New battery - Fubar
Kris
PostPosted: 11:57 - 07 Jan 2011    Post subject: New battery - Fubar Reply with quote
Got a new battery last weekend.
Got home and attached the acid container on top (i.e. push down and allow seals to break and acid to flow into cells) as I have done numerous times over the years.
Firstly, the central 4 cells refused to fill up and the others stopped halfway. A jiggling caused a few bubbles but little else which indicated an air lock. Tried to lift off and back on gently but to no avail - ended up piercing top of each container to break seal. Acid then went in...
Then charged it up after overnight on a trickle charger after leaving it to stand for several hours. Charger indicated (upon inspection next day) that battery was all good.
Fitted it, lights all work, indi's work, touch starter...
DEAD (everything off - lights the lot)
Ignition off, then back on and we have lights, indi's etc..
Touch starter...
Is this a duff one or what! As soon as it requires a big load it fails.
Why is this? Thanks
www.prisonplanet.com
Paxovasa
PostPosted: 12:03 - 07 Jan 2011    Post subject: Reply with quote
I usually leave a new battery on charge for at least 10 hours, usually overnight.
Check that the terminals are a nice and tight.
Kris
PostPosted: 12:09 - 07 Jan 2011    Post subject: Reply with quote
Sorry doesn't read well up there ^^
Should read "Then charged it up after overnight on a trickle charger after leaving it to stand for several hours. Charger indicated (upon inspection next day) that battery was all good."
Terminals were F tight and clean - trust me had that issue before Laughing
Paxovasa
PostPosted: 12:13 - 07 Jan 2011    Post subject: Reply with quote
May well be just a faulty battery.
A dodgy earth would have the same symptoms.
I prefer to get the sealed batteries. Then all I do is stick them on charge and fit them onto the bike.
fiery tupp
PostPosted: 12:55 - 07 Jan 2011    Post subject: Reply with quote
I would take it or send it back , it sounds like you've got a duff one & they should replace it without any fuss , . Neutral
Paxovasa
PostPosted: 14:45 - 07 Jan 2011    Post subject: Reply with quote
Before sending it back, try a set of jump leads from another battery and see if the bike will turn over Thumbs Up
Bikeless
PostPosted: 16:22 - 07 Jan 2011    Post subject: Reply with quote
You tried a multimeter on it to see what voltage it's giving?
PostPosted: 16:26 - 07 Jan 2011    Post subject: Reply with quote
Could be a dodgy battery (possible that if dropped it could damage a terminal so it made a poor internal connection).
However I would also check the other connections. Ie, the main earth onto the back of the engine (on a Bandit, not sure what bike this is on though). Also the main connections to the starter relay (often where the rest of the electrics take their feed from).
baldy
PostPosted: 00:31 - 08 Jan 2011    Post subject: Reply with quote
Sound like a bad connection, check the battery connections and the wires for splits inside.
One day i will rule the world, just not today.
temeluchus
PostPosted: 01:06 - 08 Jan 2011    Post subject: Reply with quote
seeing as it is taking a charge, yo may have a damaged plate or two. would seriously curtail the battery from holding much current.
MattEMulsion
PostPosted: 09:20 - 08 Jan 2011    Post subject: Reply with quote
Why did you fit a new battery in the first place? Are you sure that your old battery was knackered and that you haven't actually got a different fault?
Yamaha YZF-R6
Kris
PostPosted: 10:15 - 10 Jan 2011    Post subject: Reply with quote
Alreet, cheers for the replies.
The new battery measured 12.34V when charged and out of the bike (guy in shop tested) but when he heard about the sudden death when thumbing the starter he was happy to give me a replacement.
The bike is fine, currently using the old battery and no problems. I guess this was just a duff one <shrugs> Who knows!
The last post was made 15 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 72.72 Kb
