it is by taking them off. I want this to be possible with ease should I ever have need.
PostPosted: 23:41 - 04 Jan 2011    Post subject: Reply with quote
https://www.vehicle-wiring-products.eu/ seems to have the best selection connectors.
GeneralXcepti...
PostPosted: 01:21 - 05 Jan 2011    Post subject: Reply with quote
If you're going to use the waterproof connectors (and I recommend that you do 'cus they rock), take care crimping the connectors unless you have the proper tool. You can use needle nosed pliers no problem, just take your time.
Also, remember to put the rubber seals on the cable before crimping Embarassed and make sure that you crimp the smaller part of the rubber seal under the first part of the connector (second part is just for the exposed wire) to ensure that it's a watertight seal.
Adam80UK
PostPosted: 02:01 - 05 Jan 2011    Post subject: Reply with quote
Cheers for the advice! Will look back as a reminder when they arrive, though maybe should of ordered a third just in case.
Adam80UK
PostPosted: 21:31 - 05 Jan 2011    Post subject: Reply with quote
Just realised I've dicked myself buying those! It will not fit through the hole in the fairing so they are pointless. £14 well spent then Evil or Very Mad
Adam80UK
PostPosted: 18:35 - 07 Jan 2011    Post subject: Reply with quote
Maybe I could use some 2.5mm stereo jacks;
https://www.maplin.co.uk/Module.aspx?ModuleNo=1140
https://www.maplin.co.uk/Module.aspx?ModuleNo=1143
Any reason not to?
Adam80UK
PostPosted: 18:50 - 07 Jan 2011    Post subject: Reply with quote
Actually would want a mono one with 2 connections as opposed to stereo which has 3.
And why am I talking to myself on my own topic...
Seb
PostPosted: 19:07 - 07 Jan 2011    Post subject: Reply with quote
Regular jackplugs will likely foul up doublequick in our lovely weather.
2010 Triumph 1050 Sprint ST
Adam80UK
PostPosted: 01:45 - 09 Jan 2011    Post subject: Reply with quote
Something simple like this would be good but can't find anywhere to buy them.
https://www.whitetailsupply.com/Connectors/2_wire_locking_connector.jpg
The last post was made 15 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 90.58 Kb
