tighten the chain.
timelimit
PostPosted: 14:43 - 05 Aug 2004    Post subject: tighten the chain. Reply with quote
Very Happy
hey guys, got a slight problem. im at work and real;ised that my chain is way too slack Sad so quick question? how do you tighten a chain on an nsr?
and what tools will i need.
sorry the post is so short but ive got my boss walking around Sad
thanks guys
"Gaspar you fool"
NSR125-Kid-UK
Attention Whore
PostPosted: 15:06 - 05 Aug 2004    Post subject: Reply with quote
Well, you see the big nut on the left hand side of the bike on the swingarm? that's where the axle pokes through. You'll need to slacken this off - you might do well to slacken it off at the other end too, but don't pull the bolt out unless you want your wheel to fall off Wink .
At the end of the swingarm on either side, there should be a bolt, each with two nuts on. The nuts closest to the end of the bolt are the lock nuts - slacken these off. The nuts behind them are responsible for adjusting your chain. unscrew these nuts - a half turn at a time, at either side, to pull your wheel backwards. Be sure that you unscrew the wheel adjusting nuts the same amount on either side, or else you'll end up with a misaligned wheel, which points in a direction other than straight forwards. This can cause uneven chain/sprocket wear, as well as abnormal brake disc/pad wear, or could even be dangerous. Once you have the chain tightened up far enough (there should be about 1.5 inches of play in it when the bike's in gear - putting the bike in gear tensions the chain - putting the bike in gear isn't part of tightening the chain up as described in the manual, but an observation I made.), tighten up the locknuts. Once these are tight, and the chain is tensioned, tighten up your wheel bolt again Smile. That should be Job done Smile.
(disclaimer - this poster accepts no responsibility for damage or injury caused - maintenance work on the bike in question is the responsibility of the owner Razz )
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
mr jamez
PostPosted: 15:10 - 05 Aug 2004    Post subject: Reply with quote
You should have posted this in the workshop section, will get more attention there Wink Oh and do not tighten the chain too far!
Loosen the rear wheel nut, put the bike on the centre stand, pop it into neutral, turn the adjusting nuts (they are on the end of the swingarm) equally until there is 25-35mm of slack on the chain (measure from inbetween the two sprockets right in the middle). Secure the adjusting nuts, pinch up the rear wheel nut, put the bike back on the ground then tighten the rear wheel up to 9.0kgm or if you have no torque wrench, forking tight!
Mr Pants!
I Karma
PostPosted: 15:45 - 05 Aug 2004    Post subject: Reply with quote
Yes, the torque is very very important.
Mr Pants! (Alex or Al)
Its better to burn out, than to fade away....
NSR125-Kid-UK
Attention Whore
PostPosted: 15:48 - 05 Aug 2004    Post subject: Reply with quote
That reminds me. My chain's got a load of tight spots Sad .
Anyone know how to get rid?
dainesefreak
PostPosted: 15:50 - 05 Aug 2004    Post subject: Reply with quote
Try cleaning it, degrease it and relube. Work some lube into the tight spots if it doesn't free get a new one.
NSR125-Kid-UK
Attention Whore
PostPosted: 15:52 - 05 Aug 2004    Post subject: Reply with quote
Decent O Ring Chains cost £12? Very Happy
That's all I have in the world Razz .
Mr Pants!
I Karma
I thought all chains had tight spots, this was normal??
dainesefreak
PostPosted: 15:53 - 05 Aug 2004    Post subject: Reply with quote
It all depends on wether you love your bike or not really. Wink
mr jamez
PostPosted: 15:54 - 05 Aug 2004    Post subject: Reply with quote
Cheapest I have seen for the NSR is £40
Hmm.
NSR125-Kid-UK
Attention Whore
PostPosted: 15:55 - 05 Aug 2004    Post subject: Reply with quote
I love my bike!!!
(I'd rather have a Mito Evoluzione Wink )
but I don't have any cash, nor ways of earning any GRR Confused .
McJamweasel
BCF Junkie
...but I don't have any cash, nor ways of earning any GRR Confused .
Get a job then. Thumbs Up
NSR125-Kid-UK
Attention Whore
PostPosted: 16:25 - 05 Aug 2004    Post subject: Reply with quote
I'd get a job tomorrow Smile. If there were jobs other than "shit shoveller" and "McDonalds Crew Member" (same thing) available.
McJamweasel
BCF Junkie
PostPosted: 16:30 - 05 Aug 2004    Post subject: Reply with quote
So what you're saying is that its not a lack of ways to earn, its a lack of motivation to work.
Shit jobs are there, and they do pay. Go do one.
Git
PostPosted: 16:48 - 05 Aug 2004    Post subject: Reply with quote
One thing worth bearing in mind when adjusting a chain is to adjust the free play at the tightest point, ie a tight spot.
Hope that made sense. Confused
mr jamez
PostPosted: 16:54 - 05 Aug 2004    Post subject: Reply with quote
Don't complain about not having money if there are jobs available but you can't be bothered to get off your arse and get one Wink face it, all part time jobs at our age are shite. I don't know of anyone in a similar postion to me who has a decent job, I earn the most out of everyone I know which is £5.38p/h!
I was on £4.07 in my previous job, but these shit shovelling jobs have got me a nice little car, a driving license and a motorbike Smile
The last post was made 21 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 92.39 Kb
