Oil drain bolt threaded
Auzfest
PostPosted: 20:56 - 06 Jan 2011    Post subject: Oil drain bolt threaded Reply with quote
Start off by saying hi guys,long time lurker here but not really introduced my self.After taking out drainbolt today i noticed some thread came out also the crush washer was crushed giving me the impression that the bolt was way overtightened,i refit jhe bolt without a washer not too far past finger tight and it seems pretty secure and no indication of leakage, is it likely the bolt will hold or is there anything else i can do to help secure it cheers?Auz.
Mrs Vale46
PostPosted: 21:06 - 06 Jan 2011    Post subject: Reply with quote
Not sure but just an idea...... Could re-tap the hole and replace with a bigger wahser and bolt size?
Auzfest
PostPosted: 21:13 - 06 Jan 2011    Post subject: Reply with quote
Would it be a case of just forcing a slightly bigger bolt in or is it a more intricate job than that?
Mrs Vale46
PostPosted: 21:18 - 06 Jan 2011    Post subject: Reply with quote
No that would more than likely just bugger up the thread even more....
Dazbo666
PostPosted: 21:41 - 06 Jan 2011    Post subject: Reply with quote
Re-tap the thread to a fraction bigger than the existing one, then use a larger replacement bolt & washer
and if you were anywhere near me I'd be happy to re-tap it in exchange for a beer Wink
(...or you could try heat sensitive thread lock on the existing bolt?? but for me, that would really only be a temporary / emergency solution)
Word of the day : DILLIGAF
PostPosted: 22:01 - 06 Jan 2011    Post subject: Reply with quote
Mmm, I did this a while back, due to being a lazy cheap bugger and not replacing the already-crushed crush washer. Sad
Tapping it out is on my list of things to do (honest) but in the end, I just replaced the crush washer with a rubber seal (cut up bicycle inner tube) so that the bolt could reach the good threads higher up, and it's been dry and secure. Your bike, your risk though.
Auzfest
PostPosted: 23:19 - 06 Jan 2011    Post subject: Reply with quote
Mate id give you a bloody case of beer not just a pint for such a kind deed.
Auzfest
PostPosted: 23:25 - 06 Jan 2011    Post subject: Reply with quote
rob yarrr wrote:
what bike is it ?
could take the sump off and get it retapped
It's an 07 plate yamaha xt 125 ,how much would i expect to pay a mechanic for a job like this?
dragstaar
PostPosted: 23:27 - 06 Jan 2011    Post subject: Reply with quote
Does the bolt reach a stiff point half way in? I know it sounds silly, but are you sure it was definitely some thread that came out and not just the filings? Because my drain bolt is magnetic, and I made that mistake when i first saw the filings. It never had that much on it before, and i thought i'd threaded it.
Auzfest
PostPosted: 23:32 - 06 Jan 2011    Post subject: Reply with quote
Hmm,think i will take a similar approach to get me by for now, will bodge up a rubber washes and use some builders tape around the base of the nut(depending on the amount of thread taken off. To be fair i only want the bike untill spring and i get round to doing my test
Auzfest
PostPosted: 23:43 - 06 Jan 2011    Post subject: Reply with quote
Seemed still all along the bolt up untill the end of the bolt .could not screw in with fingers but went in with a persuasive wrench. There was definatly threading from either the screw or inner thread are a coil of aluminium wrapped sound the bolt. To be fair i shat myself when i realised id possibly bollocks my bike so i bodgeg it back in and set off home. Not had a chance for a thorough inspection as it was gettins dark
lihp
PostPosted: 00:00 - 07 Jan 2011    Post subject: Reply with quote
If you're not confident using a tap and die set to re-thread it, then I would let somebody else do it if possible. Where are you based? Tapping a thread can go pretty wrong too, best to practice on something scrap before having a first go on something you need Wink
fiery tupp
PostPosted: 00:11 - 07 Jan 2011    Post subject: Reply with quote
Auzfest wrote:
rob yarrr wrote:
what bike is it ?
It is quite an easy job really , especially as the drain plug is horizontal ,I beleive its the same as engine as the YBR & it can easily be done in situ , with the bike leant over , like as described before , just re'tap, one size up. The sump guard may need removing ? 3 bolts .
Souleh
PostPosted: 00:19 - 07 Jan 2011    Post subject: Reply with quote
Reverse tap it and stick a bolt on then ratchet off?
MaybeGuy
PostPosted: 00:24 - 07 Jan 2011    Post subject: Reply with quote
never tap a sump with it still attached to the engine
Souleh
PostPosted: 00:28 - 07 Jan 2011    Post subject: Reply with quote
Just the bolt I meant
lihp
PostPosted: 04:11 - 07 Jan 2011    Post subject: Reply with quote
You don't want to leave any swarf in the sump!
Auzfest
PostPosted: 10:35 - 07 Jan 2011    Post subject: Reply with quote
Well. It's snowing again. Looks like the bike is gonna have to wait.
DrDonnyBrago
PostPosted: 10:54 - 07 Jan 2011    Post subject: Reply with quote
Perfect opportunity to get on with it.
Get the sump off, take that to a garage or a engineering place and get it tapped to a larger thread size, then buy a larger sump plug and some crush washers.
You might want to consider getting a torque wrench too to avoid any future thread stripping Thumbs Up .
PostPosted: 11:53 - 07 Jan 2011    Post subject: Reply with quote
Oh, pfft, it's just like tapping the wife. In, out, in, out, shake it all about, wash the crap off.
fiery tupp
PostPosted: 11:58 - 07 Jan 2011    Post subject: Reply with quote
You can't just take the sump off , as the drain hole is in the crankcase Neutral
DrDonnyBrago
PostPosted: 12:00 - 07 Jan 2011    Post subject: Reply with quote
Ah.... that sucks.
stutterin' sam
PostPosted: 14:18 - 07 Jan 2011    Post subject: Reply with quote
Smear the tap thickly with heavy grease before use, the grease will trap the swarf and enable it to be removed with the tap. Have done this many times over the years without any problems.
Smile
It is said that if you line up all the cars in the world end to end, some idiot on a sports bike would be stupid enough to try and pass them.
The last post was made 15 years, 97 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 128.39 Kb
