| jaxx |
 jaxx Nova Slayer
 Posted: 13:27 - 06 Jan 2011 Post subject: Threaded Spark Plug |
I've just come to change the plugs on the bandit, and found that the far right hand plug felt a little loose in its housing.
After taking it out, very easily..., I tried to replace it, and the new plug wouldn't tighten up...
I've been very easy on it, and not forced it, as I dont want to make it any worse. Previous owners obviously didn't share this attitude...
Someone I know, fairly unreliable, has suggested Blue Loctite as a quick fix. Just wanted some opinions on this and other remedies. Obviously I know that the right thing to do would be remove the head and get it tapped, but I doubt I could afford that right now.
All help gratefully recieved
Jack |
| Paxovasa |
 Paxovasa World Chat Champion
| The Artist |
 The Artist Super Spammer
| jaxx |
 jaxx Nova Slayer
| Paxovasa |
| ms51ves3 |
 ms51ves3 Super Spammer
| N cee thirty |
 N cee thirty Banned
| jaxx |
 jaxx Nova Slayer
| Paxovasa |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 13:46 - 06 Jan 2011 Post subject: |
if you are going to go down the heli-coil route, i recomend time-sert or the wurth time-certs
they are far better than heli-coils or re-coil etc,
you can use standard taps, and you will struggle to break the little tab off on heli coils, time serts actually seat on the top edge and not on the bottom, so won't just thread right through into the cylinder ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| jaxx |
 jaxx Nova Slayer
| Pete. |
 Pete. Super Spammer
 Posted: 15:04 - 06 Jan 2011 Post subject: |
Timeserts are superior to helicoil but sometimes it's not possible to get the tool in on cylinder heads. Helicoils have been used millions of times and you do sometimes have trouble with them winding out but I bet the ratio of it occurring is hundreds if not thousands to one. I've done a handful and none have come out yet.
Forget the loctite, it'll most likely just blow the plug out one day when it gets hot. ____________________ a.k.a 'Geri'
| chris-red |
| Pete. |
 Pete. Super Spammer
| N cee thirty |
 N cee thirty Banned
| Peterthepillo... |
 Peterthepillo... Borekit Bruiser
| temeluchus |
| BIG ZOOK |
 BIG ZOOK Borekit Bruiser
 Posted: 21:06 - 06 Jan 2011 Post subject: serious ? |
Quick fix wack the threaded end of the spark plug ,several times with a chopping axe,then you will be able to tighten it up to the correct torque,without damaging the cylinder head.You can fix it with a time/cert at a later date.Ps ran the same chop method in a 99 plate gsxr 600 for 10,000 miles no bother. |
| Noxious89123 |
 Noxious89123 World Chat Champion
 Posted: 22:07 - 06 Jan 2011 Post subject: Re: serious ? |
| fiery tupp |
 fiery tupp Trackday Trickster
| LongJohn22 |
 LongJohn22 Trackday Trickster
| Ed Case |
 Ed Case World Chat Champion
| Vincent |
 Vincent Banned
 Posted: 00:24 - 07 Jan 2011 Post subject: |
+1 for timesert if you can get one in. It might be just as cheap to get it done profesionaly than buy a kit. You won't be able to retap it unless it's drilled out and resleeved and I'm not sure I'd like to rely on loctite with a bike, I've seen bikes where the plug has blown out and through the tank (you are sure that it's the thread on the head that's gone and not just the plug?) |
| chris-red |
| temeluchus |
The last post was made 15 years, 100 days ago. Instead of replying here, would creating a new thread be more useful? |
