Urgent problem - car (sorry) hydraulic clutch.
Imonster
PostPosted: 21:50 - 09 Jan 2011    Post subject: Urgent problem - car (sorry) hydraulic clutch. Reply with quote
Friend's car is stuck outside my place - he parked up yesterday, and went to move off today and there's no resistance in the clutch at all, i.e. you put your foot down on it and it doesn't even return to it's original position when you lift your foot off, let alone allow you to get it into gear.
He had a similar problem about a month ago that we cured by just topping up the fluid - in that instance though, the pedal was returning to it's original position when your foot wasn't on it, even though it wouldn't go into gear.
If at all possible, we need to get this sorted tonight. Other than breakdown recovery, any ideas as to what the problem could be, or is the clutch just FUBAR'd?
edit: sorry, Honda Accord Aerodeck
Those who make peaceful revolution impossible will make violent revolution inevitable.
Nb
PostPosted: 21:54 - 09 Jan 2011    Post subject: Reply with quote
Slave cylinder has probably got a leak if hes had to top up the fluid.
If you check the level in the reservoir is it low? You might get away with topping up the fluid and bleeding it.
https://forums.clubrsx.com/showthread.php?p=29484171
mad4it028
clutch slave cylinder at a guess it depends on what car to how simple a fix
you could probally get away with refilling the resivor and rebleeding to get somewhere to get one
on fords its a big job on fiats its a 5 min job
Imonster
PostPosted: 21:58 - 09 Jan 2011    Post subject: Reply with quote
Apparently he's tried topping up again and bleeding but no difference; we're going to have another crack at it now.
Thanks for the help thus far Thumbs Up
mad4it028
PostPosted: 21:59 - 09 Jan 2011    Post subject: Reply with quote
what car it it?
can you see where the fluids leaking from?
Imonster
PostPosted: 22:00 - 09 Jan 2011    Post subject: Reply with quote
Honda Accord Aerodeck. Difficult to pinpoint the leak in the dark, though there's definitely a bit of a puddle underneath.
Nb
PostPosted: 22:01 - 09 Jan 2011    Post subject: Reply with quote
Keep trying to bleed it, slave cylinders can send even the calmest mechanic over the edge when it comes to bleeding at times. Neutral
mad4it028
PostPosted: 22:05 - 09 Jan 2011    Post subject: Reply with quote
i beleave the cylinder is on the outside on honda/rovers rather than in the belhousing like mondeos ect so its a simple job shouldnt cost much in parts
PostPosted: 22:06 - 09 Jan 2011    Post subject: Reply with quote
Another vote for the slave cylinder. However I would still expect the pedal to return (I would expect there to be a return spring in the master cylinder), so possibly the master cylinder or a popped hose.
Imonster
PostPosted: 22:11 - 09 Jan 2011    Post subject: Reply with quote
Nb wrote:
Thanks, but the problem with that is that the clutch pedal isn't even returning, when you push it down it remains flat on the floor even with fluid topped up - almost like a linkage has gone somewhere. Trouble is, I know virtually nothing about cars Neutral
And not much more about bikes Mr. Green
prawny1
PostPosted: 01:57 - 11 Jan 2011    Post subject: Reply with quote
have you actually lost any fluid or found any leaks?
It is possible also that the thrust bearing has pushed through the clutch spring plate,
If the master or slave are leaky it is definatly cheaper to buy a seal kit or used parts than buy new, just make sure the bores aren't scored.
hellkat wrote:
The last post was made 15 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 69.41 Kb
