URGENT: Will a 2001 Derbi GPR engine fit a 2003 Derbi Senda?
povall_555
PostPosted: 17:15 - 08 Jan 2011    Post subject: URGENT: Will a 2001 Derbi GPR engine fit a 2003 Derbi Senda? Reply with quote
anybody know if a Derbi GPR engine will fit a 2003 Derbi Senda?
LJColeman
PostPosted: 18:18 - 08 Jan 2011    Post subject: Reply with quote
They are the same engine so yes...
Derbi Senda extreme Smile
cheekythomas
PostPosted: 21:44 - 08 Jan 2011    Post subject: Reply with quote
It's a similar engine yes... The same... No.
Just a couple of things you'll find..
Firstly the GPR engine will have an electric starter fitted, your senda won't.. Leave it fitted just unwired as it blocks a hole in the crankcase and will stop debris getting in there.
So as your not using the GPRs electric start, you'll need to swap over the sendas RH engine case, and kickstart mechanism as the GPR doesn't have them fitted.
When the case is off, you'll notice the GPR has an internal balance shaft fitted, that's timed off the clutch basket... Where as the senda doesn't. If you end up struggling with the kickstart shaft spring and remove the clutch basket for more room, make sure you line the dots up correctly on the parts to keep the timing right.
It's all straight forward to do.
If ya need anymore help, just ask.
The last post was made 15 years, 95 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 40.25 Kb
